Question about HP DeskJet 9800 InkJet Printer
HP Deskjet 9800 will not power up. Tried replacing power cord and tried plugging into a different power outlet. The little green light on the back of the power supply unit comes on, but the printer will not turn on.
  • 724 Answers
Is there power coming out from the supply end
Is is a DC or and AC output supply?
If is it an AC output supply tyhebm in the back of the HP had an AC to DC converted that is realy a diode bridge and should contain a fuse in the circuit somewhere on that board
Posted on Jul 27, 2009
How to turn on hp 3600
Unplug the power cord from any surge protector, extension cable, or power strip, press the power button on the printer several times. Plug the power cord directly into a wall outlet.
Feb 21, 2015 | HP DeskJet 3650 InkJet Printer
My hp f4280 printer don't have power to on.
hi misssim31, if the printer is not turning on..there might be a possibility that the power module is already faulty. if the power module light is lit up (the green light on it) try to plug the cord into different wall outlet and if it didn't worked..change the power cord and the module..and still if it didn't worked then the port on the back of the printer where you plugged the power cord is no longer working.
if you have any further question..dont hesitate to reply..
thanks
May 29, 2011 | HP DeskJet F4280 All In One Printer InkJet
I have a HP Deskjet D1560, and with the power cord plugged into a working outlet (I checked), the printer won't turn on. Is it just old? Is something wrong with the power cord or the printer?
There is only one way to find out if it is an issue with the printer or the Power cord.
Normally every HP printer has 2 parts. One cord connects the Printer to an Adapter. the Adapter cord then connects to the Wall outlet.
Now that you have connected the printer to working outlet, Check after 10-15 mins if the Adapter ( black box ) is warm or cold. If the Adapter is warm and the green LED light on adapter is glowing, then it could an issue with the Cord or the Printer.
Try with another Adapter or power cord to diagnose.
Regards,
Shawn
May 07, 2011 | HP D1560 Deskjet Printer InkJet
HP 2015dn paper jam light remains on; no paper jam
What is "cold" reset? Have you tried pulling the power cord out of the back of the PRINTER, wait one minute, and plug it back in. Wait another minute - that should do it.
Jul 09, 2010 | HP DeskJet F380 All-In-One Printer
Hp deskjet 940c - all 3 light are blinking
Check this page...
http://h10025.www1.hp.com/ewfrf/wc/document?docname=bpd09170&cc=us&lc=en&dlc=en&product=59129
"Here's what it says is the solution for all 3 lights blinking.
  1. Turn the printer off. Unplug the power cord from the back of the printer. Unplug the power cord from the wall outlet.
  2. Wait 30 seconds. Plug in the power cord to the wall outlet. Plug in the power cord to the back of the printer.
  3. Turn the printer on.
If you have completed all of the steps listed above and are still experiencing a problem, service your product."
Dec 23, 2009 | HP DeskJet 940c InkJet Printer
Pc won't power ( turn on)
The green light is most likely your lan card/port. If the cord/outlet are sparking when you plug it in, I would say try plugging something else into that socket, if you get the same spark, I'd call an electrician. Also try plugging the pc into a different outlet. As far as the computer, if its not the outlet then it is the power supply, your motherboard may be fried in the process but if this isn't an issue with that outlet, then you should take it in to a shop.
Mar 16, 2009 | HP Pavilion a450n PC Desktop
Plugged in and no lights come on
It usually means that the power supply has failed. Perhaps while transporting it, something came loose inside. At any rate, you'll probably need to replace it. Service on inkjet printers isn't cost effective.
Feb 22, 2009 | HP DeskJet 920c InkJet Printer
Power loss to HP Deskjet 9800
I think you blew it when the power source switched. When you try to power it up and don't get any lights, that usually means that the power supply in the printer is shot. Sorry. You might try getting warranty service on it.
Nov 30, 2008 | HP DeskJet 9800 InkJet Printer
Zvonko jelusic from belgrade
The print carriage is stuck.
Solution
  1. Open the top access door on the printer.
  2. Remove the print cartridges.
  3. Close the print cartridge flaps after removing the print cartridges.
  4. Turn the printer off and then on again.
  5. Replace the print cartridges.
  6. Close the top access door.
If the resume light continues to blink after the print cartridges are released,
OR
the print carriage is stuck or makes a grinding noise, follow these steps.
