SOURCE: dewalt 10 inch portable table saw blade height adjustment very st
What I would do is clean area with air (wear safety glasses) then I use a spray type of dry lubricant on the threads and also the plates that the motor slides on. You can also use WD-40 in a pinch. Hope this helps
SOURCE: uneven cutting height
Hi Matt,
Thanks for the update. Good ole brainstormin' comes through again!
Charlie
SOURCE: My 42 inch Cub cadet riding mower does not cut
check the condition of your righthand spindle, if spindle has no play, your deck may need adjustment
SOURCE: flymo micro lite - cutting height of blade
you twist the plate holding the blades and it will lift off, then you turn the blade plate upside down and replace making sure you align the notches and then twist to lock into place. hope this helps
