Color only blue ,yellow,black and gray - Televison & Video
  • mforrest45 Jul 27, 2009
    colors are only blue ,yellow,black,and gray,color comes back briefly
    rca 1996 50 inch t.v. chassis number ptk178la color comes in yellow. blue and black ,picture is sharp&clear,true colors return briefly
  • 4,234 Answers
I would be first looking for poor solder connections with a set of this age. There is a possibility that some components are defective as well, but usually poor solder connections are the culprit. IF you can solder, you can attempt the repair yourself. Realize that there are potentially dangerous high voltages present inside the set even when unplugged.
Look for solder connections that appear grainy or have rings and resolder them. Concentrate in the areas close to heatsinks. Be specially careful around the flyback transformer (part with large red wire going to the picture tube). This is the source of the high voltage and the tubes store it up so there is a shock danger there. Again carefully resolder any and all solder joints that are not "shiny" and that should resolve the problem.
If not, then try to see if there is a pattern to when the set works correctly and for how long. These will be clues to the defective part.
Thanks,
Dan
Posted on Jul 27, 2009
  • 10,865 Answers
Begin with some obvious things that can fix simple problems. Unplug the projection television and then plug it back in again. Check the outlet to make sure it's receiving power. Make sure the cable to the television is fully connected. Ensure there’s clear air flow around the television and that it isn’t overheating. If you’re still having trouble, move on to your owner’s manual.
If you can't find your owner's manual, don't panic, just type the brand name of your televison into an Internet search engine. Most manufacturers have digital copies of owners manuals online, so you can print out a new one. You may need the model number of your television to get the right manual, which you should find just above its serial number on the back of the cabinet.
The owners' manuals for projection televisions list common problems and their fixes in the back. Work through the list, one test at a time, to try and narrow down the problem. When you're troubleshooting, the key is to try one thing and see if it works, then undo the change and move on to the next item.
If the owner's manual doesn't offer a useful fix, try looking in online forums for information about your TV. chances are good that other people have encountered the same issue you have with your projection TV, and they may have a solution for the problem.
The most common problem with projectors is a burned-out bulb, either the light source used for rear projectors or one of the red, green and blue bulbs used in older front projectors. You'll often need to order replacement bulbs from the manufacturer, but you can try searching for online stores that offer these bulbs at a discount.
If the picture is blurry or the colors smear, it's usually a sign that the projectors are out of alignment. You can often fix this yourself using on-screen menus that calibrate your television. Projectors should be adjusted any time the set is moved and about once a month to make sure you're getting the best picture possible.
  • 11,896 Answers
Color wheel may need to be replaced. It is fairly easy project.
Danco instructions
Umm, yeah I think so....
Nov 10, 2013 | Danco Home
Pioneer KEH-8031ZT connection diagram of power and speakers
There are two kinds of pioneer color codes:
pre 1999
P o w e r Memory (+12v Constant) Orange Ignition (+12v Switched) Red Ground (-) Black Illumination Yellow Phone Mute Yellow/Black Power Antenna Blue S p e a k e r s Right Front (+) Gray Right Front (-) Gray/Black Left Front (+) Green Left Front (-) Green/Black Right Rear (+) Gray/Red Right Rear (-) Black/Gray Left Rear (+) Green/Red Left Rear (-) Black/Green
and 2000 or newer
Memory / Constant 12V(+) Yellow Switch / Accessory Red Ground Black Illumination Orange/White Antenna Remote Blue Amp Remote Blue/White Left Front (+) White Left Front (-) White/Black Right Front (+) Grey Right Front (-) Grey/Black Left Rear (+) Green Left Rear (-) Green/Black Right Rear (+) Violet Right Rear (-) Violet/Black headunitwh.gif
Jul 01, 2011 | Car Audio & Video
What color are the wires on a 1992 eagle talon to hook up my new stereo.for example.what color is the speaker wires,left front r front left rear right rear.thank you
Here you go.
