Error U3-5 on Xerox docucolor 4LP - Office Equipment & Supplies
5 Suggested Answers
SOURCE: xerox docucolor 250 error code 042-326
Belt Failure turn the mach. off and un plug for 20 to 30 seconds then turn back on if this dosent sole you need to call a tech to replace the main belt
Posted on May 30, 2009
pineworks
  • 4041 Answers
SOURCE: Error code 10-356
Hi
10-356 code i pws mode
remplace the fuser
Posted on Feb 10, 2010
SOURCE: Xerox DocuColor 1632 /2240 Enter the Diagnostics Mode
fuji xrox 2240 error code 102-372
Posted on Feb 15, 2010
SOURCE: Xerox Docucolor error 116-324
xerox phaser 6280 phaser controller error 116-324 i already powered off and on error returns i also replaced the contoller bd same problem can you help me
Posted on Mar 09, 2010
Xerox DocuColor 3535 103-208 error I accidentaly
There isn't much you can do, except perhaps buy at least one new board. But those are expensive
In this case, a better solution is to call Xerox. This correction must be done by an Authorized Xerox technician, with their proprietary laptop called a PWS.
They will run the procedure called GP-10 Replacing Billing PWBs.
Whit Item, Inc.
Nov 19, 2010 | Xerox DocuColor 3535 Copier
When i print one document on my xerox docu color 4lp on the printer display's this message "U6-4 Cycle power"
U6-4 sounds like an NVRAM error and could be a bad board.
I think they probably be the Main System Controller Board 160K58571 or the Engine Controller/MCU 160K60530
Whit
Item, Inc.
Aug 10, 2010 | Xerox DocuColor 4LP Laser Printer
Error code list
Hi, you can find the error code list for the DocuColor 3535 in the Troubleshooting section of the manual. If you don't have a user manual, you can download a PDF version from Xerox here:
http://download.support.xerox.com/pub/docs/DocuColor_3535/userdocs/any-os/en/3535_User_Guide.pdf
Mar 08, 2010 | Xerox DocuColor 3535 Copier
Xerox DocuColor 242 Fusor Error/ Paper Jam
Those coded normally are related to something not being seated properly in the paper transport in the fuser area.
Mar 02, 2010 | Xerox Office Equipment & Supplies
I AM HAVING SOME PROBLEMS WITH FINDING OR FIXING(IF POSIBLE) THE BELT CLEANER BLADE 2 ITEM # 33K92111 FOR THE XEROX DOCUCOLOR 4LP IT LEAVES A STREAK THE PLASTIC BLADE HAS A SMALL DENT AND CAUSES THE LIGHT...
Xerox parts are highly restricted by Xerox and thus are hard to find. I would check with The Parts Drop. www.partsdrop.com
If they don't carry it perhaps they can get it or at least give you more information.
I am not affiliated with them in any way other than I have used them before when servicing Xerox copiers.
Nov 24, 2009 | Office Equipment & Supplies
Xerox docucolor 3535 - error 010-348
Hi, you have to reset this code entering into diagnostic mode, If this fault is declared 3 times in succession, print and copy mode will be disabled. In order to clear this condition, reset NVM location 744-003 to 0. Saludos from mexico
May 10, 2009 | Xerox DocuColor 3535 Copier
Xerox dc12 error code 9-378
9-378 Drum Cartridge count expired (40K)
Aug 12, 2008 | Xerox DocuColor 12 Printer
Can ping printer but jobs not received
have you checked your firewall?
Often times, even though you can ping the printer, the firewall will block the data going to the printer.
Jan 12, 2008 | Xerox DocuColor 4LP Laser Printer
211 people viewed this question
k24674
jasbo
jasbo
