Have Samsung HL-R4667W TV. after power off for 10 secs., could not get tv to come on, as it was not on all day, could it have been a power surge? Is there a reset? The tv does click, and fan runs, and lamp seems to be lit, but dark gray screen with no sound. What part could be the problem after a a power surge? I order a lamp anyway Nick
  • 6 more comments
  • thechiaros Jul 27, 2009
    Did not answer my questions. I did all the obvious things. Again, is there a reset? If a power surge is possible with the tv off, what
    could have failed? NICK
    PLEASE answer my questions if you can. NICK
    Review my other comments, and try to get tech answers to my questions, NICK
    Lee, I just want to know how a reboot of the power can cause the lamp circuits to be affected. Is there a reset or breaker circuit? How come the lamp seems to be on? why no sound? The lamp
    assembly has a switch and pc board marked 'protection circuit'. Can this be the problem? NICK
    Thanks for new answers. I was a repairman a few years ago before high tech. The 'lamp' light is blinking, but the remote has no effect. The lamp and fan seem to be working. It may be the low
    rectifier circuits. I have to pull the plug to get the tv off. If it was a power surge, how does it affect
    a turned off tv? NICK
    Ben, The tv is only 4 years old, I've replaced the lamp once, 18 months ago. NICK
    Thanks to all
    Thanks to all
  • 3,037 Answers
The lamp may be the problem, but I would like to know if there are any blinking lights on the front of the unit as these will indicate an error code. Sometimes replacing the Horizontal Output Transistor(HOT) repairs the problem you are describing. However you have to take into consideration how old the set is and if the flyback transformer is the problem that caused a short in the first place, then it may be better to just get a new tv as many parts are prone to fail on these older sets. Let me know what you find.
Benjamin
Posted on Jul 27, 2009
  • Benjamin Patri
    Benjamin Patri Jul 27, 2009
    Is the lamp light blinking a pattern at all? Count the number of times it blinks.
  • Benjamin Patri
    The protection circuit would get activated if there was a power surge, look for burned out components on it
  • 4,472 Answers
So your power went out then the tv would not come back on? First off have you tried unplugging it for like 30-60 minutes. Have you tried other inputs to make sure its not that input. No menu's come up? These tv's have problems with the whole ballast and light engine assembly can be bad. It is not worth it to spend the money on these parts, as You can purchase a new tv with a brand new warranty. I would even return the bulb if you purchased it and put it towards the purchase of a new tv. The price of TV's has come down considerably. You can get one of comparable size LCD for under a 1000$. You can also sell your tv for parts as I am sure there are people that could use them based on the amount of issues there are. Your tv uses an older assembly that was switched to a philips assembly that also had bulbs that didn't cost so much. If you really want to fix it you can change all these parts but unless your doing it yourself then you will definitely just want to get a new tv because paying a repair man is not worth it by any means for this tv.
If you have any other questions or need further assistance please let me know.
Thank you,
Lee
  • Lee A.
    Lee A. Jul 27, 2009
    Well there isn't anything they can tell you to fix that I haven't so I hope you will reconsider that once you see their solutions you return to accept mine. Because I have recommended your options and let you know which one is the best for your time and money.
    Thank you,
    Lee
  • Lee A.
    Lee A. Jul 27, 2009
    As I said, either your ballast or the light engine assembly has failed. Either way it is not worth the repair. It is how old of a tv, the parts are relatively expensive and the tv could break again in 2 weeks because of other worn components in the tv. Yes the power surge could have definitely caused this. I am not sure what else your looking for I hope you will reconsider and accept my answer.
    Thank you for using fixya,
    Lee
  • 10,865 Answers
Begin with some obvious things that can fix simple problems. Unplug the projection television and then plug it back in again. Check the outlet to make sure it's receiving power. Make sure the cable to the television is fully connected. Ensure there’s clear air flow around the television and that it isn’t overheating. If you’re still having trouble, move on to your owner’s manual. If you can't find your owner's manual, don't panic, just type the brand name of your televison into an Internet search engine. Most manufacturers have digital copies of owners manuals online, so you can print out a new one. You may need the model number of your television to get the right manual, which you should find just above its serial number on the back of the cabinet.