1990-92 Eagle Talon Stereo Wiring Constant 12V+ Red/Black Switched 12V+ Blue Ground Chassis Illumination Green/White Dimmer Black/Yellow Antenna Trigger White/Black Antenna Left Rear Front Speakers 4" Dash Left Front (+) White/Blue Left Front (-) Black/Blue Right Front (+) White/Red Right Front (-) Black/Red Rear Speakers 6 1/2" Side Panels Left Rear (+) Yellow/Blue Left Rear (-) Gray/Blue Right Rear (+) Yellow/Red Right Rear (-) Gray/Red
Jan 16, 2011 | 1992 Eagle Talon
I need the stock wire diagram that connects to the car stereo for a 2000 honda civic
2000 HONDA CIVIC FACTORY RADIO WIRE COLORS
BATTERY WHITE/BLUE
ACCESSORY YELLOW/RED
GROUND BLACK
ILLUMINATION RED/BLACK
LEFT FRONT SPEAKER BLUE/GREEN(+) GRAY/BLACK(-)
RIGHT FRONT SPEAKER RED/GREEN(+) BROWN/BLACK(-)
LEFT REAR SPEAKER BLUE/YELLOW(+) GRAY/WHITE(-)
RIGHT REAR SPEAKER RED/YELLOW (+) BROWN/WHITE(-)
Oct 10, 2010 | Car Audio & Video
I need to know what each color means on the existing radio stereo wires please... 1999 chev silverado.
I think this is the right table, but I don't know if it will display right. If not, go to http://www.installdr.com/InstallDocs/GM/PDF/460005.pdf
Typical GM Factory Typical New Radio
Pin What It Is In Dash Wire Color Equivalent Wire Color
A Left Front Spkr (-) Light Gray White w/ Black Stripe
B Left Front Spkr (+) Tan White
C Right Front Spkr (-) Light Green Gray w/ Black Stripe
D Right Front Spkr (+) Dark Green Gray
E Ground Wire Black Black
F Not Used
G Headlight Dimmer Wire Gray Orange (if available)
H Power Antenna Turn On Pink Blue
I +12 Volt Ignition Wire Yellow Red
J +12 Volt Battery Wire Orange Yellow
K Right Rear Spkr (-) Light Blue Purple w/ Black Stripe
L Right Rear Spkr (+) Dark Blue Purple
M Left Rear Spkr (-) Yellow Green w/ Black Stripe
N Left Rear Spkr (+) Brown Green
Sep 06, 2010 | 1999 Chevrolet Silverado 1500
What is the color code for the wires to the factory radio for a chevy malibu 2004
1989-1990 And Newer
AS VIEWED FROM MATING END OF CONNECTOR
A B C D E F G H I J
K L M N
F Not Used
H Power Antenna Turn On Pink (if available) Blue
Smaller sized
Mar 07, 2010 | 2004 Chevrolet Malibu
I hav a 95 berrta and im tying to put a head unit
Hello chrisuftring,
Here's a link to the wiring color code for the '95 Chevy Beretta.
You'll need to match the function of each wire from your head unit and the color code for that would be in your manual. Most aftermarket units are somewhat standard as far as power, accessory, ground, and speaker connections are concerned. But the wiring colors may be different for such leads as remote, power antenna, illumination, dimmer, and muting.
An Alpine head unit has the following wiring colors:
Blue - Power Antenna
Blue/White - Remote
Pink/Black - Audio Interrupt (muting)
Orange - Illumination
Red- Switched 12V+
Yellow - Constant 12V+
Black - Ground
Gray - RF Speaker (+)
Gray/Black - RF Speaker (-)
White - LF Speaker (+)
White/Black LF Speaker (-)
Violet - RR Speaker (+)
Violet/Black RR Speaker (-)
Green - LR Speaker (+)
Green/Black - LR Speaker (-)
With this head unit, you would wire Yellow to Orange, Red to Yellow, Black to Black, Orange to Gray, Blue to Pink, Gray to Light Green, Gray/Black to Dark Green, White to Tan, White/Black to Gray, Violet to Dark Blue, Violet/Black to Light Blue, Green to Brown, and Green/Black to Yellow.
Note that there are 2 "yellow" wires in your vehicle color code. You'll have to test them to determine which one is the accessory wire and which one goes to the left rear speaker. Using a 12V "test light" is the simplest. Connect one side of the light to ground. With the ignition ON probe the yellow wires. One of them should light the tester, the other one won't. Verify that the light goes out when the ignition is OFF and your have separated the redundant "yellows". The one that lit the tester is your 12V+ switched wire and the other one goes to the left rear speaker.
