Question about KitchenAid Superba Architect KSCS25INSS Side by Side Refrigerator
My Kitchenaid Freestanding Icemaker Model KUIS15NRHB9 won't stop making ice when it reaches thermostat?
catriver
  • 878 Answers
SOURCE: My subZero Model 245 Icemaker stopped making ice
Ice maker, I don't know where you can find the manual but I'll give you a few ideas of what to look for. First make sure that the inlet tube is not frozen over. Next, look at the center gear on the module and see if the clips in the center are not broken. If so you will have to replace the module. The ejector blades should be at the 2:00 position when home. If you get a jumper wire and jump T to H, this will by pass the bi-metal and run a cycle. The ice maker should fill at around the 12:00 position. Test points L & N will verify if you have 120v to the ice-maker. Test points L & H will test the resistance of the heater, 72 ohms. plus or minus 10%. Hope this gets you going, Catriver...post back.
Posted on Aug 21, 2006
watugot
  • 290 Answers
SOURCE: icemaker want stop making ice
The quick answer is to turn the water off to the refrigerator so it quits making until you get it fixed.
If your fridge has the control boards in each side of the freezer cabinet that controls the icemaker, then you have a failed board.
If you have a standard icemaker with the metal shutoff arm then you have a failed motor module in the icemaker.
You can remove the icemaker and unplug the wiring connector from it so you can leave the water on to the dispenser.
Post back if you need instructions on reparing it.
Posted on Oct 25, 2007
  • 109 Answers
SOURCE: ice maker
verify the water supply to the valve first, second verify valve to icemaker works(unit has dual valve at rear bottom of fridge, switch plugs, then press water dispenser and see if icemaker fill with water ) if fills icemaker is bad , if not valve is bad. replace one or the other.
Posted on Mar 28, 2008
SOURCE: kitchenaid superba icemaker leaking/freezing in freezer section
Thank you, I am going to go check right now
Posted on Nov 09, 2008
mark_37388
  • 100 Answers
SOURCE: kitchenaid ice maker not making ice
first check the tube running to the ice maker where the water flows in see if it is frozen if not take the cover off the ice maker front and see if the little tabs in the middle of the gear is broken there are two one might be broken off
Posted on Mar 30, 2009
Makes too much ice
check to see if bin thermistor is plugged in and if it is good . should be about 1100 ohms when at room temp
Jan 23, 2014 | KitchenAid Architect Series II 15" 51-Lb....
Refrigerator model kscs25inssoo. Don't stop filling ice box in the door
you have a problem with the optics--if you look on the inside wall of the freezer section on the left side you will see a eye with a flipper on the left is another eye with the icemaker on off selection when ice reaches that level in the bin it cuts off a laser beam that runs from one side to another which stops power to the icemaker---clean both sets right and left eyes and unplug the fridge for 2min this will reset the optics--if problem still persists you will need new optics-part#-4389102
Mar 27, 2012 | KitchenAid Refrigerators
Ice cube tray won't stop making ice.
This is due to the arm that controls the switch on the icemaker itself either being shorted or froozen in the toggled position. Usually the arm would lift as your ice container becomes full and shut the icemaker off until it reached a level where the switch would then toggle to the make ice position and then start makeing ice again. There are three 1/4" screws that hold the icemaker in place remove these screws unplug the icemaker and then use hot water to dethaw your ice maker for about 2-4 minutes after wards dry the icemaker then try reinstalling the icemaker if the problem persists replace the icemaker itself. If you have any further questions message me back I await your reply.
Thank you
Rick
Mar 12, 2012 | Refrigerators
I have a KitchenAid SxS model # KSRG25FTST01 with an icemaker problem. It stopped making ice, but the water still dispenses. It makes no noise and no water in the ice tray. I never hear it try to fill with...
If the thermostat behind the left side of the fill tray goes bad, the cycle will stop completely. Cost of thermostat is $20.00. Cost of new icemaker with new motor and everything including thermostat is $45.00, brand new, on EBay plus shipping. Cost for new icemaker from repair shop, $153.00 plus tax. Control board circuit panels each side of freezer compartment will go bad also stopping the ice maker cycle. these control boards come in pairs, one for each side of freezer compartment. Cost for new circuit panel control board from repair shop, $215.00. Cost from EBay brand new circuit control board $45.00 plus $8.00 shipping. Easy to install both, icemaker and control board circuit panels. Phillips screw driver and small socket set is all you need for removing and installing these items.
Jan 22, 2011 | KitchenAid KSRS25IL Side by Side...
ICEMAKER HAS NO WATER IN IT AND ICE STRIPPER NOT MOVING BUT WATER DISPENSER WORKS KITCHENAID SUPERBA MODEL #KSCS23INBL00 SIDE BY SIDE WITH ICE AND WATER DISPENSER IN DOOR
First check to make sure the icemaker is on. Most icemakers have what looks like a wire that extends to the right. Down is on, up is off. If yours does not have this, there might be an on off switch on the icemaker itself. If the wire (bale) is on, or the switch is on, then the icemaker is defective, unless the freezer is too warm. Icemakers have a thermostat in them that will not let them operate if the freezer is too warm. Sometimes that thermostat will not activate until the freezer is 15 degrees.
Mar 03, 2010 | KitchenAid Superba Architect KSCS25INSS...
No water to ice maker
It will only call for water when the thermostat is satisfied. Now if you advance the icemaker when the ejector blade reaches 10 oclock thats when it should call for water. If you dont here the valve humming then it would be in the water switch inside the icemaker.Also make sure the thermostat is not set too cold. if its too cold it will never satisfy your control.
Manually advance : remove the cover on icemaker then turn the small gear counter clockwise
Oct 04, 2009 | U-Line Icemaker
Takes long time to make ice then stops
What is the model number of your unit? Some of the icemaker is designed to harvest when the thermostat is cycles. So every 1/2 hr on some and longer on others. If you have a BI series then make sure the thermostat is set to a warmer temperature. That way the thermostat will be satisfied.(counterclockwise). Listen for the compressor to cycle off. When that happens then the icemaker should harvest. If not then the thermostat could be bad. If its a different model then Let me know and I can try to help you thru that.
Jul 30, 2009 | U-Line Icemaker
Ice maker
By manually moving the ejector blades you have now broken the ice maker module. (The brain and the motor of the icemaker). Kitchenaid had a batch of thermostats that arent working properly in these Indoor ice makers. I reccommend getting an entire new IDIM icemaker. You will have the improved module whith stronger gears (however you still cannot manually move them) and the improved thermostat.
Nov 24, 2007 | KitchenAid Superba Architect KSCS25INSS...
KitchenAid Superba Architect KSCS25INSS Side by Side Refrigerator Logo
136 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
vince
geob91
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
