Question about Danby DPAC12031 Air Conditioner
Danby Premier 13000 seris portable air conditioner
I also have the yellow indicator problem.
When I set up the unit out of the box, the remote control would not start the unit. I had to use the button on the front of the unit. When I pushed the button, it would cycle between "blue" to show it was cooling, then green for the fan. I feel like the unit worked fine for for about 15-20 minutes that way.
Then the indicator changed to yellow and it has stayed that way, and the remote control no longer controls the unit. It has slipped into some kind of automatic mode. If cycles between cooling and fan about avery 5 minutes or so.
I ran it all day yesterday and it seems to work fine, but it is in this cycle. It is cooling the room, but the unit is definitely not working to its potential, and I cannot control any of the features of the unit with the remote. All of the features of the unit are not available. Basically all I can do is turn it on or off with the switch on the front.
Is there something I have to do with the remote or the unit to "reset" it and regain control? The unit cools great when it is running, but it will not stay on COOL for more than 5 minutes or so and then it kicks over to fan for 5 minutes or so. Reading in the manual again it seems to be saying that the main switch is just an emergency shutdown type button, so it seems like I have interrupted something here.
When I press a button on the remote, the display on the remote lights up and it shows that it is broadcasting a signal, but it is not changing any of the settings on the unit.
I read another question here where you said to "follow the instructions" in the manual, but I do not understand what I need to do here. Can you walk me through the steps your would recommend?
  • thegolls Jul 27, 2009
    I will give it a try tonight and reply tomorrow morning.
    Brigadier General:
  • 4,090 Answers
Hello thegools, Like most modern appliances everthing is now controlled via the remote.
From what you describe i would think that the batteries in the remote are flat, but recover sufficeiently to be able to turn on the unit after a while. Try changing the batteries and seeing if the remote responds better. Most of the controls on the remote will control the mood of the unit. It may be that you have a default set of a reasonable temperature that allows the thermostat to achieve and then rest. This of course is a economy mode. Look at the diagram in the manual and see what each button does. I was not able to find an electronic reference to this model so its all guess work at this point. But change the batteries first. OK?
Posted on Jul 28, 2009
  • 11,896 Answers
Try leaving it unplugged overnight to reset iself.
Posted on Jul 27, 2009
I need to purchase the remote control for Danby premiere dpac13009 Where I can find it ?
Ebay, only 1 available. $55 free shipping.
NEW Danby Premiere Room Air Conditioner Remote Control Transmitter A2529...
Appliance Parts Pros. $48 + shipping. I would call first because they don't have it in stock. Claim of 5-6 days may not be correct.
http://www.appliancepartspros.com/danby-dpac-remote-control-a2529-950-ap4556076.html
Repair Clinic $49 + shipping. Again call first because they don't have it in stock.
Remote Control A2529 950
Jul 27, 2016 | Danby Premiere 13,000 BTU Portable Air...
Danby portable air conditioner won't turn on - brand new!
Obviously it is problematic machine from the factory so it will suggest a replacement.
Apr 12, 2012 | Danby DPAC12010H Portable Air Conditioner
Have a portable air conditioner Danby model DPAC 8399-3. Could you tell me how can I open the remote control to replace the bateries, since i lost the literature. My name : NANDO
Slide the rear cover of the remote in the directions of the way the arrows are pointing.Continue pulling gently until the cover separates completely from the unit. Insert 2 - AAA Batteries in the direction indicated inside the holder. Reinstall the cover and you're ready to go.
I hope this helped you, Nando. Thanks for choosing FixYa.
Jul 25, 2011 | Danby Heating & Cooling
Danby DPAC8399 Portable Air Conditioner no Cool air
You possibly might have a bad switch or have a dirty ac unit.Try 1st turning off the unit and cleaning the inside ...
May 27, 2010 | Danby DPAC8020 Air Conditioner
Using the DPAC 8020 AIR Conditioner (Danby)
these portable units will usually have a knob reading from low to high. set it about half way and adjust as needed. half way is usually low 70's
Aug 03, 2009 | Danby DPAC8020 Air Conditioner
Just opened up box and no instruction booklet nor remote control included
Contacted Danby- Direct and they are sending me the missing parts from my order...
Thanks for you help.
Jun 02, 2009 | Danby DPAC120068 Air Conditioner
DPAC 13009 portable air conditioning problem
Remove your remote control on the unit, follow the manual step by step. First, do the emergency on/off button, then operate the air conditioning using the remote control, follow the procedure of your manual.You may notice a clicking sound of your remote control. The yellow/green color of your emegency on/off button will turn to blue. Do not put it back your remote control on the unit because he may sense the temperature of the vent, and your air conditioning will not stay on, it will shut off every five minutes. Your problem is solve.
Regards,
Cesar
May 24, 2009 | Danby DPAC12031 Air Conditioner
Danby Portable Air Conditioner DPAC120068 - room temperature
Maybe, the compressor isn't starting? I'd take it back to where you purchased it.
May 18, 2008 | Danby Portable Air Conditioner
Danby DPAC12031 Air Conditioner Logo
388 people viewed this question
Top Danby Heating & Cooling Experts
Dan Webster
Dan Webster
Dennis Boxerman
mintvl
Level 1 Expert
Are you a Danby Heating and Cooling Expert? Answer questions, earn points and help others
