Question about Toshiba Satellite A135-S2276 Notebook
My computer will not turn on. when i plug in cahrger the light comes on but power button not doing anything.
  • 724 Answers
Is there sign of voltage comimng out of the supply the Green lite is only sign that is it pluged in the wall Primaty side of the transformer. You need to see if that output secondary has juice.
Posted on Jul 27, 2009
  • 126 Answers
Disconnect the charger and remove the battery. Wait 10 seconds, then reconnect both battery and charger. also, let it charge for 5 minutes before you try the power button again.
Please make sure that you see the power/recharge light on your laptop. Let me know if you need further help.
How comewhen I turn it on i don't here anything
have u plugged the power cord,
one thing if the light does not turn on, then how do u say u turn on,ok it got it,
check for the power cord,then if no result try another speaker
good day
Jun 01, 2010 | HP JBL Platinum Computer Speakers
Dell inspiron 1300 does not switch on
try unseating and reseating the memory one stick at a time in each slot one at a time and try turning on the laptop after each stick reinsertion.
If this doesn't do it then take out the hard drive and dvd drive then turn on ht laptop.
If after all of these steps you still don't get video then the motherboard is bad.
Aug 08, 2009 | Dell Inspiron 1300 Notebook
HI I have a dell Vostro 1510.There is a problem with my system since yesterday .when I have connected my latop to the cahrger My laptop swiched off .And I am never again able to restart it.Later observed...
dear,
did u check the charger itself...its important ...
if you have multimeter then unplug the charger from laptop and plug the mains from socket to th charger plug and check the output DC voltage..is it coming, if coming then is it constant or varing ...if varing then u have to check the charger inside by an expert...
if its ok then remove the battery of the laptop and plug the main to charger and charger to laptop and then check its performance by switching on laptop...if its work then battery issue....
Aug 03, 2009 | Dell Vostro 1510 Motherboard System Board...
Getting power but wont boot up or anything
pull out everything in the computer except what's required to boot...so any pci cards or video cards (if you have onboard video). you can also try pulling out the ram (while unpowered AND unplugged) and then booting to hear beeps...if you pull the ram out and the computer doesnt make a sound, its probably a bad motherboard and needs to be replaced. if you hear beeps, try replacing the ram or disconnecting other parts...like harddrives, optical drives, modems and what not.
Apr 26, 2009 | E-Machines T2792 PC Desktop
Blinking lights
this means your printer wast pad is full this is now oyu reset your printer but make sure you have put new pads in 1st and dont for get to rate plz
  1. Turn off the printer power and unplug the power cord from the wall. Disconnect the computer interface cable at the back of the printer.
  2. After one minute reattach the power plug to the wall, but don’t reattach the computer cable.
  3. Hold down the ROLL and the PAPER ADVANCE buttons simultaneously.
  4. Turn the printer on. after 2 blinks, all the ink lights come on, then release the buttons being held down.
  5. Press and hold the ROLL button for 10 seconds.
  6. Release the ROLL button and the printer will initialize, which resets the Waste Ink Pad Counter.
  7. Once initialization is complete, turn the printer power off.
  8. Reconnect the interface cable.
  9. Turn the printer on and print a document.
Sep 11, 2008 | Epson Stylus 2200 InkJet Photo Printer
Power/charging from wall cahrger
Either a bad charger with a weak/short in the end of the cable or the plug port in the laptop needs re soldered/replaced..
May 18, 2008 | Gateway MT6705 Notebook
Monitor won't come on
Lets start with the basics. Does the monitor have power, do you get a light on the monitor when you try to turn it on? If you do then do you get any lights on the computer when you try to turn it on? If the monitor has no lights on it check the power connections and if still no lights then try plugging it into a different outlet preferably directly into the wall. If still nothing then the monitor is bad. If the computer has no lights but the monitor does once again try plugging it in to a different outlet and if that does not work there is a problem with the computer most likely the power supply, CPU, or motherboard. If both have lights but you get no display on the monitor then check the connection between the monitor and the computer. if the connection is good (I would ***** in the screws on the sides of the connectors just to make sure there is a good connection) then there could be a problem with your video card.
Mar 12, 2008 | Computers & Internet
Won't come out of "power saver mode"!! PLS HELP
before anything else... just try to check or diagnose if your video card is not defective..and you try also to use another computer to connect to identify the problem...
Jan 28, 2008 | LG Flatron L1710M 17" LCD Monitor
Stuck in sleep mode
Press the power button on the Computer it should come out of sleep mode then if it doesn't hold the power button of the computer down until the system turns completely off.
Then turn back on the computer should now boot fine. Once in windows goto control panel and select power option then adjust the setting.
Hope this helps you
Cheers J
Jan 05, 2008 | Dell Dimension 5100 (D51L1) PC Desktop
Toshiba Satellite A135-S2276 Notebook Logo
151 people viewed this question
Top Toshiba Computers & Internet Experts
k24674
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
