Question about NetGear WGR614 54 Mbps Wireless Router - Wireless router - EN, Fast EN, 802.11b, 802.11g
Wireless router is not running as wireless. have to use cable. have multiple laptops but can't use them all at once
  • 1,272 Answers
Hi, Follow the steps below to configure settings:
1. Open the browser (Internet Explorer, Mozilla Firefox or Safari) on a computer connected to the router.
2. Access the router, usually with http://192.168.1.1 or http://www.routerlogin.com.
3. Login to the router with the Username as "admin" and Password as "password" (please note that the Username and Password are case sensitive).
4. Click on Wireless Settings (under Setup) from the left menu.
5. Select security options as WPA-PSK. Enter a Password in the passphrase box. Apply the settings.
If the laptop has windows XP then perform the steps below:
1. Right click on My Computer icon and go to Manage.
2. Go to Services then go to Service and Applications.
3. Double click on Wireless Zero Configuration.
4. Change the Start Up Type to Automatic and click on Apply
5. Click on Start and press OK to close the window.
6. Go to 'Control Panel', Click on Classic View in the left hand side menu and then open 'Network Connections'.
7. Right-click on the wireless Network Connection icon and select 'Properties'.
8. Go to the 'Wireless Networks' tab .
9. Check the option 'Use Windows to Configure this Wireless Connection' and click 'OK'.
Now please perform the following instructions to connect to the wireless network:
1. Go to 'Control Panel', Click on Classic View in the left hand side menu and then open 'Network Connections'.
2. Right-click on the wireless Network Connection icon and select 'Properties'.
3. Click on the 'wireless network' tab.
4. In the preferred network box, Select all SSID and remove the name from the list. Once the list is empty, Click OK.
5. Right-click on the wireless Network Connection icon and select 'View Available Networks'.
6. Look for the SSID (aka Network Name) of the Wireless router or access point.
4. Highlight the SSID from the list that you want to connect to.
5. Type the security Key here and click on the 'Connect' button.
6. You should have successfully established a wireless network connection.
For Vista laptop perform the steps below:
1. Click START, Click Control Panel then click classic view in left hand side menu.
2. In the main screen, open up NETWORK AND SHARING CENTER.
3. In the left hand side menu open up MANAGE WIRELESS NETWORKS.
4. If you see any name in the list, please select the name and click remove.
5. Once the list is empty, click on ADD, select the first option, ADD A NETWORK THAT IS IN RANGE OF THE COMPUTER.
6. Click on your network name SSID and click on connect. If you have a Password setup on the router enter the security key.
7. This should setup the wireless network.
I hope this information allows you to resolve this issue.
If I have helped you, please help me, and rate this suggestion with the highest FixYa rating. If you cannot rate this post with the highest rating, then please comment to this post and I will try to help you further.
Regards
Anand
Posted on Jul 27, 2009
I DONT KNOW HOW TO PUT MY NETGEAR ROUTER THROUGH MY LAPTOP , SO I CAN HAVE WIRELESS INTERNET ACCESS
u will need RJ45 CABLE (normal ethernet cable, labelled cat5e)
plug one end into laptop network connection other into laptop
login address will be (netgear) details will be under router
http://192.168.1.1pi
or something like that.
login id: admin
password: password
if u cant login then, press reset button back of wireless router, will need to do that with pen or pin?
once logged into the router, use the setup wizard and the the rest is self explanatory.
once setup is dne, with SSID and password, then plug the cable from laptop, in back of the internet modem coming into ur house from ur supplier....and ur ready to surf the web.
find your new wireless network using the laptop and insert the password....
Oct 10, 2010 | NetGear WGR614 Wireless Router
I have attempted to set up our Belkin wireless router multiple times, we use Suddenlink cable system and we get as far as .......it asks for some kind of code that IS NOT on the list of codes that came...
HI! I bliv u are having some issue setting up ur router.. I will be more than glad to assist u. . here are the steps u need to do:
1. press the reset button on the back of the router for 20sec..while pressing the reset button, unplug the power plug and after 2secs while pressing the reset button plug it back in and press for 30secs after that unplug the router for 15secs then plug it back in..once all the lights are solid and ok
2. connect the ethernet cable to port1 of the router and the other end to the lan port of your computer..
3. pull up ur browser then type at the url:192.168.1.1.or 192.168.0.1 or u can check the routers default gateway by right clicking the network icon on the lower right of your task bar and click on status and it will show the ip address of the computer, subnetmask and default gateway, the default gateway is the routers ip address, once u type in to the url, it will ask u the username and password, by default the username is admin and the password is 1234 or just leave it blank
4. it will show the setup page of the router. u can set the router on the specific internet setup that u have.
a. if ur isp is a cable company, normaly u need to do a mac clone on the router setup page by cloning the computer that is reg to the cable company, how to determine it. ex. the computer that is reg to the cable company is a desktop or laptop, if this computer is connected to the modem directly and u can access internet.
b. once u determined it u need to connect this computer directly to the router and do a mac clone and set ur internet settings to auto-dhcp..then save the settings and after that, unplug to the power of the modem and router, plug in 1st the power of the modem then once all lights lit, plug in the router, then once all lights lit, try to pull up a browser that ur computer is connected directly to the router.. ur cable connection shud be, cable from the modem will go to the WAN port of the router and connect ethernet cable on port1 going to the lan port of the computer..once u can access the internet, u can now access again the setup page of the router by typing at the url:192.168.1.1 and u can setup the wireless settings, u need to create a ssid or wireless name and a security..
5. If ur isp is a dsl normaly they give u a username and password to connect to the internet, ur settings on the router should be PPPoe
6. If ur isp gives u a static ip address settings, u need to set the router to isp setup.
a. how to check the isp of the isp given to u..
