Question about Dometic Rooftop RV Air Conditioner
Dometic Quick Cool compressor freezing and evaporator coil
My Dometic Quick Cool compressor is freezing and evaporator coil was frozen. I allowed the unit to completely thaw. Once it thawed it worked great but after 45min. the unit was frozen. Does this mean the unit is low on freon? If so, since it's a sealed unit - how would you charge it?
Also, does it take R22 or 134?
Your help is greatly apprieciated.
  • 4 Answers
Could be low. First check air filter, air flow, and evap coil to see if it has restricted airflow. If all seems well, its probably low. The specs will tell you what type and how much refigerant. To access system, you will need a gauge/manifold set, refrigerant, and a piercing or line tap valve for the low pressure side of the system. Of course, first, you need to locate and repair the refrigerant leak.
Posted on Jul 27, 2009
Frozen compressor
A frozen compressor can be caused by several things. One cause could be partial loss of refrigerant or being over charged by someone adding to the factory charge. Another cause for a frozen compressor might be poor heat transfer in the evaporator, which is where the cool air comes from. This is usually systematic of a dirty evaporator or poor air flow coming from the fan. Another cause for a frozen compressor is the system not turning off when it should. This problem is usually a result of a bad thermostat or the thermostat not turning off soon enough.
JohnL
Apr 19, 2016 | Dometic Rooftop RV Air Conditioner
P3ra-048k uses what type of refrigerant and manufacture charging chart
This sounds like a trick question. Are you a service man? You must know HVAC well if you know sub cooling! There is a tech info plate on the unit that tells you how much and what type of refrigerant. Check the fan direction and if indeed it is running at all. If its icing up back to the compressor is the condenser fan running? Make sure you thaw it completely before trying to recharge it. Also check for plugged filter dryer, and as a last resort see if it has a plugged or incorrectly sized orifice or TXV. Charge by superheat method.
Jul 15, 2014 | Intertherm P3RA-030K Air Conditioner
I meant the AC does not cool
Make sure the mode is set to freeze and temperature is set to below the room temperature.
If it is a split system, check the outdoor unit whether it is running. If it is running, see if you can reach and feel the temperature of the pipes connecting between the indoor and the outdoor unit. It should be cool.
If it is not cool, you may need to get somebody to check the refrigerant.
May 22, 2014 | Dometic 57915531 Air Conditioner
RF265AARSXAC The freezer is not freezing.
looks as evaporator fan is working. have you ever clean condensor under the fridge. possibility it is pluged with dust and not allowing compressor to cool down.
Also check the fan at the back of the fridge beside the compressor. see if it is working
Nov 14, 2013 | Samsung RF265AA Bottom Freezer French Door...
Magic chef freezer model mcuf88w won't freeze
When you thawed it, did you remove ice from it using a metal object. That may have damaged the coils when would allow freon to leak out. This is too coincidental to be a problem itself with the compressor. The t'stat might be the problem. Try turning it off at the t'stat for a few minutes, then turn back on to the normal setting. Keep door closed for 30 minutes and check the inside and see if the walls are freezing. If not, you may have a compressor problem, or t'stat, or relay switch problem.
Feb 04, 2013 | Magic Chef Freezer. 8.8 cu. ft. Upright...
Coils freeze up. completely blocked. have to shut off to thaw coils. located in basement.
After the unit is totally thawed and dried, turn the unit Off if you haven't already and unplug it. Remove the filter and clean it. If it's really dirty wash it with warm water and dish washing liquid, thoroughly rinse it and allow it to completely dry, before reinstalling. DO NOT operate the unit without the filter in place.
Because the air temperature in a basement is colder at floor level, than at shoulder level, this caused the coils to freeze. Dehumidifiers do not work well at temperatures at or below 60 degrees F. That is, unless, it's a Low Temperature model, designed especially for basement applications. Obviously, yours isn't a Low Temp model.
To overcome this, place the unit up on a sturdy table, counter top, etc, that can handle the weight of the unit, as well as a full bucket of water. The higher off the floor the better. This way, the ambient operational temperature will be higher and the coils will have less of chance to freeze again.
I would suggest that continue to monitor the unit and if you notice that it's doing more than a little frosting on the coils, turn the unit OFF immediately. A little frosting is normal and the deforst mode should kick in and thaw the coils. When this happens, the compressor should automatically shut OFF, but the fan will continue to run. Once it's defrosted, the compressor will start again, if necessary.
I hope this helped you to troubleshoot and solve the problem. Please let me know.
Jul 19, 2011 | Whirlpool AD50DSL Dehumidifier
Freezer quit freezing ice cream Thur night, but everything else was fine, not everything is starting a slow thaw
either the ptc overload relay on the compressor is bad and the compressors not operating to cool the unit or the evaporator coil behind the freezers inside wall is iced up and cant let cold air out due to this blockagethen its a defrost heater/thermostat on the evaporator coil issue
Jul 02, 2011 | Kenmore Side by Side Refrigerator
Does not cool, cleaned coils, eveporator has frost, lights dim frquently in trailer, is this the compressor not running.
If the evaporator has frost on it, the compressor is running. The problem is, when there is frost or ice on the coil the air cannot pass through the coil, and therefore you have maybe some or no cold air. First, you will need to make sure the evap. is thawed out completely. You will probably have to turn the unit off for a couple of hours. When it is thawed, turn it back on. You are probably low on refrigerant. If you have the proper tools and a set of guages, you can do this your self . If not it's best to take it to a technician so they can check the refrigerant level. Hope this helps you.
Jun 22, 2011 | Dometic Rooftop RV Air Conditioner
Dometic Rooftop RV Air Conditioner Logo
436 people viewed this question
Top Dometic Heating & Cooling Experts
Bill Long
Tim Whalen
Dan Webster
Dan Webster
Are you a Dometic Heating and Cooling Expert? Answer questions, earn points and help others
