Question about Toshiba Satellite L305-S5933 Notebook
Sd card stuck in slot
Put memory card of camera into sd, in trying to get out it went in further. My friend took the back off the laptop and keyboard off but the sd slot at the front in a separate comparment which i can't get at. have tried getting a tweezers but no joy. Help
  • 125 Answers
You will have to remove the palm rest and then unplug the sd device look in the back of it and should be a small hole take a paperclip and push through the hole
Posted on Jul 27, 2009
I have a vivitar camera from a friend and she took her memory card out then i bought my own brand new memory card with nothing on it and new batteries too. then when i try and take a picture it says memory...
From the manual:
http://static.infoteldistributors.com/pdf/VC8025%20User%20Manual.pdf
Installing SD Memory Card
Your camera has a memory card slot that enables you to insert any "SD" compatible memory card up to 8BG. Adding a memory card will allow you to increase the capacity of your camera before you have to transfer photos and videos to your PC. Install the SD memory card as below:
  1. Locate the Memory Card slot within the battery compartment.
  2. Insert the Memory card into the slot in the correct direction. (see the sketch below)
7
  1. Push the card in until you feel it "click" into position. The top of the card should be flushed with the surface of the camera. An icon will appear on the LCD screen after you turn on your camera.
  2. Once the external memory card is inserted into the camera all the images taken with the camera will be stored on the card.
Note:
  1. Limited internal memory is provided for test images. The image will be deleted when camera power is turned off. Please download the images before power off .SD memory card is required for normal use.
  2. An external memory card is required for normal use. Your camera supports any compatible SD memory card (up to 8GB).
  3. If there is a photo in the internal memory when you insert the card into your camera, a "Copy to card" message will appear on the LCD with Yes or No options. On selecting 'Yes' the photo will now be copied to your card.
  4. Formatting will delete all data on the SD memory card including protected data.
8
  1. Don't remove the SD card during formatting as this may damage the card and render it unusable.
  2. When your card is full, download the media on the SD card to your PC and delete the photos and videos from it in order to continue using your
Dec 24, 2010 | Vivitar ViviCam 8025 Digital Camera
I took pictures and recorded video on a (PNY OPTIM SD HC [60 HD] ) Memory Card that a friend gave to me. and it recorded fine on my camera. I use a Nikon Coolpix, but yet nothing is reading the card. I...
It could be that the devices into which you inserted the SD card are not designed to accept SD cards of that type.
There are 3 SD card types: SD, SDHC and SDXC. If the SD card size is 4GB to 32GB, the type is SDHC, and if the card is larger than 32GB, it is an SDXC type.
Newer devices will accept SDHC and SDXC cards, but older devices may not be able to read those SD card types. You should be able to check the specifications of the devices you are using by looking on the device manufacturer's web site.
Sep 25, 2017 | PNY 2GB microSD Memory Card
How do I put an SD memory card in a hp Paviliion ze2000 notebook? I cant' find the memory card slot anywhere!
Actually your laptop doesn't have SD memory card slot but there is another way you can use that SD memory Card in your Laptop.
You have to get SD Card Adaptor.
Click here to see how it looks like and also you can buy it at the website.
Please let me know if you have any further questions or concerns.
Thanks.
May 03, 2010 | HP Pavilion ze2000 Notebook
Memory card error
Did you format the card before using it on your camera? Try using a memory card reader instead of the printer's SD card slot to transfer the video. Also check if the memory card is locked (check the position of the yellow slider at the right side of the card). If this does not work, then you will have to format the card. Unfortunately this will erase all the data in your card.
Feb 04, 2009 | Panasonic Lumix DMC-FX01 Digital Camera
Memory Card Error on my Canon Power Shot S2 15 using Kodak SD car
Hello
OK, if the memory card itself is locked, you might sometimes get this error code. All you need to do is to take out the memory card and switch the lever on the left side to the unlock.
If the error is still displayed after you did the above, you might want to try the card in another camera.
If the card works in another camera . the problem is with your card reader in your camera.
If you open you sd slot and look inside with a sharp light , you should be able to see on the left side of the slot there is a little copper or spring steel lever switch. This switch work as follows:
1. When no card is inserted / no write protection , the switch is open and thus the protection is off.
2. When locked card is inserted , the tab is depressed and tells the camera that the card is lock.
Contrary to popular belief ,the little tab on the sd card is not an electronic switch and does not physically influence the card operation itself. If you put a locked card into a camera without a sd lock switch , you would still be able to use the card normally.
It is incredible difficult to fix this switch because of space limitations in the sd card. Look into the sd slot and if you can see the switch , use a needle to pull the little tab down toward the base of the camera by about 2mm or until it works being careful not to bend it.
If this does not resolve your problem , there might be a short in the switch circuit and the camera will need to be disassembled to resolve this error. This should cost no more than $50.
Please feel free to contact me if you need further information
Kind regards
Andrea
Jan 27, 2009 | Kodak EasyShare C315 Digital Camera
Pictures on lg shine won't show on computer.
I think the problem might be that your phone is set to save pics you take with shine to phone instead of card. Try opening your camera, click "options", click "primary storage", then select "memory card". Take a test pic, pop the card in computer and see if it shows up. You should see a new folder choice -- "graphics". Hope that works for you!
Dec 27, 2008 | LG Shine KE970 Cellular Phone
Pictures
You have to make sure that the sd memory card you were using, hasn't been in another camera. If it was, your camera read the memory card differently, and it didn't show you had taken any. If this was the case, put the sd card back into the camera you took it from, and hopfully it will show on that.
If I wasn't even close, put you sd memory card in your computer, and hopefully, they will show up on there.
I'm sorry if I didn't get what you were saying, and didn't even answer you problem. I hope this helps.
Oct 01, 2008 | Nikon Coolpix L11 Digital Camera
Momory card slot?
I imagine that is just the plastic plug for the bus port. Are you looking for a laptop memory slot or SD camera memory slot. These machines do not have an SD camera memory slot. You will have to get a USB adapter for it. They sell them at Walmart for approx $15. The laptop memory slots are located under a panel on the bottom of the machine. If there is only one slot there, then the other slot is under the keyboard.
Jun 29, 2008 | Toshiba Satellite M45-S165 Notebook
Digital camera sd card stuck in laptop
Hi...
Remember that the SD card has a little slot at the center we'll use that to retrieve the card. First, find a "medium safety pin" and straightened it and on the sharp edge, use a plier to make a little hook... Use that to pull it out....
Use an extended card holder to insert the SD card because the design is for the mini stick SD card...
Goodluck... happy Fixya...
Feb 06, 2008 | Lenovo 3000 C200 Notebook
Toshiba Satellite L305-S5933 Notebook Logo
513 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
