Question about Bissell Velocity Bagless Upright Cyclonic Vacuum
My velocity has little suction,it immediatley clogs the filter inder the dirt cup snd goes no further..we just changed both filters
    Champion:
  • 363 Answers
Have you unclogged the from where it enters the vacuum to the end of the hose, sometimes the hose clogs are the way up into the machine which will reduce the suction to almost nothing.
Posted on Jul 27, 2009
What causes poor suction on model ud40270? It seems like a lot of air is blowing out the front where the filter is.
Susan:
First, remove and clean or replace all of the filters in the machine. There is an inlet filter above the dirt collection cup. and an exhaust filter at the front lower part of the top of the vacuum head. If either filter is clogged, you'll get poor suction. Also lay the machine on it's back, and check the tunnel where the dirt goes up into the machine (behind the beater bar) to see that it is not clogged.
Jan 08, 2015 | Filter Vacuums
Loss of suction o=with hose tool
Hose or tool is probably clogged. Is this an upright? Bagged or bagless? Have you changed the bag and filters? Cleaned out the brush and hose that goes from the brush area to the collection bag/cup? The only reason for a vacuum cleaner to lose suction but still work is a clog or dirty filter which blocks the air flow. Follow the air flow from the brushes to the bag/dirt cup. If the machine is bagged, change the bag. I use another vacuum cleaner to do this.While your at it, might as well change the belt.
Nov 15, 2011 | Hoover Vacuums
No suction
Could be a clog of course. Id run a coathanger or something similar through the tunnel the dirt goes up through.
Another thing is if the dirt cup and filter aren't seated right, it could stop suction.
You could take the dirt cup off, and turn the machine on, and see if there is any suction right at the motor, carefully of course. That could rule out a fan/motor issue.
Jun 11, 2011 | Hoover Platinum LiNX Cordless Stick Vacuum
No suction through top of hose - HELP
disconnect the hose where it goes into the clear tube on top of the base.there will be a little flapper door there when yo take it off.open the door and take a coat hanger with the end bent over like a hook and pull the dirt clog out of there.but first take the dirt cup off and remove the filter,if its clogged with dirt you won't have any suction.try using the vacuum without the filter in the dirt cup.if you have suction then then thats your problem ,a cloggeds filter
Jul 01, 2009 | Dirt Devil Featherlite Bagless Vacuum...
Suction when I vaccum the floor but not in the hose
remove the filter from the dirt cup and try again,if you have suction the the filter is clogged.the other is the intake hose that goes into the top of the base where the clear tube is.disconnect the hose from the base tube and take a coat hanger and bend the end into a hook.open the litte flapper door and stick the hanger down in the tube and see if you can pull out a clog of dirt.last but not least,disconnect the top hose completelyfrom the vacuum and see if you can blow through it.if you can't then the flex top hose is clogged.open the little flapper door on the top of the base and turn on the vacuum,if the intake hose isn't clogged then you should have suction.that will tell you that the broblem is in the flex hose or the filter
Jun 07, 2009 | Dirt Devil Featherlite Bagless Vacuum...
I recently cleaned all the filters in my Bissell powerforce, now instead of suction I get all blown back instead.
take all the filters out put the dirt cup back in then try it again.3 filters 1 on the bottom of the dirt cup and one above the dirt cup and one in front at the bottom behind the little door.if thats not it at the bottom on the right side you will see a clear hose thats your intake hose,one screw holds it on,take it out and bend a coat hanger so the tip is rounded ,then work it down into the clear hose ,you should be able to push the clog out through the bottom
Apr 28, 2009 | Bissell 6594 PowerForce Bagless Upright...
Vacuum hose has little suction.
There is most likely a clog in the hose. If the hose has poor suction the foot probably has poor suction as well seeing that the hose is what gives the foot assy suction.
Jan 05, 2009 | Bissell 6594 PowerForce Bagless Upright...
Decreased hose suction with Windtunnel
There are very few things left to check. First verify that the filter is installed properly, in the dirt cup. second check to make sure the dirt cup lid is on and secure. Did you use water on the round dirt cup filter? if you have you will need to replace it. To verify this remove the round filter and re-install the dirt cup on the vac. do not vacuum the carpet, just turn it on to check for proper suction. and then turn it off.
Your problem has nothing to do with it in the upright position. once turned on you will always have suction, either to the floor or when hose is removed from foot for accessories.
Dec 03, 2008 | Hoover U5753-900 WindTunnel Bagless...
Vacuum Problem
The Bissell can have several filters in it, depending on the model. Some have a round hepa filter that is covered with a foam sleeve. This filter is located at the bottom of the dirt cup. Others have a foam filter that is located under the dirt cup in a pull out drawer. Also, they can have a cylindrical separator above the dirt cup which can be removed and washed. They are usually a blue plastic and you reach in and turn it a 1/4 turn counter-clockwise to remove. If your machine has the hepa filter, when you remove the dirt cup, the filter is at the bottom and you turn the bottom 1/4 turn and the clear housing will come off to access the filter. You should also check the small filter on the machine just below where the cup sits. This will only be there if your machine has the hepa filter on it.
Mar 21, 2008 | Dirt Devil Vision Turbo W/Bonus Upright...
Hoover Windtunnel
Either the hose has a clog, or the inlet down by the belt is clogged. Is there suction at the end of the hose, if not then it is clogged. If there is suction, then it has to be clogged down below by the brush roll, check that inlet. There also is a filter at the bottom where the dirt cup (and bag) is, check it also.
Dec 28, 2007 | Vacuums
Bissell Velocity Bagless Upright Cyclonic Vacuum Logo
191 people viewed this question
Top Bissell Vacuums Experts
Jim Thurston
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