The owners' manuals for projection televisions list common problems and their fixes in the back. Work through the list, one test at a time, to try and narrow down the problem. When you're troubleshooting, the key is to try one thing and see if it works, then undo the change and move on to the next item.
The most common problem with projectors is a burned-out bulb, either the light source used for rear projectors or one of the red, green and blue bulbs used in older front projectors. You'll often need to order replacement bulbs from the manufacturer, but you can try searching for online stores that offer these bulbs at a discount.
Hl-r4667w/hl Bought the tv 2005 and just started a buzzing noise
Buzzing noise on that model is usually caused by a fan or the color wheel.
May 18, 2012 | Samsung HL-R4667W Rear Projection...
My lamp burned out and I got the replacecent lamp from samsungparts.com, but the housing didnt fit into the tv. So I put the new lamp in the old housing, after verifying the lamp was the correct part...
According to an aftermarket lamp manufacturer, there are 2 different lamps (1st and 2nd generations) available for the Samsung HL-R4667W, but only one of them will actually fit. The lamp that is commonly associated with this model, BP96-00826A, is used in housing that has a silver bump protruding from the opposite side as the front face of the bulb itself. The other type, BP96-01073A, is placed in a housing that has a smooth back face and a overall larger bulb. I can verify that the HL-R4667W that I own seems to have the second type of lamp.
As long as you didn't open the housing of the lamp that you purchased to try to install the lamp in the housing that your TV came with, you might still be able to request an exchange from samsungparts.com, given the circumstances.
Jan 11, 2011 | Samsung HL-R4667W Rear Projection...
Green vertical lines,minor. flashing goodback ground pic good sound . i have samsung dlp tv model hl-r4667w
the lines are from the vertical control, theres a minor short on the vertical board if not fixed the power supply will short and whole tv will go green call repair shop and get short fixed
Jun 11, 2010 | Samsung DLP HL-P5663W 56" TV
My Samsung HL-R4667W rear projection tv turns off -- has sound but no picture. You then have to turn the tv completely off, wait a few minutes, then it will come back on with picture and sound. It may...
Lamp or Lamp Fan For replacement Lamps Call Mats Electronics 1-800-628-1118
for other Parts/Boards Call Encompass Parts Distrubtion 1-800-638-3328
Replace Lamp!
Mar 02, 2010 | Samsung HL-R4667W Rear Projection...
No picture on my Samsung HL-R4667W TV.
Its your Lamp if you have sound and no picture.
CK the lamp Fan make sure it is running.
Lamps Prices depend on where you buy.$85.00 up to $300.00 Look on E-Bay under Electronics/ Lamp number-BP
Mats Electronics has them for $99.00
1-800-628-1118
remove your Lamp and look in middle of it,that will tell you if it is busted.
Feb 20, 2010 | Samsung HL-R4667W Rear Projection...
Picture is scrambled after power surge. Have a
Check if it has a scrambled image on all sources ie - DVD- VCR - cable/satellite box. Since the PIP is normal it sounds like the signal source is bad.
Post back with more info about your set up (what's hooked to your TV) if you need more info
Nov 28, 2009 | Samsung HL-R4667W Rear Projection...
Samsung DLP TV HL-R4667W. When turned on, the TV comes on normally. Within about 10 - 20 seconds, the screen goes blank, can hear the sound for another couple of seconds, then can hear a relay trip, and...
Those lights flashing mean the lamp is the issue. You need to test it with a meter. If the lamp tests ok then it may be the ballast is bad and that is what powers the lamp.
Oct 12, 2017 | Televison & Video
Samsung hl-r4667w needs power cord reset to turn on
How much was it moved? It could have jiggled something loose or made an intermittent connection, try removing the bulb/lamp and put it back in to reseat it, it might be detecting a lamp issue due to a bad connection, or a lamp thats starting to fail, if you have a spare lamp you can try replacing it. If thats not it then it may just be something is failing due to age/heat in the tv and moving it caused enough shock to the part to go intermittent. Most commonly when a projection tv does this its a problem with the lamp, or the power supply board.
Jan 02, 2018 | Samsung HL-R4667W Rear Projection...
Televison & Video Logo
42 people viewed this question
Top Televison & Video Experts
