The modem is not connecting with the fax line. I can copy and scan, but I cannot fax.
  • 295 Answers
Mention the name of ur printer and model number also.there is a separate fax line if u have to send fax from ur printer. if u have a dsl line, u need a splitter. then only u can send or receive fax.
Posted on Jul 28, 2009
How do I connect A Epson WorkForce 845 to NBN & Telephone
If your phone is provided by broadband then it is now a VoIP phone. In order to use your machine, you will need a fax gateway or a digital to analog converter. This will allow your fax machine with uses a analog line to connect to a digital VoIP line. You will need to connect your nbn provider.
Sep 05, 2014 | Epson WorkForce 845 Wireless All-in-One...
Can't send or receive faxes on my Canon MF 6550
Make sure you cartridges are not empty and properly installed. Also make sure the paper is properly installed.
Thanks,
lee
Jul 28, 2008 | Canon imageCLASS MF6550 All-In-One Laser...
My computer does not recognize my modem so I can send a fax.
2 completely different technologies.
FAX uses phone line (analogue) and router is digital.
It's one or the other.
Plugging what is essentially a modem into another modem was never going to work.
Scan and email is much faster and easier.
Or FAX to FAX through phone line.
May 14, 2017 | Computers & Internet
Printer will not fax I have dsl modem for computer
Hi
If you have ADSL modem for the internet, and same line you connected with Fax then you will need to ADSL splitter to split your adsl line, get the ADSL splitter in market. in splitter you get one male pine or two female pine, male pin you connect the main switch where the connect is come, one female is ADSL there your connect your modem, and other female pin you connect you fax and try. your fax and internet will work both at a time.
Jun 23, 2011 | Lexmark X7170 All-In-One Scan/Copy/Fax and...
Hp c309a printer/fax/scan/copy - fax's sent not being rec'd and cannot receive incoming. Ran fax test and shows "pass" on all items.
hate to ask, but is the phone line from back of printer in the correct port, the one for 1 line, next check the connection to the wall or splitter, if you are using a splitter, radio shack type, try the other side, and last, if you have a single hand set, check to see if you have dial tone at that connection. now if you are using cable modem for your phone and fax, you will need to contact them for assistance.
Sep 22, 2010 | HP Photosmart Premium C309A All-In-One...
Is there a fax number for people to fax you?
Yes,
It is the phone number assigned to the phone line you plugged into the fax machine. You Fax machine is basically a Modem listening to the phone line. Someone dials and if they are sending a fax, the two machine's make squealing noises called a "handsake" then connect sends data.
It is then stored or printed or both.
If you pick up the phone while the two fax machines are connecting.
You will most likely disconnect the data transfer and get an ear full.
Hope this helps!
Nov 17, 2009 | Lexmark X7170 All-In-One Scan/Copy/Fax and...
I have a Arris Modem from time warner cable, no i
do you have dsl filter where the phone line comes out of the wall and goes into the Router.
https://en.wikipedia.org/wiki/DSL_filter
Mar 26, 2017 | 2wire (1000-000057-000) Modem
No Dial tone using Symantec Winfax Pro 10 on Windows 98
Check the physical connection of the phone line to the computer make sure that it is connected to phone line symbol of the Ethernet adapter. Then make sure that the driver of the adapter is installed properly on the computer or you can try to scan the hardware first before the re-installation of the driver using the adapter.
May 26, 2009 | Conexant chipset 56K V.92 PCI Data/Fax...
FAXES ARE NOT COMING THROUGH
try calling your fax line from a different phone and see if your machine is picking up the line and making a high pitch squeel. if it is then the modem is ok. then insert a document into your fax and select a copy and see what happens, that will be test your scan and printer on the fax.. hope this helps. contact me if you need additional help.
Thank You,
Mikey
Mar 21, 2008 | Canon FAXPHONE L80 Laser
Lexmark X73
Sending a fax by DSL requires one of two methods: 1. You obtain a DSL line filter suitable for connecting a standard voice telephone to the DSL line, then connect an analog fax modem to the line through the line filter. 2. You hire an Internet E-faxing service. See · http://www.slipstick.com/addins/services/fax.htm#internetfax · http://www.slipstick.com/addins/services/fax.htm · http://www.savetz.com/fax Tim
Jan 30, 2007 | Lexmark X7170 All-In-One Scan/Copy/Fax and...
42 people viewed this question
jasbo
jasbo
