Question about Ryobi 26CC, 22 In. Hedge Trimmer
Pull start broken on Ryobi gas trimmer
The pull-starter does not work
    Problem Solver:
  • 34 Answers
Ssssssssssssssssssssssssssssssssss
Posted on Jul 27, 2009
Ryobi ss26 trimmer puller cord won't retract
It appears that the recoil spring has broken and you will have to pull it apart to replace it
Jun 17, 2013 | Ryobi Multi-Volt Battery Charger
Pull the chord and it just uncoils and recoils, not turning anything to start the motor.
You might have a broken latch inside the coil assy or maybe just gummed up or stuck. take it apart and look into it further. Go to this website and they have a video about restringing starter coils this will aide you in your disassembly. smalleng.com
Nov 20, 2010 | Ryobi Factory-Reconditioned 30cc 18" Gas...
I have a Ryobi gas click it system. Have been
You didn't list the model but those little rewinds are typically built very similarly.
It may sound a little crazy but it works, take the unit to a power washer such as a car wash and blow out the gook in the rewind with lots of hot soapy water and then rinse. Then using a probe or small screwdriver get the rewind unstuck. If it retracts you’re good to go if not let me know as you may have a broken piece in there
Jun 04, 2010 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
It wont start
First, make sure that the gas mixture is correct (gas and oil mixed in the right proportion). Next, press the primer bulb 3-4 times, turn the choke lever on to Full Choke, and pull the starter cord until the engine seems like to wants to start, but dies. Next, switch the choke lever to Half Choke and start the gas trimmer, giving it gas by pulling on the trigger. Once it has warmed up fully, you may be able to reduce the Half Choke to No Choke, although my 20+ years of experience with dozens and dozens of models tells me that many trimmers run better, although smoking slightly, when you keep them at Half Choke. One last tip, when pulling the cord, try pushing the trimmer away from you with the opposite hand at the exact same time that you are pulling the starter cord--the equal and opposite push-pull technique may sound like something from karate (and it is, in a way), but it is really helpful when trying to start trimmers. Best of luck, Bill
PS: Check you owner's manual (at home or online) for the proper gas/oil mixture. Empty any old gas out and replace the spark plug, if required.
Oct 10, 2009 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
Replacment of starter pull cord
Remove the recoil cap cut the knot of the old cord off pull out the string. Cut a new cord the same length thread it in and knot it . rewind the spool until the cord in the spool. fish the cord out of the pull hole and tie on the pull handle
Aug 04, 2009 | Ryobi Factory Reconditioned 18" 40cc...
Trimmer won't stay running without starter fluid
drain any old gas/fuel mixture out of unit.
purchase new gas and mix with oil as recommended for your engine.
clean the air filter on the unit.
pull the spark plug and clean with carb spray and reinstall...
you also may need to remove the carb and clean any jets with carb spray... old gas can turn into a shellac'ish type goo and foul up the works...
I recommend draining all fuel after usage...
May 29, 2009 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
3 year old ryobi gas trimmer won't start...didn't winterize. I follow the start-up directions and it won't turn-over.
This could be caused by tons of problems. I'm going to assume you've checked the spark at the plug first. If not then you'll want to pull the plug out, leave connected to the wire and check to see if there's a blue spark when you pull the starter string. When my trimmer finally wouldn't start (or keep running) I found there were small cracks in the fuel lines. It was causing problems with the prime (for starting) and then with the running. My engine wasn't leaking fuel so it was hard to find.
May 02, 2009 | Ryobi 30 Cubic Centimeter Curved Shaft Gas...
Ryobi Line trimmer
you have to remove the starter housing, inside will be 2 knobs that spring out when the cord is pulled that contact the flywheel cap of the motor and rotates the crank. check if they are missing or damaged and that they ejecting when the cord is pulled. if not; replace.
Jul 24, 2008 | Ryobi 15" Electric Factory Reconditioned...
Gas Trimmer will not stay started
My straight shaft trimmer will idle but dies when the I pull the trigger.
Apr 03, 2008 | Ryobi 15" Electric Factory Reconditioned...
Ryobi 26CC, 22 In. Hedge Trimmer Logo
327 people viewed this question
Top Ryobi Garden Experts
Nick Olsen
Rexter1
Roland W VanLue
Roland W VanLue
Are you a Ryobi Garden Expert? Answer questions, earn points and help others
