Question about Car Audio & Video
Have 2003 monte carlo aux input cutting out
Have 2003 monte carlo with an aux input just started cutting in and out works sometimes but dosen't on other times also if i remove factory stereo will it affect any of the car systmems like the alarm?
    Problem Solver:
  • 8 Answers
If the radio itself works all the time then you probably have a bad connection between the aux device and the radio. It could be a cable, or it could be the jack. Depending on that it is in easy fix or a harder one. You can take it to a place that installs car stereo equipment and have them look at it or just tackle it yourself. If you put in an aftermarket radio you will need a wiring harness and possibly an antenna adapter. Sometimes you need other things that interface between the car and the harness as well such as controls for steering wheel remotes and other special items.
Posted on Jul 29, 2009
My 1996 monte carlo has started cutting out, stalling and i did not run out of gas
what size engine? any repairs lately to the engine? when does it stall? freeway speeds, around town or at lights?
Jan 24, 2013 | 2003 Chevrolet Monte Carlo
Think the ignition switch is bad on my 2003 monte carlo
bad starter hold key on and have someone hold test light on small wire on starter or tap on starter with hammer when it acts up to verify 2 person job
Jan 03, 2013 | 2003 Chevrolet Monte Carlo
2003 monte carlo does not start
need to narrow down to electrical or fuel management --when no start is fuel pump working ---has the ignition system been tested or starter when no start
Jul 08, 2017 | 2003 Chevrolet Monte Carlo
My rear defogger doesn''t work on 2003 monte carlo
check the wires where they connect and plug in on both corners of rear window...sometimes they break off and lose contact ....they can be reglued on using a special glue that will conduct electrical current through it...can be found at most auto parts srores...good luck....Lee
Feb 19, 2012 | Chevrolet Monte Carlo Cars & Trucks
2003 chevy monte carlo security light came on and now car wont start
does it have the v.a.t.s. system...a chip in the key? sometimes the little resistor in the key goes bad..if you have a spare key try it
Feb 08, 2011 | 2003 Chevrolet Monte Carlo
Ingition key will not turn 2003 chevy monte carlo
WD-40 Put key in the ignition, RAP while trying to turn. Also get a new key cut by code. Maybe your key is worn
Mar 26, 2010 | 2003 Chevrolet Monte Carlo
My 2003 monte carlo wont start after maybe 30 mins of driving
please be more specific --- will not start after ???
Dec 11, 2009 | 2003 Chevrolet Monte Carlo
98 Monte carlo Z/34 cranks immediately then cuts
start by check ignition module(controls spark) do fuel pressure check to see if pressure within specs
Oct 20, 2009 | 1998 Chevrolet Monte Carlo
Have a 2003 Monte Carlo SS. Usually happens when I first start the car. The cruise control light comes on in dashboard at the same time the air, heat and defrost won't work. After a few minutes everything...
most of the newer cars especially the new chevys are all ran off the bcm or body control module, i would have someone with a snap-on brand tester check to bcm and the parts of your car first to make sure what is all wrong, could just be a shorted wire or a broken vacuum hose
Jun 26, 2009 | 2003 Chevrolet Monte Carlo
2003 Monte Carlo losing power
I would try going to one of your local auto parts places first and ask them to hook up a codes scanner and see if there are any codes. If so, which ones and fix the first code first. That will usually fix any other codes as well.
Kenneth Triest
Jul 30, 2008 | 2003 Chevrolet Monte Carlo
Car Audio & Video Logo
199 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
