SOURCE: Hi can you please tell
By going through the menu you can set date & time to display, setting the day when setting out on a trip with the LX2, you can display which day of the trip each photo was taken on while viewing. Great for organizing your travel photos.
SOURCE: how to set camera mode to have time and date on
Refer the page # 77 in the manual of the Camera to superimpose the Date stamp on the images or print the images with Date stamp.
http://www.kb.sony.com/selfservice/microsites/search.do?cmd=displayKC&docType=kc&externalId=DSCW100guidepdf&sliceId=pdfPage_77&docTypeID=DT_MANUAL_1_1&dialogID=55704716&stateId=1%200%2055706200
or
http://www.docs.sony.com/release/DSCW100guide.pdf
However, because the images shot with the Camera include information on the recording date, you can print images with the date superimposed if the printer or the software can recognize Exif information. For compatibility with the Exif information, consult the manufacturer of the Printer or the software.
If you use a Photo printing service, ask them to superimpose the date on images.
However, using the supplied PMB software, you can print images with date.
How to add a date and time to images for printing using the Picture Motion Browser software.
http://support.d-imaging.sony.co.jp/www/disoft/int/pmb/feature/edit/attach_date.html
Good Luck!!!!!!!!!!
SOURCE: Show/print date stamp on my photos
In order to imprint the date stamp on photos, the photo size (L, M1, M2, M3, S, Postcard) must be set to Postcard, and in the recording menu the "Date Stamp" option must be set to Date or Date & Time.
Testimonial: "Perfect! Thank you so much..."
SOURCE: I have a canon digital ixus 951s - some of the
You'll need to check your owner's manual for directions for turning that feature off. As for the pictures that already have the date on them, Photoshop Elements or any similar photo editing software can easily remove them. Also, if the date is near enough to the edge of the photo, you might be able to just crop it out.
SOURCE: Kodak M1033 lens comes out but will not go back
Here are the steps: 1. Make sure you will install a new or fully charged battery/batteries into your camera. 2. Clean the battery contacts. a. Remove the battery/batteries and the memory card from your camera, then wipe the battery contacts with a soft, clean cloth. b. Reinstall the battery/batteries into your camera. Please make sure that you are installing a fresh/ fully charged battery c. Without the memory card, turn your camera on. 3. Please test with the a different battery If you do not have access to another battery Try these steps instead: Please take the battery out of the camera. b. Insert the charger into the unit from the main socket and turn the camera on. If the camera works you will need to replace the battery. If you camera doesn?t switch on you will need to order a No power repair or a new cable. In order to organise your repair or Trade up please Contact KODAK: http://www.kodak.com/eknec/PageQuerier.jhtml?pq-path=14563&pq-locale=en_US&_requestid=3490
