Question about Sony Cyber-shot DSC-W55 Digital Camera
I have two DSC-W55s
I have two DSC-W55.
One with a broken screen.
One with a lens that is stuck half in and half out.
Which one is easiest to fix (with parts from the second) and can you give me instructions on how to do it.
Thanks
  • warks_mole_m Jul 28, 2009
    I've got to the point where you say there is ribbon connection. I can see 2, one small one and one much larger.
    Do they disconnect from the screnn itself?
    The small one might but the bigger one doesn't look like it comes away from the screen.
    If it doesn't the ribbon disappears around to the front of the camera and can't see where the connection is.
  • 724 Answers
Screen to good lense is easier Find a set of Jewler screw driver you can find these in Job Lot stores or the expensive snapon dealer drive by. Theb proced to remove the bateries and memory sticks. Now the back of the camera that surounds the frame of the screen take great care and remove the small screw. o9nec the back is off the screen should float out and a ribbon cable in a socket snould be found make sure it is a socket and no a hard wire connection it should slip out from this connector block do the same to the other camera and do the swap.
Replace the back makesure everything aligms and do not force the alignment. It should plop together like mustard in the baby's pants
Posted on Jul 27, 2009
  • tommya300
    tommya300 Jul 28, 2009
    50 50 they both remove 10 to 1 the side on the circuit boaud does.
    The ribbon part that is a flat all the way to the connectes area and all you see is a patch that is glued or fastened and just soldered is permanent look at the other end one of the two has to be a connection and not permament just for easer manufacturer production sake for assembly. The part that is plugged in to looks like an edge connector and that is the unit plug that the ribbon plugs into. Hey you are going to be the one to decide. I can not see the camera machanics here. I can only go by what I seen in other camera electronics. You either end up with a 2 in one camera or two pieces of junk.
    I should not have encouraged you by assuming you can recognize a removable part that small. Common scence on your part is 90% of a successful repair. Use a magnifine glass and look closer.
" " lens pops in & out twice & the screen says access then screen says turn power off and on again. Sony Cybershot dsc w55
this problum is related with optic zoom lenz assy its not work propally so thats why screen shows access problum pleae go to your nearst sony service centre & fix the problum or repair optic zoom assy
Feb 05, 2010 | Sony Cyber-shot DSC-W55 Digital Camera
Sony cybershot DSC-W170 lens malfunction
sounds like you have dust, sand of some type stuck in the retracting lense. Ive found someone to tell me to take out my batterys and SD card, then tap the bottom of the camera on a table top. Replace the batteries and power up. Doing this, I was told it loosens up the debri for the lense to retract to close and to open again.
Aug 24, 2009 | Sony Cyber-shot DSC-W55 Digital Camera
Sony dsc w55 lens extend out and in wont take pictures
Hi!
The focus is stuck. Contact your local Sony service center, but if they ask too much, you can contact me at toms.safranovs@gmail.com and I will give you a good price.
I work in Sony service center.
Tom
Jul 10, 2009 | Sony Cyber-shot DSC-W55 Digital Camera
Sony cybershot dsc - w55
the part which comes out when the power is on might have got stuck .. there may be some dust particles. just blow over it or vaccum it..
Dec 26, 2008 | Sony Cyber-Shot DSC-S40 Digital Camera
Sony dsc-w55 fell and the lens is stuck
Use bit more force to push or pull the lens as lens has been damaged. If applying bit more force lens goes to working, u saved $$$ otherwise, new lens option is always available at Sony repair shops.
May 30, 2008 | Sony Cyber-shot DSC-W55 Digital Camera
Dropped Sony Cyber-Shot DSC-W55
use the rechargeable battery and charge it for 8hrs.turn of the LCD,put the mode in auto.I do no exactly about the lens problem, you try this press the lens lightly and then twist it lightly with your fingers.
Dec 31, 2007 | Sony Cyber-shot DSC-W55 Digital Camera
Sony Cyber-shot  DSC-W55 Digital Camera Logo
80 people viewed this question
Top Sony Cameras Experts
james laughton
james laughton
JonSnell Electronic
JonSnell Electronic
Are you a Sony Camera Expert? Answer questions, earn points and help others
