Question about Samsung (GV-DW-KVM-4P) KVM Switch
What's the power specifications for the SamSung LCD KVM?
  • Samsung Master
  • 4,806 Answers
As far as i know Samsungs LCD monitors run on either 12 or 14 volts and 3 amps, if you can post the actual model number i will be able to narrow power specs down for you.
You can find the model or part number at the back of the unit.
Regards.
Posted on Jul 27, 2009
We have to push the on button on our TV from 20-100 times to get it to turn on. Have changed batteries and restarted to no avail.
"He said our TV has a problem". Brilliant! To be more specific, he could have suggested switch failure or a failing power supply.
Apr 26, 2017 | Samsung Televison & Video
My ECS17 KVM tray will not respond to hotkey commands.
The LCD is just that an LCD, you would need a Switch behind it in order to get into the Hotkeys.
Feb 11, 2011 | Avocent ECS17KMM-001 Rackmount LCD...
Can you recommend a brand of KVM switch that will work with the MX 5500 wireless system
I am not sure about MX500, but this kvm switch works fine with all major OS. So, it should work fine with MX500 too. You can always try, just view its specifications and you may find it useful.
Jun 24, 2010 | Logitech 2 Port Automatic Electronic KVM...
No backlight on Samsung 710N LCD Monitor
No, it is not easy to change the backlight on an LCD panel. The backlight is an integrated part of the LCD panel itself. The backlight for LCD monitors is also model and manufacturer specific, so there's no easy place to order a backlight to do it yourself. The good news is that your Samsung monitor should come standard with a 3 year warranty, so if it's less than 3 years old, you can call Samsung and they'll repair/replace it for free. If it's over 3 years old, then you may need to repalce the monitor... or pay to have it repaired.
Mar 07, 2010 | Samsung SyncMaster 710N 17 in. Flat Panel...
My Samsung 913t says "Check Signal Cable." HELP PLEASE!!!
Cheap CRT monitors can be picked up at Thrift Stores, quick and cheap way to test your computer output.
Sep 22, 2009 | Samsung SyncMaster 191T 19" Flat Panel LCD...
No signal to monitor.
1 st you directly connect the lcd to system and see it is showing the display and conncet the vga cable proprly to kvm output socket.
Sep 08, 2009 | HP TFT7600 Rackmount KVM Switch
4-port usb kvw switch #GCS634U
The GCS634U is designed and tested to work only with a standard USB keyboard and mouse. However, most wireless keyboards and mice work with it, but they cannot guarantee any specific model or brand that would work correctly.
As you can see, this KVM switch is a bus powered device (meaning it only gets power from the USB ports of the computers). If the computer cannot provide enough power for the KVM switch to function correctly, then the wireless keyboard will be affected.
You may try using the IOGEAR GKM541RA. It's tested to work with the GCS634U. Or you may also try using a self-powered USB hub (meaning, it has it's own power adapter) and connect it in between the KVM switch and the computer. That self-powered USB hub will be the one that will add up power to the KVM switch and help it to function properly.
Jan 12, 2009 | IOGear GCS634U KVM Switch
AC-DC power converter for Samsung SyncMaster 191T Flat Panel Monitor
According to all the specifications on the web that has built in power. You should just need a standard PC power cable.
Maybe the SN on the monitor would help to locate what you need.
Oct 10, 2007 | Samsung SyncMaster 940BE 19" LCD Monitor
Samsung (GV-DW-KVM-4P) KVM Switch Logo
18 people viewed this question
Top Samsung Computers & Internet Experts
270rexton
270rexton
Are you a Samsung Computer and Internet Expert? Answer questions, earn points and help others
