Question about Health & Beauty
I have new batteries, how do i disassemble to replace?
  • dfur26 Jul 27, 2009
    panasonic ES7008
  • 57 Answers
There should be an slide open on either the side or the bottom. then just simply insert the new ones and through the old ones away
Posted on Jul 28, 2009
How to fix lithium battery got wet
The battery cells inside lithium ion batteries (and other types of batteries) tend to corrode if they become wet for a given period of time. They need to be dried out immediately to avoid corrosion. Unfortunately, it seems like it is too late to dry out yours. Your battery will need to be carefully disassembled using procedures on fixya and the corroded cells replaced with similar quality cells. The cells in Ryobi batteries are spotted welded in place and these welds need to be broken carefully using a Stanley knife. Replace the cell(s) with new ones or from other disassembled batteries and solder them in place. Check for cell voltage imbalance (see other solutions on fixya) and reassemble. Good quality Panasonic Li Ion cells can be purchased for about $4 each on ebay. If you go this route, I would recommend replacing all cells, not just the corroded ones.
May 13, 2014 | Ryobi Two 18V Lithium-Ion Batteries +...
Remington pg200 groomer disassembly
This is a very simple repair.
To disassemble, twist the round bottom part (with the battery contacts) counterclockwise just a bit. Use jaw pliers if it won't twist with your hands alone. To protect the plastic finish of the groomer use some duct tape or a rag on the jaws. Gently twist and open the assembly. When separating the bottom part, take care not to pull it apart too far from the main assembly to avoid damaging the 2 thin wires connecting the bottom plate on the inside of the bottom charger to the main body of the groomer. The batteries will just slide out easily; they are not soldered or attached in any way. You can replace the batteries with any two standard AAA rechargeable NiMH batteries (1.2 volt).
Since the batteries are so easy to access, and there is no solder involved, in a pinch you can even use regular AAA Alkaline batteries! (but, of course, NEVER USE THE CHARGER WITH NON-RECHARGEABLE BATTERIES!!)
The groomer is now as good as new!
Dec 08, 2012 | Remington Precision Deluxe PG-200 Beard...
Need to replace battery door.
i have not replaced the battery door but have disassembled an S5000 following the service manual
it looks like once you complete the first step 'Removing the R CABINET ASSY' you can withdraw the hinge pin and replace the battery cover without any more disassembly [see attached image]
Nov 29, 2011 | Fuji FinePix S5000 Digital Camera
Remington Electric Shaver..How do I disassemble a Model XLR 900. 8BF2-1C. I want to replace the battery.
Unfortunately these rechargeable razors are not designed to be easily serviced by the home user.
Changing the battery will definitely involve a bit of searching for the multiple screws which hold the case together and then disassembling the case to access the battery compartment. Just watch out for any screws which may be hiding under the rubber padding pieces. You will then likely be required to desolder the old battery out and then resolder your new battery back into place.
Here is a link to a site which describes the various methods for disassembling battery powered shavers:
http://k0lee.com/2008/04/replacing-remington-and-norelco-shaver-batteries/
Here is a link to a replacement battery available for your model:
http://www.batteryweb.com/cordlessrazordetail.cfm?ID=238
Just use your mouse to click on the link, which is the underlined and highlighted text just above. This will open a new web browser page automatically for you and allow you to view the information and items at the website indicated.
Thank you very much and good luck.
May 14, 2011 | Health & Beauty
How do you replace a battery on a Braun 7680 Shaver?
I replace my Bruan 7680 battery. I place the order for battery from Amazon, cutter& foil from goodmans.net. The following is my procedure 1.Using a small flat screw driver to plier the plastic socket lock (Where the charging located ) 2.Disassemble left and right plastic holder 3.Disassemble plastic cover top and bottom 4.Take out the circuit board where the battery mounted on. Please be careful at this process you could ruin the circuit board while taking the old battery out(I used a soldering and a small wood stick just to take the extra flux away from contact to other on the circuit board).It is not as difficult as I thought. 5.During your install a new battery please make sure that the batter pole does not go the same way(Check direction of a battery before taking it out so you do not put in the wrong direction) 6.Putting them back together. Note #special tool required to take out the circuit board from a mounting?My the battery replacement came with the tool)
Apr 19, 2011 | Braun Activator 8595 Electric Shaver
Braun 7526 needs new rechargable battery
You will find batteries for model 7526 at shaveroutlet.com. See link below
http://shaveroutlet.com/shaver-replacement-parts/shaver-replacement-battery-aa-nimh-p-108.html
Scroll down the page for disassembly video instructions.
For easier replacement, it is suggested that you use a modified installation technique. This is to break the tabs off of the old batteries rather than unsoldering them from the circuit board. This allows the old batteries to be removed but leaves the tabs attached to the circuit board. You can then solder the tabs from the new batteries to the old existing tabs
Feb 21, 2011 | Braun Syncro 7526 Electric Shaver
My remote control has stopped working ,i have tried new batteries but it not work
good day... well you said you already replace w/ new battery..try to check the batt. terminals if still intact...if you can disassemble it to clearly check the wires.. if still good I suggest that you replace the infra red LED...goodluck
Feb 12, 2011 | Abt Television 1745 Remote Control
Locating the cmos battery in a toshiba satellite m45-s165
If you have disassembled your toshiba unit, and you are somewhat new in electronics, you cannot see the battery similar to other PC, bcoz its battery is somewhat soldered, and the only things you migt notice is its two colored wire (black and red) attached to a round, flat, insulated (wrapped with insulation) battery.
Dec 17, 2007 | Toshiba Satellite M45-S165 Notebook
Health & Beauty Logo
523 people viewed this question
Top Health & Beauty Experts
Robin Hill
Robin Hill
wcdoc1953
wcdoc1953
Are you a Health and Beauty Expert? Answer questions, earn points and help others