Solution
  1. Lift the top cover to the printer.
  2. Turn the printer off and then on again.
  3. Unplug the power cord from the back of the printer when the grinding noise starts. Unplug the power cord from the wall outlet.
  4. Move the print carriage towards the middle of the printer (this procedure may take a couple of tries to get the timing correct).
  5. Take out the print cartridges and close the top cover.
  6. Plug the power cord into the wall outlet. Plug the power cord into the back of the printer.
  7. Open the top cover, reinstall the print cartridges, and then close the top cover
Solution
  1. Open the top cover.
  2. Unplug the power cord from the back of the printer. Unplug the power cord from the wall outlet. Wait a minute or so.
  3. Plug the power cord into the back of the printer. Plug the power cord into the wall outlet
Sep 22, 2008 | HP DeskJet 5550 InkJet Printer
Hp laserjet 1020 meltdown
Try this out:
Some printers require time to turn on. These printers may or may not give feedback in the form of blinking light(s). Wait up to a minute for the power light to come on before proceeding with the steps below. Instructions If the printer uses a power adapter (module), follow the instructions below. If the printer uses only a power cord, see the section below entitled “ If the printer uses only a power cord .” If the printer uses a power module Follow the steps below to ensure power is properly supplied to the printer:
  1. Check the power module part number against the part number listed in the User’s Guide to ensure the proper power adapter is being used.
  2. Disconnect the power cord or adapter from the wall outlet.
  3. Disconnect the printer data cable from the printer.
  4. Disconnect the power cord from the printer, wait thirty seconds, then reconnect the power cord to the printer.
  5. Disconnect the power cord from the power module and reconnect the power cord to the power module. This may not be necessary if the power module has a permanently attached power cord.
  6. Reconnect the power cord directly into a working wall outlet. If the power cord was plugged into a surge protector or power strip, plug the power cord directly into a wall outlet instead. NOTE: "The HP Photosmart 8100, 8400, and HP Deskjet 6000 series printer power cords feature a green LED built into the power plug. If the LED is not glowing, the power module may have failed. Proceed to step 7 below.
  7. If the printer still will not turn on or the power LED built into the power cord is not glowing, plug the printer into a wall outlet in another room. If the printer or power LED turns on when connected to an electrical outlet in another room, there is a problem with the power in the original room.
  8. If there is still no power to the printer, then the power module, cord, or printer may be defective. Try the power module/cord on another HP Deskjet or Photosmart printer, of the same model if possible, to see if the power module is functioning. If the power LED is still not glowing, the power module may be defective. Replace the power module and cord.
  9. If the power module/cord works on the other printer, then this printer is defective. Service your printer.
  10. If you cannot determine whether the problem is the printer or the power module/cord, or if another printer is not available to test with, replace the power module/cord first. If this does not resolve the issue, service your printer.
If the printer uses only power cord Follow the steps below to ensure power is properly supplied to the printer:
  2. Disconnect the power cord from the wall outlet.
  5. Reconnect the power cord directly into a working wall outlet. If the power cord was plugged into a surge protector or power strip, plug the power cord directly into a wall outlet instead.
  6. If the printer still will not turn on, plug the printer into a wall outlet in another room. If the printer turn on when connected to an electrical outlet in another room, there is a problem with the power in the original room.
  7. If there is still no power to the printer, then the power cord or printer may be defective. Try the power cord on another HP Deskjet or Photosmart printer to see if the power cord is functioning.
  8. If the power cord does not work on the other printer, it is defective. Replace the power cord.
  9. If the power cord works on the other printer, then this printer is defective. Service your printer.
  10. If another printer is not available to test with, carefully inspect the power cord for damage.
  11. Inspect the power cord for visible damage. If the power cord is damaged, replace the power cord first. If this does not resolve the issue, or if the power cord looks fine, then service your printer.
Goodluck,
Dont forget to rate me as fixya..
Jan 30, 2008 | HP LaserJet 1020 Printer
HP DeskJet 9800 InkJet Printer Logo
1,164 people viewed this question
Seeker5211
Seeker5211
