Question about Maytag Dishwashers
Hello, it seems that my maytag does not drain properly anymore.it leaves a puddle of water at the base all the time...I think its because particles of the dirt may have clogged the output of the drain. what can I do to fix this problem...many thanks in advance. you may reply at my email address at domenic.ricciotti@dhl.com
  • 1462 Answers
SOURCE: dishwater fills with water, hot...but doesnt wash?
when in the wash phase, listen for a low hum near the wash pump. if you hear this it indicates the wash pump capacitor is faulty or something jammed in the pump.after that you will have to access the wash pump and check if there is any supply to it
Posted on May 04, 2007
  • 1314 Answers
SOURCE: Kenmore 18inch Portable Dishwasher
how is the water flow at your sink this is a portable right un screw the connector at the sinkand check the screen 2 your fill hose could be kinking up when you pull it out take a light and look down into the washer see if you can see it kinked we will go from there
Posted on Dec 31, 2007
SOURCE: Kenmore Dishwasher leaving SAND behind
1. Remove the top rack and lower rack.
2. Remove the lower spray arm by holding the top of the center hub and rotating spray arm counter clockwise.
3. Remove water tube feed from the back wall of the dishwasher by unclipping at top and back. Pull towards you and lift tab at the bottom on the big tube to remove the plastic clip from main water feed.
4. Remove the main water tube by turning quarter turn clockwise, then lift off. Keep the center hub from falling out so you don't lose the plastic washer.
5. Using a star tip screw driver; remove the four screws and lift off the filter cap assembly. The assembly consists of the screen filter and the food trap grate (The outer edges look gear like).
6. Look down inside this area and clean out anything foreign. usually there will be seeds, paper, and other gook. I used tweezers, toothpicks, and needlenose pliers. I remove from my dishwaser quite a bit of paper, two wooden match sticks, lots of undissolved soap etc.
7. When you have removed as much as you can, put everything back together in the order you removed it.
8. When you run the next cycle, you should immediatly hear more noise to indicate that you have cleared the pathway that allows water to flow at its intended pressure.
Posted on Nov 13, 2008
  • 677 Answers
SOURCE: GE Profile Dishwasher (5 years old); Leaving residue on dishes
There is a new product out that actually filters the water going into your dishwasher. My dishes came out amazing after the first load. No more cloudy glasses. I was very impressed. Who knows whats in the water cleaning your dishes so i thought this filter was great. It is very affordable and you can get it at www.dishwasherfilter.com. Hope this helps some people.
Posted on Jan 06, 2009
  • 677 Answers
SOURCE: Maytag dishwasher filter keeps clogging
There is a product made to filter the water going into your dishwasher only to soften the water and remove the calcium before it enters your dishwasher. your dishes will be spotless and it will not get clogged again. you can get it at www.dishwasherfilter.com. it goes right under the sink and is very affordable. you will love this product and it will solve your problems.
Posted on May 07, 2009
Why does my double doors/GE/culligan refrigerator leak water at night
there will be a drain at the back of the fridge down the bottom there is probably something caught in it blocking it causing the water from the evaporator in the fridge to run out instead of down the drain
May 22, 2014 | GE Refrigerators
When it rains puddles of water on the passenger side floorboards mostly in the back not coming from sunroof and theres a crack in my windshield thought it might be that but the dashboard is never wet so...
The cowl drains could be clogged. Trace from the opening at the base of the windshield down to door hinges and look for debris such as leaves in the opening behind the hinges. You may have to use a coat hanger as a special tool to remove the debris.
Oct 10, 2017 | Cadillac Catera Cars & Trucks
Hi, Have a Maytag LSE1000 stackable w/d. Has worked flawlessly for years. Now the washer will not drain and shuts off after wash cycle leaving the unit full of water/laundry. Can you give me an idea where...
Hello
Washer not draining completely is caused due to clogs/blockages in the drain hose. You can start by checking the drain hose and clean the drain pump filter of any foreign particles. Please get back to me if you have any other questions.
