I HAVE A 15MF400T/37 HAS LINES IN PICTUR AND BAD VIDEO.I REPLACED MAIN BOARD SAME PROBLEM.
  • 3,037 Answers
Are the lines vertical or horizontal or a mix of both? And are they, thick or thin and just a couple or many lines? Thanks
Benjamin
Posted on Jul 27, 2009
VIZIO E43 C2 DROPED NOW LINES ALL OVER PICTUR
I hate to give you bad news but I have a feeling your screen is bad from it falling, you can try unhooking the flat cables that go to the Tcon and panel and reseat them along with the cable going from the Tcon to the main and see if that helps
Nov 09, 2017 | Vizio Televison & Video
Rca 42 led42c45rq triad flashlight test there is pictur and oudio backlight tern on for a second than tern of I sand you pictur of my tv with ID #:25970867 that you give me
Contact any service technician; or the authorized service center. If you wish to get some details; check the site linked here. Surf the site with patience. Pull up older posts. http://electronicshelponline.blogspot.com/ . In most cases, the main board might have to be replaced. If so, a software [firmware] update too might be necessary. Fault to its main board. Short circuited component/s at it.
Nov 21, 2015 | RCA Televison & Video
Magnavox 15mf400t 37
Check the other sources first - AV, scart, hdmi, etc. If you get the same result your main AV board needs replacing or repairing.
Jun 17, 2013 | Televison & Video
"I have a rarely used Magnavox 15MF400T/37 Series
first, make sure the Tv is correctly plugged into the wall. You can try another outlet. If that doesn't work, then your Tv is certainly having a power problem.
The issue you describe is consistent with a power supply board issue. This is the board where the AC goes to. This problem may have occurred as a result of irregular power supply, or excess power supply or power surge.
The TV is receiving current but cannot circulate or transfer the current to other necessary part of the TV because of the defective power supply board. You might be lucky it's just a blow fuse. Also a defective transformer can cause your TV not to power on.
All these can be checked on the power supply board.......
But more often bad capacitors causes problem on the power supply board. I do not think the power board needs replacement, rather those defective capacitors is causing this issue. Open unit up and take a look at the power supply board.You will probably see one or more electrolytic filter capacitors that are bulged up in the top-not perfectly flat like the others.
The value of these capacitors will be different, most likely they will be somewhere around-820 to 2200uF/25 V( or /10V sometimes).
You can replace them with same values but I would recommend the voltage rating to be higher(like 35V for an original 25V) for reliability purposes.
What happens is,these bulged top capacitors will cause a low and unfiltered DC voltage=main board will malfunction(the relay will keep clicking until the caps are holding enough charge to bring the voltage up over a threshold point).
You can buy these capacitors at any Fry's or Radioshack store or you can order them online at vendors like "mcmelectronics.com"(look for electrolytic capacitors). After replacing these capacitor(capacitors) most likely the normal operation will be restored. Or you can by a refurbished complete power board to save you some stress.......
Note: There may be also some other causes for this symptom ,like a defective T con board ,or main board,but the bulged top capacitors are the most common cause for this issue.
If you don't know about TV repairers, take the TV to the nearest repairman to fix the fault for you. Also, note that TV stores a lot of current, so wait a while before opening the TV back cover.
Yours sincerely.
Elect_Comp.
May 15, 2011 | Televison & Video
WHITE DISTORTED SCREEN
U Main Tuner signal board is dead.Replaced the Main Tuner board will solved this problems.Picture was white distorts,he should of replaced the Main Tuner board.The T-con control board only replaced when u have power to tv,but no video.When have any kind of video on the tv all it way cause by Main Tuner signal board.
Mar 17, 2010 | Televison & Video
LVM-37w1 Westinghouse T.V. pictures goes nuts, is the the lcd converter board?
If you getting a lot of vertical lines, double picture, it can be the LCD panel driver board, or worst case will be the LCD panel, very expensive.
Nov 17, 2009 | Westinghouse LVM-37w1 37 in. HD-Ready LCD...
Tv turns on but pictur has lines through it?
If the lines are verticle,it could be a bad control board/data ribbon that connects to pdp panel. if they are horizontal lines,it could be the y boards (main for power, buffer upper and lower control half of the panel each) if not,replace swollen capacitors on the power board.
Oct 04, 2009 | Philips 42PF7320A 42 in. Plasma HDTV
Philips Magnavox 37" LCD Flat Screen 37MF331D Have replaced power board,main board,hit power a faint light on whole screen for about 2 seconds the nothing.
Disconnect the LVDS Cable that runs from the small signal board to the display panel and apply power,if the screen comes on,the Small signal board (aka Scaler Bd ) is the faulty board. other than that,all that's really left that has gone bad for me is the logic board.
Feb 19, 2009 | Toymax Magnavox 37MF331D 37 in. LCD TV
Televison & Video Logo
13 people viewed this question
Top Televison & Video Experts
Electro Med Services...
