Question about Yard Machines 158cc Push Lawn Mower #11a 034f200
Replacing the pull rope
Rope came off the pully, got the rope back on but now it wint wind up after pulling it to start
    Champion:
  • 363 Answers
The solution to this one is very tricky. You have to remove the shroud to access the inside of the spring return. Pull the rope out but make sure it is still attached to the spindle check to see if the return spring has broken. If it is then it will have to be replaced.
Posted on Jul 28, 2009
How do I replace the pull cord on snapper sr1330 riding mower
remove coil cap look at the rope pulley pull old rope forward till you get to end knot hold pully pull not out with the rest of the rope then wind pulley up till it wont go any farther back off one turn alighning the cover hole with pully hole use ascrew driver stuck between the slot on cover and pulley ten get your rope take a lighter and burn the end of the rope the take a rag pul the end of burt end of the rope shuold leave a pointed rope then take rope and stick through pully hole then the housing make the rope about 70 iches long it will be to long i no but just do it tie a knot in tend on the back of pully take lighter and heat it still it melts a very little the knot that is pull rope on through pulley hold rope remove screw driver slowly let rope wind up on pulley still it stops you will have rope sticking out reistall pulley cap then put handle on rope put handle all the way down to cap pull rope one turn push handel down to cap atie a knot in rope as close to to handel as possible heat not like the other end cut rope with 1/2 inch of rope sticking out of knot
Sep 13, 2014 | Snapper Garden
Lawn mower rope pully repair
if rope to long then pull out recoil one turn hold rope tight pull knot out of handle down rope rope to were you are holding it tie a knot in rope slowly let rope go back in recoil then pull it all the way out should fit now cut off excess rope but also if you have a long rope it is suppose to mount on handle should be a mount hook for on the handle
Sep 05, 2014 | Garden
Cub Cadet has broken pull cord
pull off cap first from engine look inside it pull the rest of the cord out to the end then grab the not onthe pully while holding it pull the rope out after that wind pully all thee way up shuve a new cord throug houseing pully then slowly let rewind up until it stops cut the rope 6 inchs in front of cap hole restall cap to motor slip your starter rope threw grip that you pull pullthe cord attached to handle out two feet hold onto rope cut handle loose slip[ and tie handle again to the houseing rope dont let go of the rope after that let it rewind back up done
Sep 04, 2013 | Garden
How do you take the outer shell off the engine of my Poulan 446 T pole saw/weedeater. I need to replace the pull cord. Also, how to properly install a new pull cord. Thank you. Don
I do not have knolage of how to take off the cover but I have replaced start cords on other saws. There is a hole in the pully you put the rope through and then tie a knot it it so it won't pull out.Usually there is a half circle in the edge of the pulley you place the rope in so you can wind up the spring but not take up the rope. You will need to count the turns the pulley makes when the rope is pulled out then add one or two more turns so the rope is pulled in snug. Then you take the rope out of the notch and let it coil up nomally.
Aug 03, 2013 | Garden
How to fit new starter cord
remove recoil cut off old rope take new rope burn end till pointy push threw recoil and into hole in pulley tie knot on pully side add handle pull string between pully and outer shell rotate pully counterclockwise 4 times with rope you puled from out in between pull access back out of the housing till tight release or go to a shop they normally only charge ten bucks
Mar 05, 2013 | Makita DPC6410 64cc 12" Power Cutter
How to replace pull string on honda 5hp pressure washer?
you will need to remove the flywheel shroud and turn it over so you can see the pully, remove the old rope then wind the pully against the spring tension until it stops, then clamp it with a c-clamp then take the new rope and feed it through the pully into the knot hole and tie a knot on the end release the clamp and let the rope rewind into the pully(slowly) until it can't fit anymore then pull a little bit back out then cut it off there and reinstall the handle then tie a knot on this end and reassemble the shroud back onto the engine...good luck
ps this also works on any small engines)
Apr 03, 2010 | Karcher 2500 PSI Pressure Washer
Lawnmower rope pull start, has rewound back into housing and locked? How can I get it to release so that I can reconnect it to the lawnmower handle?
You will have to take the top off.It has 3 bolts on the sides of the motor.Pull top off,hopefull you just have pull rope out to fix.The rope on the pully has a spring in the bottom of the pully.Do not pull out pully,you will have a hard time gettig it back in.
Aug 29, 2009 | Craftsman Garden
Replace starter cord, briggs & stratton 6.5 MTD mower
my rope broke to lol. i have bought new roape and have reinstalled it. u have to take top of the mower apart. the plastic cover take it off all the way a few bolts u can see un do them. pull off the plastic cover and take gas cap off so it will come off. next u will see 2 bolts on the fron of the mower on the rope houseing. un do them. next behind the mower 2 more bolts. u will see them it holds the rope houseing unit in place. after u unbolt both it will come of easy. next ull see when u tip it upside down a bolt with flat head bolt. use a socket or falt head undo that. next pull out the pully that the rope gose around. install new rope threw hole in rope houseing and threw the rope pully. ull see a srping on the rope pully. its hard for me to get it to wind all the way back up so all i did was roll up the rope best i could and reinstall the pully. titen flat head bolt back in place and reinstall all bolts and plastic cover. it should work now.
Jun 21, 2009 | Troy Bilt 5.5hp Self Propelled Mower
Yard Machines 158cc Push Lawn Mower #11a 034f200 Logo
302 people viewed this question
Top Yard Machines Garden Experts
dannydoesita
Phil Walker
Phil Walker
Dean Gruber
Are you a Yard Machines Garden Expert? Answer questions, earn points and help others
