Question about Compaq Presario SR1120NX 2.66GHZ Tower w/ CD-RW (2018267632) PC Desktop
My SyncMaster 930b suddendly went blank except for "Check Signal Cable" box floating around. All has been working fine on my Windows WP Proffessional system. The cable from the desktop CPU has not been disturbed and is still connected properly. Turning monitor off and on does not help.
  • 1 more comment
  • dnvjohnson Jul 27, 2009
    So you are saying it probably is not a problem with the monitor, but in the CPU. Correct?
    Give me a few minutes to plug the monitor into this laptop as a check.
    Plugged into this laptop. No image. In display properties shows monitor 2 is inactive. Since I have used this
    laptop to drive my large Samsung TV using the same settings, it would seem that the problem is with this 930b
    monitor.
    Not sure you got this so sending again.
    Connecting monitor to this laptop did not change image on monitor. In the past, connecting my Samsung tv
    to this laptop worked fine. I am using the same settings.
    for this monitor, the Display properties shows 2 not active
  • 11,896 Answers
Try a different video card or booting up PC via cd rom. Possibly bad video drivers or card.
Posted on Jul 27, 2009
  • Nate Stansfield
    Nate Stansfield Jul 27, 2009
    On main windows screen, right click, properties, settings, then move boxes and enable all monitors.
My screen just stopped working and I have a rectangular box floating around in a counterclockwise rotation that says " Check cable signal " Do you have any ideas? It was working fine up...
that means your monitor is working fine, just check your video connection on both ends of the monitor and PC.
maybe your PC has two video cards, try to plug in another video connector
Jan 29, 2011 | Samsung SyncMaster 931B 19" LCD Monitor
Check signal cable
Check if the monitor is not working by connecting this monitor to another computer.
If the monitor woks on another pc, then the pc is the issue and not the monitor.
If monitor doesnt work on the other pc, then it's the monitor that needs replacing.
I hope this helps you :)
Jul 13, 2010 | Samsung SyncMaster 930B 19" LCD Flat Panel...
My Samsung Syncmaster 930B was working fine unti I disconnected and then reconnected it to my computer. Now I get a black screen with a roaming box that says, "check signal cable".
Hello
1st Pull all power from pc from the wall.Plug back in and start pc up.
While starting hold down the f8 key and select safe mode.
once in go to control panel and select display.
set resoulution to default 60 hz and screen size to 800 by 600.
Reboot.
You may need to readjust your screen again.
Hope this helps.
Jan 14, 2010 | Samsung SyncMaster 930B 19" LCD Flat Panel...
HDM1 BOX FLOATING
This is telling you that you do not have a High Definition Mode source connected to teh screen.
Oct 03, 2009 | Samsung SyncMaster 2233BW 22" LCD Monitor
Samsung SyncMaster 226BW - floating box "Check Signal Cable"
had the same issue, called up customer care of samsung and they suggested me to change the cable to D-15 10 series. I was getting the comp o/p on TV but with the "Check Signal Cable" messg with the old VGA cable where some pin is not grounded used for computer to monitor connectivity.
Abhi..
Jul 25, 2009 | Samsung SyncMaster 2233BW 22" LCD Monitor
A box stating not optimum mode-get distorted internet images
Sounds like your resolution is not set correctly.
Try going to Start-->Control Panel-->Display and choose the Settings Tab
Under there change the resolution slider bar to 1280x1024
Should do the trick!
Jul 11, 2009 | Samsung SyncMaster 913V 19" Flat Panel LCD...
No Signal HDMI
Had the problem. Turned out to be a defective hdmi port circuit board.
Aug 04, 2008 | Insignia 42" LCD Flat-Panel HDTV
Connection
that has nothing to do with the keyboard.. check your vga cable (the cable that connects your screen to your PC)
Jun 12, 2008 | Logitech Cordless Desktop EX110
Compaq Presario SR1120NX 2.66GHZ Tower w/ CD-RW (2018267632) PC Desktop Logo
Top Compaq Computers & Internet Experts
Abhinandan  Patil
Abhinandan Patil
mukhtar21 shaikh
mukhtar21 shaikh
Are you a Compaq Computer and Internet Expert? Answer questions, earn points and help others
