Question about Konica Minolta Office Equipment & Supplies
We have a customer with a Konica 2125 copier that has a blank LCD screen on the control panel. The print switch will glow orange but will not turn green. The AES, RADF, AES lights are on but you cannot make it zoom up or down or make a copy. The LCD screen is always blank even if you open a side door. We have switched out the following items from a known working machine and still have the same problem. All printed circuit boards in back of machine. All wiring harnesses to all boards and AC wiring harnesses as well. Complete control panel including both door interlock switches. Complete drum/developer unit.Complete fuser unit.Tested exposure lamp and is OK. Checked all grounds in back of machine and all are tight.Complete feed section. Complete exit section. Power cord including noise filter board and circuit breaker. I have worked on office equipment for 18 yrs and cannot figure this one out, can anyone help us in this situation. Lee Osborne 828.327.7777
  • Konica Minolta Master
  • 6,161 Answers
No power.
Solution
PROBABLE CAUSES:
1. The front door interlocks are not actuated. Open the front panel of copier and ensure that (green) handles 1 and 2 are positioned to the far right. Close the
front panel and power ON.
2. F4 (28V DC, 4A) or F5 (5V DC 2.5A) on the copier control board is open. Ensure that there are no 5V DC or 28V DC loads shorting to ground. Repair
shorting condition as necessary. Replace F4 (p/n 963012100) or F5 (p/n 936012300).
Note: If replacing the fuse, see Technical Operations Bulletin #A15, dated 7/24/95.
3. No 5V DC output from the DCPS with all loads disconnected. Check all 5-volt loads for shorting to ground. Repair as necessary. Replace the DCPS (p/n
540084513).
4. Main CB failure. Replace the main CB (p/n 35BE-9010).
OR
Blank LCD.
Solution
PROBABLE CAUSES:
1. Drive pulley (A) (p/n 540076531) slips on the lens motor (M7) shaft, or the timing belt (p/n 540077520) falls off and is lodges between the motor and pulley.
As an interim repair for a slipping drive pulley (A), apply a small amount of instant adhesive between the drive pulley and motor shaft. As a permanent repair,
replace M7 with the new-style (p/n 25BA-7404). The motor must be used with the new-style adjustable drive plate assembly (p/n 5400-6321). In addition,
there is a motor cover mylar (p/n 35AE61990) that prevents M7 from interfering with the door detect wiring cover. The mylar is placed onto the underside of
the motor. These parts can not be mixed with the original parts. They must be used as a set.
Note: For more detail, refer to Parts Information Bulletin #81.
2. The 5V DC to the LCD needs adjustment. Adjust VR1 on the operation board.
Posted on Jul 31, 2009
Konica-Minolta bizhub 215 giving c3451 error message?
Error c3451 is a warm up error meaning the machine has not yet reached the correct temperature within a specific time. To Reset switch machine off using the switch inside the front door, not the one on the control panel. While holding the UTILITY key down on the control panel switch the machine back on keeping the UTILITY key held down. Eventually a Trouble reset key will be displayed in the LCD screen. Tap that, OK will be displayed then turn off the machine and then turn it back on. This will reset the error code, if the code reoccurs then there will be a problem with the fuser unit in the machine, and this will require replacing
Sep 18, 2015 | Konica Minolta bizhub Office Equipment &...
My photocopier machine Konica Minolta, when I power it on, the lights turn on, but the display screen does not, on the start button, the yellow light appears.
Sounds like the LCD or main board has blown a fuse. Look for a small fuse. This may require the machine to be opened up. Contact Konica customer services as this is a common fault with the c250 range
kindregards
Mar 07, 2015 | Konica Minolta Bizhub C253 Copier
How do I fix error code p51 on Konica 3135 copier
P51 means "key switch OPEN", look to the right side check the continuity of the Sw.
Dec 04, 2014 | Konica Minolta Konica 2125 3135 4145...
Blank screen
control panel may need to be replaced have a tech come or it could be a control board, or the firmware is bad.
Jan 28, 2014 | Konica Minolta Office Equipment & Supplies
Konica minolta bizhub c350 c-0500 display
Fuser warm up failure. Most likely this will require a service person to repair but here is the reset procedure you can try yourself. If it does not reset then you will need a service technician.
Turn off the main power switch located on the right side of the copier, NOT the one on the edge of the operation panel. Press and HOLD the utility/counter button on the control panel. While holding this button down continuosly turn on the main power switch. Continue holding the utility counter button until the screen changes to a blank screen with just a box that says "trouble reset". Now release the utility/counter button and touch the trouble reset box. Now turn off the main power switch for a few seconds then turn the machine back on. The code should be gone but if a problem remians then the code will come back within 30 seconds.
Good Luck and Thank You for using Fixya.
Dec 01, 2010 | Konica Minolta DiALTA Di200 Copier
Error konica 2125
Hello sir; On the control panel upper left corner there have a dial turn dial clockwise it will be bright.
Aug 14, 2009 | Konica Minolta Office Equipment & Supplies
We have a customer with a Konica 2125 copier that has a blank LCD screen on the control panel. The print switch will glow orange but will not turn green. The AES, RADF, AES lights are on but you cannot...
FROM KonicaMinolta
Description
Blank LCD.
Solution
PROBABLE CAUSES:
Description
No power.
Solution
PROBABLE CAUSES:
540084513).
Jul 27, 2009 | Konica Minolta Office Equipment & Supplies
Video Underrun
never seen that before I beleive it is the application that you are printing from. try saving it ina different file and printing it (Ms viewer, paint, etc... see if it prints) or try right clicking the picture and go to print picture.
Oct 08, 2008 | Konica Minolta magicolor 2430 DL Laser...
Blank screen, cannot get menu to display, but sound works
Does the lcd screen have a glow to it ? Or is it really dim if u get real close to screen u can see images moving ?
it it has a glow to it you panel lighting is fine but you control board is bad. If you have a dark screen and see faint images you panel back lighting is out u can check the power with a meter at the connection to inverter board on panel.
May 03, 2008 | Televison & Video
82 people viewed this question
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Ben
Ben
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
