Question about Timex Expedition 40141 Wristwatch
The back cover for my watch popped off when I dropped it. How do I get it to "snap" back on?
  • 7 Answers
I used to work with jewelry. !!BEWARE!!
This method is for face crystals that are completely FLAT! Any convex crystal will shatter without proper tools!!!
Any method of putting the watch cover back with the watch remotely near water/moisture is a mistake. The watch will rust sooner or later.
So if you don't want to pay a jeweler five dollars to put it back on, this is what I did to my sister's watch cover when I could not snap it back.
I took my cushy 1/4 inch mousepad to a vise. You may not have a vise. If you don't, stop reading now and take the watch to a jeweler --one who replaces batteries.
Inside the vise jaws, I used a 5 inch square piece of wood, then my cushy mousepad, then the watch facing the pad, then the back in the right place for restoring.
!!!!NOTE: Not having the back in the right place will smash the stem and damage can/will result!!!
To push the back on, I picked a 12 point socket out of my socket set that was the same DIAMETER as the watch back and placed it CENTERED behind the back.
Recapping, inside vise:
  • small board
  • cushy mousepad (to avoid scarring and crystal breakage
  • watch crystal facing mousepad
  • watch back in correct position
  • ratchet socket the same diameter as watch back centered behind cover
Slowly I positioned all these items with minimal pressure. Then when I was sure that I was ready (and prepared to hear the crystal break) I put as little pressure closing the vise that I could. The I heard a snap, and to my relief, it was the back going in!
I DO NOT RECOMMEND THAT YOU DO WHAT I DID. People with broken watch crystals become very IRATE when "all it needed was a battery"!
A screw clamp would also give adequate pressure. Any unsupported direct pressure over the crystal will shatter it!
Hope this helped.
Good luck!!!!
Posted on Aug 27, 2009
The best and the easiest way ( ONLY for FLAT Crystal)
Place the watch with back in the middle of a book ,close the book and press hard. It should snap into place.
For Dome or curved crystals, go to watchmaker.
good luck
Posted on Nov 22, 2009
    Problem Solver:
  • 11 Answers
If it wont snap back on with just your fingers you may need to take it to a repair shop. I have to use a case back closer to close some watches. It is a pain for you but it does help the watch to be more water resistant that it is so hard to close. Oh and if you try yourself, check to see if there is a notch on the inside rim as that will need to be lined up with the stem.
Posted on Jul 31, 2009
2 Suggested Answers
SOURCE: Replaced battery in my Burberry watch, back cover won't snap on
I have the same problem. Did you guys find how to do it? Please let me know. M
Posted on Sep 03, 2010
How do I put the back cover on a Waltham watch?
Try hooking the edge furthest from the winder at first, then work toward the winder.
If that isn't enough... warm the back cover with a hair dryer while you chill the rest of the watch. Serious as anything - the warmed cover will expand JUST SLIGHTLY while the cooled watch will contract JUST SLIGHTLY, maybe enough to snap that cover on. You can cool the watch in a freezer, but if you do... quickly snap the cover on while you hold the watch in the still-open freezer. If you take the watch from the freezer and leave it open at room temperature, it'll get moisture condensate inside. Leave it cold until the cover's on.
It also helps to wear cotton gloves if you use the heat-and-cool approach - then your hands won't appreciably cool the warmed cover or warm the chilled watch.
The watchmakers have a special watch press that squeezes the back into place - it's padded to prevent damage to the crystal, and applies a little extra force to the center of the back to buckle the rim outward just slightly during pressing. Like the opposite of a wheel cover for a car.
Jul 30, 2014 | Waltham Watches
Does the back cover snap-on/off or screw on/off? I don't see tabs for popping off.?
Although the cover is flatly closed and there's no tab/recessed area on the cover, you can still use a watchmaker's knife (looks like a Swiss Army knife but with case opener blade) or even use a Swiss Army knife to open it (pry off, particularly common in less expensive watch).
Be careful, don't try to use the point of the knife, use the blade instead.
Get under the rim and gently but firmly turn the blade upward, popping the cover off.
