SOURCE: pierre cardin running fast
Not enough information. Mechanical or Quartz for starters. Runs fast probably means it needs cleaning and service. Probably not a watch worth doing that with. They use cheap movements that can easily replaced but jewelers are too lazy or expensive to take a cheap watch to. These use cheapo movements.
SOURCE: how can i unlock the combination lock on my
If its a padlock your talking about a quick answer is try making a shim.
( http://www.instructables.com/id/Open-Any-Padlock/ )
a long answer is start at 1 and work your way up. lol
SOURCE: I have a Series 118 Pierre Cardin Quartz alarm
mcdevito75 here, The mode button is the button you need to depress to set the mode of the watch. Depress the mode button once, see if anything on the face is blinking, if it is use the set button to adjust the time/date You may have to depress the mode button twice or depress and hold down the mode button a couple of seconds to get the face/display of your watch to blink, after you make 1 adjustment to move to the next depress the mode button again until you get to the next adjustment, or the next function to set on your watch. After you"ve set all the functions depress the mode button again to stop the blinking a show a steady display.
SOURCE: I need a spare part to my Pierre Cardin watch. Is
mcdevito75 here, You can try to contact online at Pierre Cardin watch.com Most likely you"ll have to send the watch to Pierre Cardin or you may be able to order the part you need.
SOURCE: i bought a new pierre
Your best bet is to take it to a jewellers in your local town, they have no reason to falsify any answer
hope this helps
