My dishwasher is blinking on "clean". When I press cancel, it sounds like it's draining for a while, then it blinks "clean" again. It won't let me start a new cycle.
When the clean light is blinking, the self-test on the dishwasher has reported a problem with the heating circuit. It needs to be fixed. If the dishwasher is still under warranty, call for service.
Open the door.
Within 3 seconds press the following sequence --Try pressing normal wash,
heated dry, normal wash, heated dry, normal wash, heated dry three times within
6 seconds and then press cancel to reset the dishwasher. If that doesn't help
then try pressing Saini
Rinse, Heated Dry, Saini Rinse, Heated Dry, Saini Rinse, Heated Dry or Saini Rinse, Air
Dry, Saini
Rinse, Air Dry, Saini
Rinse, Air Dry 3 times in 6 seconds and then the Cancel Button. Close the door
and press Cancel.
Blinking lights would stop and should be able to use your dishwasher normally.
If the light is still blinking try and reset the power to the dishwasher and
try again. If still the light is blinking then check for the connections on the
keypad, it may be due to moisture or shorted connections on keypad.
Hope this
helps... Please post back if you need more information.
press normal heated dryer normal heated dry normal the dishwasher should reset and start. You will need to check the heater this happens because the heater normally fails. Let me know,
press heated dry
press normal wash press heated dry again press normal wash again.......... .....wait a few seconds all the lights should come on press cancel (should hear pump) hit cancel again
Hope this helps, it worked for me, but it may depend on your model.
is the cean light blinking 7 times and then repaeating?? If so this is a water heating fault and means that the computer sensed that the water temp didnt rise just 3deg in the last main wash cycle. If its not blinking 7times then repeat, it sounds like the user interface (membrane switches) have failed. Let me know more and i can help.
about the only thing to try would be to remove the inner door panel to get to the control bd then you will see a mylar ribbon looks like a fat piece of scotch tape pull up on the plastic connector that holds it in and pull the ribbon out then get a clean pencil eraser and gently clean the ribbon and put it back in dont forget to push the locking tab back down then try it again and let me know
I just read this for the same problem: push sanitize, then heat and dry, sanitize, heat and dry, sanitize, heat and dry, cancel, then open and close the door. It worked. The dishwasher is running correctly even as I type this.
when you said "I can run a wash", does the machine act normal for that time frame up to the point of drain? if yes, the pump is fine. sounds more like the micro chip on the board is "confused", but not sure why.