Hope this helps.
Sep 11, 2009 | Dual Car Audio & Video
Suburu radio wire harness. trying to match up with a new soni deck
Hello uze7, Here is the wiring match up for a 2009 Subaru Forester using the Metra 70-7552 wiring harness: NOTE: The actual harness will be listed as a Nissan harness, but has been used by Subaru since 2007. Also, I'm assuming that your Sony deck uses the standard color code. If not, you should have a manual that lists the function along with the colors. Match the wiring by function, not by color (although the colors may be the same). 2009 Subaru Forester Radio Wiring Color Code: Battery BLUE/RED (+) RADIO HARNESS Accessory YELLOW/RED (+) RADIO HARNESS Ground BLACK (-) RADIO HARNESS Illumination VIOLET (+) RADIO HARNESS Dimmer BLACK/WHITE (-) RADIO HARNESS Power Antenna YELLOW/BLACK (+) RADIO HARNESS LF Speaker (+) BROWN LF Speaker (-) BROWN/WHITE RF Speaker (+) BLUE/WHITE RF Speaker (-) BLUE/YELLOW LR Speaker (+) WHITE/BLACK LR Speaker (-) RED/YELLOW RR Speaker (+) GRAY RR Speaker (-) GRAY/RED Metra Harness: Yellow ? 12V Constant Red ? 12V Accessory Black - Ground Orange ? Dash Light Dimmer/Illumination Green ? Left Rear Speaker (+) Green/Black - Left Rear Speaker (-) White ? Left Front Speaker (+) White/Black ? Left Front Speaker (-) Purple ? Right Rear Speaker (+) Purple/Black - Right Rear Speaker (-) Gray ? Right Front Speaker (+) Gray/Black - Right Front Speaker (-) Standard CEA Color Code: Blue - Power Antenna Blue/White - Remote Turn-on Pink/Black - Audio Interrupt In (Phone) Orange - Illumination Red - Ignition (Switched 12V) Yellow - Battery (Constant 12V) Black - Ground Gray - Right Front Speaker (+) Gray/Black - Right Front Speaker (-) White - Left Front Speaker (+) White/Black -Left Front Speaker (-) Violet - Right Rear Speaker (+) Violet/Black - Right Rear Speaker (-) Green - Left Rear Speaker (+) Green/Black - Left Rear Speaker (-) Hope this helps.
Aug 13, 2009 | Car Audio & Video
Color code for 01 acura integra factory stereo wiring harness
Battery BLUE/WHITE (+) RADIO HARNESS
Accesory YELLOW/RED (+) RADIO HARNESS
Illumination RED/BLACK (+) RADIO HARNESS
Power Antenna YELLOW/WHITE (+) RADIO HARNESS
LF Speaker (+) BLUE/GREEN
LF Speaker (-) GRAY/BLACK
RF Speaker (+) RED/GREEN
RF Speaker (-) BROWN/BLACK
LR Speaker (+) BLUE/YELLOW
LR Speaker (-) GRAY/WHITE
RR Speaker (+) RED/YELLOW
RR Speaker (-) BROWN/WHITE
Steering Cntrls NO
Speed Cntrl NO
Radio Security YES
Dec 28, 2008 | Pie Hon03 F/Mm Car Stereo Wiring Harness...
Need free color codes for which wires are what for new stereo
Constant 12V+ Red/Black Switched 12V+ Blue Ground Chassis Illumination Green/White Dimmer Black/Yellow Antenna Trigger White/Black Antenna Right Front Front Speakers 6 1/2" Doors Left Front (+) White/Blue Left Front (-) Black/Blue Right Front (+) White/Red Right Front (-) Black/Red Rear Speakers 6" x 9" Side Panels Left Rear (+) Yellow/Blue Left Rear (-) Gray/Blue Right Rear (+) Yellow/Red Right Rear (-) Gray/Red go to the12volt.com for other wiring questions seems to be a good site
Aug 01, 2008 | 2000 Mitsubishi Montero Sport
Televison & Video Logo
Top Televison & Video Experts
