Question about Quad 47 cc / 49 cc Pocket Mini Bike Scooter Atv Pull Start
It starts fine an idles pretty good and smooth but as soon as i give it some gas to go it dies on me
    Night Owl:
    An expert who has answered 10 or more questions between 12 midnight and 6am on the same day.
  • 142 Answers
It sounds like a carburetor problem.You need to make sure the diaframs in the carburetor are good.The last thing you need to do is set the high and low speed needles.If its the same as mine,it will be on top of the carburetor.
Drop me a message if you need more help.
Posted on Jul 27, 2009
  • fivepoint136 Mar 16, 2012
    One of da needles clog up n it broke. Bt GTA needle, same thing
Idles fine,,push pedal and it dies
Idles FINE but stalls when pedal is pressed - Yamaha Rhino Forum ...
www.rhinoforums.net > ... > Technical > Engine
Feb 6, 2012 - 9 posts - ‎5 authors it starts fine but stalls when I press the gas pedal. what do I need to check now. Sponsored Links. RhinoForums.net is the premier Yamaha Rhino UTV/ATV Forum on the internet. Registered ... Does it seem to Idle smoothly and does it start right back up after it dies? Does it .... astro push accelerator and dies.
Oct 07, 2015 | ATVs
Starts dies
You should have the mass air flow meter checked also have the throttle body checked the idle air control valve is there.
Jan 18, 2014 | Volkswagen Cars & Trucks
1999 FLHT idles nice but dies when you move throttle
Remove the carb and clean. Dirty Jets. Idle jet is fine.
Jun 30, 2013 | Motorcycles
So my snowmobile will not start without putting gas in the carb or starting fluid
Try to give it throttle as soon as it starts, hold it about half until the engine runs at a high rpm. Then keep doing that until it idles fine. You might have to adjust the idle and mixture screws. Good Luck!!
Feb 26, 2013 | Yamaha Motorcycles
Cherokee will not start until i hold down on the gas as soon as i take foot off it dies immediatly
Might have to reset the codes on the computer. Take the + battery cable off the battery and reconnect it afer 5 minutes. Next try to start the engine without holding the gas petal down, it should start and run rought till the computer resets itself. If engine stops, restart the engine and hold the gas petal down and give it enought gas so it will run smooth, it may take 5 minutes or so for it to smooth out and run at idle speed. If this did not fix the problem, check for a vaccum hose that may be off some where on the engine
Sep 05, 2011 | 2000 Jeep Cherokee
I have an 1989 4.3 it wont start unless i press the gas pedal down. then once it is started it idles fine but as soon as you put it into gear and try to give it throttle it dies, but if i am lucky enough...
Change the gas filter if you havn't already done so. It sounds like fuel restriction to me or perhaps a faulty fuel pump or cheap gas has blocked the gas filter. Hope this helps! Good luck!
Aug 03, 2010 | 1988 Chevrolet S-10
Rough idle, dies when trying to give it gas
it'll either be your ignition system (spark plugs, distributor cap, etc) or more likely your fuel system (most likely your fuel pump or your fuel filter)
Sep 09, 2009 | 1996 Nissan Altima
Quad 47 cc / 49 cc Pocket Mini Bike Scooter  Atv Pull Start Logo
509 people viewed this question
Top Quad Cycling Experts
shaun taylor
Eric Hidle
Level 1 Expert
Are you a Quad Cycling Expert? Answer questions, earn points and help others