If the cover is flat, no notches on it, that is a screw-back case. You need a case wrench (screw-back watch case opener) to open (unscrew) the cover. If you try to use a very small flat screw drive and tab (turn) the cover in counter-clockwise direction, be careful because it can cut your fingers.
Hope it helps.
Feb 19, 2011 | Watches
Trouble replacing rear analog watch cover
mcdevito75 here, Replaceing that back cover can be a real pain. I think I have a tip for you. Place the cover only in the Frig. for about 15--30 minutes, the cold should shrink the cover just a bit so it may be easier to snap back onto the back of your watch.---------- OR, Make sure any cutout on the back of the watch is lined up with the stem, make sure any lip used to pry the back cover off the watch is also lined up with the case of the watch if need be. Place the back cover on the watch back, place the watch on a sturdy table, counter top etc. Crystal up, now with even,even pressure useing your palm, press down on the crystal, this should get the back cover to snap back on. Remeber even, even down ward pressure useing the flat palm of your hand on the crystal, press down slowly and the back cover should snap on. If not, visit a small watch repair shop in your area as they have a special pliers just for this job.
Aug 17, 2010 | Armitron 165 watch
Get cover off the timex watch indiglo w30m watch
Try removing the rubber washer or the black band on the cover then try snapping it back on. I removed the washer and placed it on the back of the watch before I placed the cover on and it just snapped back on.
Sep 14, 2009 | Timex Watches
Cannot get the cover back on Fossil watch after changing battery
First open your bracelet. Then align groove in caseback with crown and press that side lightly into the case. Then using both hands(one from dial side, another from back) press as strong as you can.
If this do not work:
Get mens leather belt and place it on flat surface(table top). Lay the watch face down on that belt. Again adjust caseback as before and using your weight push caseback down with both hands.
NEVER use hammer or similar.
If none of these works- go and see your nearest watchmaker.
Dec 20, 2008 | Fossil Sport University of Texas LI2084...
Expedition WR50M
I had the same problem. The thing that was most frustrating is that I have a standard tool to remove and install screw in watch backs, but Timex in its infintie wisdom, decided to make this model withta snap-in back.
I tired usinga a set of adjustable locking pliers with rubber claw covers. I tried holding one side with finger and thumb while using the pliers on the other to no avail.
robatbath's answer about jewelers having a special press led me to a solution. I just happened to have (2) 1.25" steel washers with 1/4 inch holes. I placed one on the face and one on the back. This way I could use the locking pliers (with rubber covers on) to press in the center of each side. The back snapped in fine. You can get washers and pliers at any hardware store.
Aug 09, 2008 | Timex Expedition 40141 Wristwatch
Watch battery cover
You will need a special tool to pop it back on. Any other way will result in the crystal breaking.
Aug 04, 2008 | Kenneth Cole 1213 Wrist Watch
HELP !! can't snap armitron watch cover back on
Take a small thin piece of cloth or paper towel, fold it and use to cover the watch face.  Put one quarter (coin) on top and one quarter (coin) on the bottom.  Place the sandwich in a pair of pliers, center thhe pliers and press, when you hear the snap, the back is on.  Do not use on a watch with a domed crystal, or at least use a lot more padding over the face.  Takes 10 seconds.
Jan 20, 2008 | Watches
Removing the back to change battery
The plastic wrist band doesn't have to be cut away. You need to dislodge the spring-loaded end of the pin from the hole in the plastic with the blade of a sharp thin knife.
The you proceed to lift one of the 4 snaps to open the cover. The battery is under a white translucent inside cover.
The original battery was Sony SR621SW.
Pay attention to the rubber seal ring when putting the watch back together.
Jan 13, 2008 | Casio MQ24-7B2 Wrist Watch
Timex Expedition 40141 Wristwatch Logo
646 people viewed this question
Top Timex Watches Experts
Ansel Alberto
Ansel Alberto
Brett Duxbury
Brett Duxbury
David Ellis Rhea
Are you a Timex Watch Expert? Answer questions, earn points and help others
