Question about JVC AV-56WP74 56" Rear Projection HDTV-Ready Television
JVC AV-56WP74 closes up and flickers when input is trying to come through
I have the model listed above, and the screen is closing up about half way and flickers/jumps and turns all green. There is no signal getting through, neither audio nor video on any of the channels/inputs selected. I have seen ONE other post about this EVER and it was made by another person on this site. They never got back to my message of how they fixed the problem, or whether or not they fixed it at all. I was wondering if someone can tell me specifically what may be wrong? I thought maybe it was the MI COM DIST PWB because that seems to be where all of the signals converge. But that is a $400-500 board to replace myself. Any help would be great, and if there is an estimated cost of fixing this, please let me know, so I can start saving. I really like this tv, and would like if I could fix it for a reasonable price. Thanks!
  • LuckyLindy Nov 22, 2007
    Yeah, I've already pulled out all the boards (they are on a plastic mounted tray that slides out) and I didn't see anything unusual. What should I be looking for if there was coolant leaking? Also, I'm not purely positive that the signals converge on that board (part number SSB0D069A-M2) but I'm pretty sure, based on the schematics/diagrams in the service manual.
  • 1,694 Answers
First possibility is a CRT coolant leak onto the signal PCB.
Examine from front and back with good light = even a few drops
of conductive coolant can cause various unusual symptoms....
Your symptoms are multiple and normally un-related, unless,
as you mentioned,all the signals converge......................T.
Posted on Nov 22, 2007
  • Vista Electronics Nov 22, 2007
    Look for any wet to touch spot...if not,then perhaps you have a
    power supply issue that affects multiple circuits....T.
  • 1284 Answers
SOURCE: Convergence IC,s overheat
Make sure there is enough heat sink compond between the IC's and the heat sink itself. These IC's do usually run fairly warm to hot but that heat should be disapated onto the heat sink.
Posted on Apr 26, 2007
  • 254 Answers
SOURCE: Need schematic for Convergence PWB of Hitachi
click the link.
Posted on Mar 09, 2009
  • 1139 Answers
SOURCE: convergence problem
Did you lock the adjustment into the TV's memory? This step is the most often missed. Please follow the directions on the Users manual or on the service manual on how to set your memory to hold the configuration.
Find the menu item on setting the convergence adjustment into memory (the menu should have an informational screen on this topic)
I hope this helps
Thank you,
Posted on Mar 23, 2009
  • 227 Answers
SOURCE: JVC AV-56WP74 56in red shadow
hello, the first thing i am going to ask you is do you have the jvc original remote, because sometimes universal remotes don't work a 100%. now the second one is if you have any repairs skills, because if you do, just replace the convergence stks, i am almost sure that this tv you don't have to open it from the back, i believe they are right in the front just remove the front panel and you will see them ,well before you replace them check for loose connections, if not replace the convergence ics stks (stk392-110) and also replace any burned resistors. good luck
Posted on Apr 05, 2009
  • 8617 Answers
SOURCE: AV-56WP74 the convergence is off.
You will need to replace the Convergence ICs and resistors you can get the JVC repair kit called the AV48WP74-65WP74 convergence repair kit from which contains the ICs , resistors and the CD with instructions,
Posted on Sep 23, 2010
JVC AV-56WP74 56 in. Rear Projection red projector is not showing images and big red line in tv
If the red line looks like a swoosh of red across the screen it may be the convergence Ic having an issue.
Jul 04, 2011 | JVC AV-56WP74 56" Rear Projection...
A black box appeqars on my screen
u have the cc1 on , goto the menu and look for close caption and put it off
Aug 25, 2010 | JVC AV-56WP74 56" Rear Projection...
How do I hook up my dvd player to my JVC model AV-56wp74?
just run your av leads into your AV inputs on tv,then switch tv to AV1 or AV2
May 01, 2009 | JVC Televison & Video
Blue lines
Hi, convergence amps have failed, your going to need a tech for that repair, involves un--soldering and re-installing parts as well as an alignment, hope this helps, video-tek
Feb 11, 2009 | JVC AV-56WP74 56" Rear Projection...
After a power surge My Jvc Av-56wp74 big screen Tv won't come on.
 Try this: Works with most crazed computer based devices.Remove power (unplug) unit for 1 minute then plug in
Dec 14, 2008 | JVC AV-56WP74 56" Rear Projection...
Green screen
If the TV works ok using the component,composite and tuner inputs otherwise then the HDMI module is bad.
Nov 25, 2007 | JVC AV-56WP74 56" Rear Projection...
Jvc model av-56wp74
Needs convergence IC's replaced..........T.
Oct 06, 2007 | JVC AV-27850 27" TV
No picture
sounds like you have a defective signal board.. shuld be replaced by qualified tvtech..John
Sep 05, 2007 | JVC AV-56WP74 56" Rear Projection...
JVC AV-56WP74 Problem
Yes, one of your convergence IC's have gone bad. They are located on the convergence board inside the tv and there are two of them. They are inexpensive and easy to replace if you know how to solder. Watch out for the JVC booby trap sensor on the dvi input card. Don't run the tv with the back panel off unless you have disconnected the DVI card from the main board. I would even cover the little sensor with black electrical tape. Then it is safe to work on the tv when it's open and on. Well safe for those who know what they are doing.
Jul 29, 2007 | JVC AV-56WP74 56" Rear Projection...
Can't shut off closed caption
I have the JVC I Art 46" TV. The Close Caption was turn on accidentally by my grandson. After lots of searching for the original remote. I called JVC Customer Support. He told me to change the Close Caption settings to CC2 and T1. That fixed the CC without having the original remote.
Apr 10, 2007 | JVC AV-32F704 32" TV
JVC AV-56WP74 56" Rear Projection HDTV-Ready Television Logo
60 people viewed this question
Top JVC Televison & Video Experts
Jaime Hernandez
Are you a JVC Televison and Video Expert? Answer questions, earn points and help others
