Ref Rotel RA-930AX Stereo integrated amplifier. There is no output from the right speaker channel. I have gone through the process of elimination by swapping speakers and cables around and checking all sources i.e. CD, Tuner, Aux and Tape and established that the source of the problem lies with the amplifier. Can this be fixed by repairing or replacing some internal component within the amplifier?
  • martinlennon Jul 27, 2009
    I was after a more technical answer than the one I got. Being an electrician myself, my natural curiosity had me wondering if it could be fixed D.I.Y. with a little background information from somebody who can point me in the right direction in what to look for inside the amplifier.
    Top Expert:
  • Audio Player... Master
  • 76,109 Answers
Replace the large power output transistor, it is on a heat sink at back of unit, use only OEM part, the bias of most aftermarket "generic" replacements will not work and leaves you chasing your tail.
Posted on Jul 27, 2009
  • 10,865 Answers
Hello Martin. You have taken the correct steps so far. Good for you. Now that you have isolated the problem, take the amplifier to a reputable repair shop and get a free estimate on a repair. After they give you a price tell them what u have already done and offer them half of what they are asking since you already isolated the problem for them and saved them all that time. Good luck with it.
HALLO I HAVE A ROTEL RA 9858X AND AGTER PLAYING FOR A FEW MINUTES I LOSE THE RIGHT SPEAKER CHANEL
Try interchanging the speakers. If the right channel works, you have a problem with your speaker.
Jun 14, 2014 | Rotel Audio Players & Recorders
Tip
REPAIR ASSISTANCE
ROTEL RA 980BX
Fault: No output from left channel. The right channel is working fine.
Added some photos and circuit for reference
While testing the amp noticed that the left channel is giving switch on off thump while powering ON and OFF the amplifier. It happens when there is DC voltage flow through the speakers. It shouldn't be there. And the thump is there only on the left channel. While testing the amplifier section found that all the transistors where idling at mentioned voltage. All Base pins where around +/- 0.5volt. and the output is almost 0.012mvdc.
FOR MORE DETAILS CHECK THE LINKS
http://electro-medical.blogspot.in/search/label/ELECTRO%20MED%20SERVICES
on May 17, 2015 | Miscellaneous
Integrated amplifier for Mordaunt-Short Avant 908i
Use an amplifier with NO MORE than 150 Watts per channel or you be buying new speakers. At this power level don't expect booming bass boost without damaging the speakers. The Rotel generates 130 per side which is very near the safe maximum for those speakers... and the specs look good. If you are not satified with the sound, the speakers are LIKELY the problem. Look at getting good commercial speaakers instead of CONSUMER grade speakers. Go to a music store dealing with bands and musicians and view the products they have to offer. Consumer speakers often fail when people turn up too much bass. At high listening levels hearing damage can result.
Aug 02, 2012 | Audio Players & Recorders
Rotel processor bypass for Audio Research SP10
If I understand you, the 'sound' of the AR preamp is what you're trying to preserve. Presumably you're just running a phono through it as nothing else needs a preamp these days.
The multichannel inputs bypass all of the Rotel's processing except the volume. Use the Front L and R.
Mar 12, 2010 | Audio Players & Recorders
Need manual for ra 840bx4 & wattage output when remote speakers?
Lets try the simple stuff first. This whole problem could be caused by a dirty switch contact. Pick up some electronics cleaner from a local electronics shop and spray the switch (from the inside of the unit). Work the switch on/off a number of times then respray one more time. That should clean out any dirt that is there. Try the unit again and hopefully the problem is resolved. If not, then the switch itself may need to be replaced. When you get the cleaner, get one that contains a lubricant as well. This will help to prevent the problem from coming back again.
Dan
Jun 20, 2009 | Rotel Audio Players & Recorders
No Left Output
check stereo settings after that if it still persists your left channel is goin out
May 21, 2009 | Audio Players & Recorders
Rotel power amp
some amps have a switch to bridge them rather than wiring a bridge meaning output is mono check to see if yours has this switch if you do simply put back to stereo
May 20, 2009 | Rotel RMB-1095 Power Amplifier
Help with my power amplifier
This sounds like there is a problem with the final output stage. Is this a new amp? Is it under warranty?
Dan
Oct 08, 2008 | Rotel RMB-1095 Power Amplifier
Distortion in one channel
your right output component (transistor or integrated circuit needs to be replaced)
Nov 11, 2007 | Alesis RA-150 Amplifier
Rotel RA 9808X Amplifier
I'd suspect that one of the two output transistors on that channel has gone bad. If you are unsure how to test or troubleshoot this, then you might try replace both the NPN and PNP outputs and catch the bad one that way. If your amp uses an output module then you would of course have to replace the module which would replace all the output transistors on both channels. Good luck. Another thing to look out for, is the emitter bias resistors. They are the large white ceramic ones near the outputs. Sometimes one of those will open up too. They will be of a very small resistance value like .5 ohms (point five ohms) or something in that general ballpark, and have a wattage value of typicaly 5 watts. So they are pretty big resistors. Be sure to check them all even if you do find a bad output transistor. They will often go out with the transistor. Good luck.
Jan 18, 2007 | Rotel RMB-1095 Power Amplifier
174 people viewed this question
 Grubhead
Grubhead