Kevin
Nov 09, 2010 | Maytag Washing Machines
I have a Maytag MSD2556AE Side by Side Refrigerator/Freezer. I keep getting a puddle of ice in my freezer and water leaks out of the freezer onto the floor. All this happens in spite of the water line to...
Sounds like you have a frozen drain line. I would unplug the unit at let the drain line thaw. This would be the easiest way to rectify the issue. Leave both doors open for 24 hrs. Hope this helps _MJ_
Jul 28, 2010 | Maytag MSD2756G Side by Side Refrigerator
I have a top freezer Maytag refrigerator. Water condenses on the "ceiling" of the refrigerator section enough to drop onto the top shelf and form small puddles. Otherwise, the refrigerator seems to keep...
first make sure the door of your fridg is closed very good, check in your freezer behind the back wall that the drain is clean and water can flow down.
Dec 29, 2009 | Refrigerators
Does not pump water. Leaves dishes soappy
We really need your model number to help you properly. In the mean time you can check you sink connection and air gap for obstructions. Usually the cover just pulls up and off then you unscrew the cap to expose the drain tube for the dishwasher. More often than not if the unit fills and washes but leave soap on the dishes a clogged drain line is the problem. You may have to run something down the drain tube to clear it. Usually you will see the obstruction when you remove the cap. There is a remote possibility if it drains into a garbage disposal that food particles have clogged the drain outlet inside the garbage disposal. Hope this resolves your problems. Cheers!
Sep 20, 2009 | GE 15" Laundry Pedestal for Horizontal...
My maytag will not clean the dishes. I have cleaned out the water tubes, I have checked the hot water. all it does when you run a cycle it leaves the dishes dry and the detergent is not being used.
Most likely causes are:
Not enough water entering dishwasher (check level after fill... Should be slightly below bottom wash arm)
Water filling but draining during wash cycle. Check toward end of wash cycle but before drain. See if water level is diminished from start of wash cycle.
New 'water saver' dishwashers are notorious for having smaller water jets, and thus easier to stop-up jets. Check the jets on all wash arms to be sure they are cleared of food particles.
Another way to check the wash arms is to manually position them at specific locations, momentarily run the dishwasher for a few seconds, then open the door to inspect the location of the wash arms. Do this three or four times to eliminate the possibility of coincidence.
If the wash arms do not move from the location that you put them, the most likely cause is food particles stopping up the water jets. These jets not only clean the dishes but also the water pressure they generate turn the arms inside the dishwasher to properly distribute water pressure on the dishes.
Sometimes you can dislodge and remove food particles stuck in one of the jets with a toothpick or other small probe. Others require that you remove the arm(s) and get a little more creative. I use compressed air to clear mine, but not everyone has access to compressed air, so use whatever you can to remove the food particles.
Simply dislodging them from the water ports is usually not effective... As soon as water pressure is applied, the particles return to the jets and stop them up again. The real fix in this instance is to completely remove the food particles from the arm if you can.
Hope this help. Good luck.
Sep 11, 2009 | Maytag 24 in. MDB8600AW Jetclean II...
Food particles are on dishes after washing
Try adding bicarb of soda/baking soda and vinegar in the detergent dispenser. Bicarb fizzes off hardened particles and vinegar strips off grease and aids rinsing.
Jan 26, 2009 | Maytag 24 in. PDB1420 Built-in Dishwasher
Older maytag fridge side by side.
Buk, there's supposed to be a drain pan under your fridge to catch the water that comes from the drain tube. The water that's coming out is supposed to be there (only, it's supposed to be caught by the drain pan)... it's the water that's made when your fridge defrosts itself. If you plug the tube, the water will back up inside the fridge , puddle up in the bottom and eventually leak out through the door.
You should order a drain pan for it. Here's a link to one online. After you have it in place, you won't have to worry about it anymore. The water that collects there will simply evaporate back into the air.
Oct 15, 2007 | Maytag MZD2766GES Side by Side...
Dishwashers Logo
19 people viewed this question
Top Maytag Dishwashers Experts
Mike
Are you a Maytag Dishwasher Expert? Answer questions, earn points and help others
