My OCE 7050 Copier is displaying Error Code 0810. Any Ideas?
The copier will advance the plan to be copied about 3 in. then it stops and displays error code 0810. I cannot do anything else and have to power off and power on again.
checkitright
  • 1362 Answers
SOURCE: Error code no. E00004-0000
the fuser has a bad
thermistor or
thermofuse or
lamp
Posted on Dec 20, 2007
Bubbabear64
  • 2794 Answers
SOURCE: Error Code SC570 for copier Aficio 1224C
It could be covering the sensor. Clean the fuser oil sensor off and see if it goes away.
Posted on Dec 17, 2008
Cogz
  • 1326 Answers
SOURCE: error code C0070
This could be a easy fix for you. Did you just add a new toner? If so, try this..... Remove the new toner bottle CAREFULLY, mahe sure the hole in the bottle is in the upward position. Once you have removed the bottle, Close the front door and turn the copier OFF then back On. Let the copier come to ready and reinstall the toner agian as it is displayed on the front cover or box. Then close the front door and try to make a copy. It should work for you... If not you most likely have a problem with the toner motor or the home position sensor for the toner bottle. You may have to call a service rep. to handle that problem. Good Luck...
Posted on Jan 24, 2009
SOURCE: Canon COpier NOP 6030 error code E064
hi.... sir
i've an erorr code for copier np 6030 is 064 how to solve it
Posted on Mar 14, 2009
redzventures
  • 149 Answers
SOURCE: IR2270 copier displaied error code E000020-000
It's concerning the toner level in the dev unitor drum unit. Try entering service mode and selecting 'install' this will stir toner and try to feed toner through. Could be a dirty or faulty toner level sensor. Cuuld also be the drum life over - check drum life in the service mode. Check my other posts to see how to enter service mode
Posted on Jul 06, 2009
Hi, oce 3165 machine is giving error 1104,kindly help me get a solution to this
Output OP paper rejection roller drive malfunction.Try to reset the malfunction code to Open/close the front door.If not reset:
Turn OFF the copier.
Press and keep pressed the Utility key and turn On the copier.
Keep pressed the Utility key and wait while Trouble reset message displayed.
Release the Utility key and touch the message.
Turn OFF the copier ,wait 1 minutes and turn ON.
Apr 19, 2013 | OCE 3140 Copier
Error code c-2152
C 2152 : Transfer belt separation.Check the main motor connector for proper connection,check the image transfer pressure/retraction position sensor and clutch.For reset the error turn OFF the copier press and hold pressed the Utility key and turn ON the copier,wait to Trouble reset message appaire on the display and release the utility key and touch the trouble reset ,turn OFF the copier ,wait 1 minutes and turn ON.
Mar 03, 2013 | OCE Office Equipment & Supplies
My AR-5316E copier is displaying this error code H and 4
Your heater lamp maybe busted.
Use the simulation 14 to cancel the error..
If nothing happens then you need to check your heater lamp.
Oct 28, 2009 | Sharp AR-5316 Advanced Digital Imager...
What is error code 06112 ?
oce is a variety of different model of copier send me the picture of your copier then i can tell what model is it and what is the real problem low_toner@yahoo.com
Aug 06, 2009 | OCE Office Equipment & Supplies
Oce7050/error code 2205
what is oce 9400 error code 0813 ?
plase help me??
msmSAS@YAHOO.COM
Dec 20, 2008 | OCE 3140 Copier
OCE 7056 Toner Not Fusing To Paper
you need parts to fix the heater. the heater is the part that fuse the ink to the paper.
since part of print is not fused to the paper. I am assuming at this time it must have multiple heater in the machine.
go to the link and see if they can sell you the heater you need.
www.kyoceramita.co.nz/files/1/Parts%20List%20v0405.xls
good luck on finding parts.
Oct 16, 2008 | Office Equipment & Supplies
MY SHARP AR5316 DISPLAY H4 WHEN I PUT IT ON
Here is the process
  1. Find the pink Clear button on the Control Panel of the WorkCentre.
  2. Find the button below the word Auto.
  3. Press these buttons in the following sequence: [Clear], [Auto], [Clear], [Auto] NOTE: All of the lights on the Control Panel should go out and the LED Display should go blank. If the lights do not go out, then repeat step 3 until they do. It may be necessary to increase or decrease the pace of the [Clear], [Auto], [Clear], [Auto] sequence.
  4. Press the [10's] key one time and the [1's] key four times to enter '14' in the LED Display, as if you were to make 14 copies.
  5. Press the green [Start] button.
  6. Press the pink [Clear] button two times.
  7. The WorkCentre should now warm up and come to ready.
  8. If the above steps do not clear the error code, repeat steps 3 to 6 a second time.
Dec 11, 2007 | Sharp AR-5316 Advanced Digital Imager...
186 people viewed this question
k24674
jasbo
jasbo
