Question about RCA R52WH73 Projection Television
My RCA TV model D52W17 powers on and goes off
Ok my rca tv model number d52w17 powers on then goes off itll do this like 3 times by its self and wont do anything for like 2 or 3 mins before itll let you try and turn it on again and i also can hear it power on like it normally does
premtech
  • 934 Answers
SOURCE: RCA D52W17 ANTENNA/CABLE ANALOG INPUT
That is an ITC222 chassis and one of the more dependable RCA units built. The "F" connector is the part you're referring to and it's not something that carries a specific part number for that unit. In the shop here we simply buy them by the box and the tuner will have to be removed to install a new connector. The new one will be soldered to the chassis of the tuner and less likely to break in the future. Not something you probably want to do yourself, but at least you'll know what to ask the shop when you're calling around for estimates.
Posted on Nov 05, 2007
SOURCE: RCA D52W17 won't stay on.
Need to find a small circet board for my RCA D52W17 TV my remote doesnt work not any remotes work any more and the problem is the small circet board
Posted on Jun 19, 2008
Slinteriors
  • 8617 Answers
SOURCE: tv wont turn on
try replacing the flyback 259296 and CP150 both items are available at the following link with free instructions.
http://servicemanuals.vstore.ca/
Posted on Dec 20, 2008
  • 5 Answers
SOURCE: My rca tv d52w17 won't turn on.
Sounds like a faulty power inverter to me.
If it's covered under warranty, take it back to where you got it and ask them to cover the warranty for you.
If it's not under warranty, take it to a local electronics repair store that deals with TVs. Get a quote from them on the amount to repair it.
If it exceeds a third the amount you paid for the TV in the first place (ie if the TV cost you $1,200 and the bill exceeds $400) you're better off to get a new TV.
Posted on Apr 19, 2009
ladywinn
  • 5138 Answers
SOURCE: RCA D52W17 wont come on, the green power light
On deflection board CK capacitor cp 150 2200uf 16v use 25v if i is puffed up on top it is Bad replace 2 more caps in same circuit cp114 cp120 220uf 35v for parts call Mats 1-800-628-1118
Posted on Nov 12, 2009
How do I fix the red color on my RCA D52W17 HDTV ? Everything is real clear on the TV but I only get blue and yellow colors, I don't seem to get red. How do I fix this????
if your supplying an RGB signal to this set from a cable or sat box and not using its built in digital tuner id check the connections of the "R" (red) cable input this might have come disconnected
Sep 23, 2015 | RCA Televison & Video
I have a RCA D52W17 rear projection T.V. When I turned the power on the green light flashed 3 times then shut off and now it won't go on at all.
Hi
Thanks for using FixYa. 3 blinks in your RCA D52W17 rear projection are caused due to 3 capacitors (CP114, 120 and 150) which are located on the deflection board. If any of these capacitors goes bad you’ll have to replace them with the exact same ones. Please do rate the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Jun 21, 2010 | RCA D52W19 52" Rear Projection Television
RCA D52W17 wont come on, the green power light goes on and off three times then stays off.
Nov 12, 2009 | RCA D52W19 52" Rear Projection Television
Green light comes on 3 times but tv will not come on
You probably have capacitors defective in the power supply circuit.
Aug 09, 2009 | RCA HD52W59 HDTV Projection Television
Tv wont turn on
Dec 20, 2008 | RCA D52W19 52" Rear Projection Television
are you looking for this part?
http://www.partstore.com/Part/Thomson/RCA/264658/New.aspx?ModelMfgName=Thomson&ModelBrandName=RCA&ModelNumber=D52W17BYX1
if so, just make sure your model number is on the listed devices.
Nov 11, 2008 | RCA D52W23 52" HDTV CRT TV
RCA MODEK D52W17 Cant Get Any Remotes To Work This TV
The remote receiver in the TV is failed. It is possible that a TV repair shop might be able to fix the problem for you
Jun 18, 2008 | RCA HD52W58 52" TV
Possiblility include bad convergence cuircit. A component that is overheating and bad solder connections.. Technicians can use special equipment to read error codes... this will tell them the error that is shutting it down
Mar 13, 2008 | RCA D52W19 52" Rear Projection Television
RCA R52WH73 Projection Television Logo
228 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Computer Repairing
Computer Repairing
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