1. click on start
2. run
3. type cmd
4. it will show a dos prompt
5. from the dos prompt type ipconfig/all
6. it will list the ip address, subnet, default gateway, dns server
this settings should be type in to the settings on the router for static ip addressing..
7. Once your done on the internet setting, go to your wireless connection settings and you can create a wireless network name or ssid, set a security by selecting wep, wpa, wpa2.
8. once all is set. save the settings and to check if your laptop can access the wireless network that you did, turn on the wireless switch of your laptop, once its on, it will show the wireless network icon on the lower right of the taskbar, right click it and select on view available network, the network name that u did should list, just select it and connect and it will ask for the password, just type the password and connect, you should be connected to the wireless network and have internet access..
9. If you are going to hook up your desktop to the wireless connection, you need to install a wireless network adapter, install the driver and do the same thing as u did to the laptop, for the desktop no need of turning on the wireless switch, once you install the driver correctly, it will show a network icon..
if you have any query pls feel free to get in touch.. good luck
Nov 20, 2009 | Belkin (F5D5231-4) Router
Had an extra router, brought it to my folks to hook up wireless for new laptop...connected through Comcast modem, all wired correctly...problem because laptop is an HP and modem is being run through Mac???...
HI! I bliv u are having some issue setting up ur router.. I will be more than glad to assist u. . here are the steps u need to do: 1. press the reset button on the back of the router for 20sec..while pressing the reset button, unplug the power plug and after 2secs while pressing the reset button plug it back in and press for 30secs after that unplug the router for 15secs then plug it back in..once all the lights are solid and ok 2. connect the ethernet cable to port1 of the router and the other end to the lan port of your computer.. 3. pull up ur browser then type at the url:192.168.1.1.or 192.168.0.1 or u can check the routers default gateway by right clicking the network icon on the lower right of your task bar and click on status and it will show the ip address of the computer, subnetmask and default gateway, the default gateway is the routers ip address, once u type in to the url, it will ask u the username and password, by default the username is admin and the password is 1234 or just leave it blank 4. it will show the setup page of the router. u can set the router on the specific internet setup that u have. a. if ur isp is a cable company, normaly u need to do a mac clone on the router setup page by cloning the computer that is reg to the cable company, how to determine it. ex. the computer that is reg to the cable company is a desktop or laptop, if this computer is connected to the modem directly and u can access internet. b. once u determined it u need to connect this computer directly to the router and do a mac clone and set ur internet settings to auto-dhcp..then save the settings and after that, unplug to the power of the modem and router, plug in 1st the power of the modem then once all lights lit, plug in the router, then once all lights lit, try to pull up a browser that ur computer is connected directly to the router.. ur cable connection shud be, cable from the modem will go to the WAN port of the router and connect ethernet cable on port1 going to the lan port of the computer..once u can access the internet, u can now access again the setup page of the router by typing at the url:192.168.1.1 and u can setup the wireless settings, u need to create a ssid or wireless name and a security.. 5. If ur isp is a dsl normaly they give u a username and password to connect to the internet, ur settings on the router should be PPPoe 6. If ur isp gives u a static ip address settings, u need to set the router to isp setup. a. how to check the isp of the isp given to u.. 1. click on start 2. run 3. type cmd 4. it will show a dos prompt 5. from the dos prompt type ipconfig/all 6. it will list the ip address, subnet, default gateway, dns server this settings should be type in to the settings on the router for static ip addressing.. 7. Once your done on the internet setting, go to your wireless connection settings and you can create a wireless network name or ssid, set a security by selecting wep, wpa, wpa2. 8. once all is set. save the settings and to check if your laptop can access the wireless network that you did, turn on the wireless switch of your laptop, once its on, it will show the wireless network icon on the lower right of the taskbar, right click it and select on view available network, the network name that u did should list, just select it and connect and it will ask for the password, just type the password and connect, you should be connected to the wireless network and have internet access.. 9. If you are going to hook up your desktop to the wireless connection, you need to install a wireless network adapter, install the driver and do the same thing as u did to the laptop, for the desktop no need of turning on the wireless switch, once you install the driver correctly, it will show a network icon.. if you have any query pls feel free to get in touch.. good luck
Oct 05, 2009 | Linksys Wireless-G WRT54G Router
Multiple users cannot connect through router at one time!
1. click on start
2. run
3. type cmd
Sep 30, 2009 | Linksys Ultra RangePlus Wireless Routr...
Belkin 54 Wireless Internet Connection Problems
If wireless adapter on the laptop is fairly old, you may need to update the drivers for the wireless adapter. Some older wireless adapters are not capable of properly communicating with WPA devices. Typically a driver update of the laptop resolves the issue. If not, try another wifi adapter and verify it is not the OS or laptop itself.
Good Luck.
Jun 20, 2009 | Gateway Belkin 54g Wireless DSL/Cable...
Setting Up a Wireless Network
You can still use your existing Linksys router with your cable modem. In fact the router your have is designed to work with DSL/Cable Broadband connections.
1. Make sure to properly connec the devices in your network. Modem will be connected to the Internet port of the router. Then, laptop will be connected to one of the 4 Ethernet ports of the router. For initial setup of your router with modem, you need to hardwire laptop to the router.
2. Press and hold reset at the back of the router for about 15 seconds.
3. After 15 seconds turn off the router and then turn off the modem. Wait for a minute.
4. Power on modem and wait for the lights to be ready.
5. When modem lights are on, turn on router.
6. There should be 4 lights on. Power should be steady green. Internet, WLAN and Ethernet port.
7. Checked if you have Internet connectivity on your laptop while it is wired to the router.
8. If Internet is working, disconnect laptop from wired connection to the router and check available wireless network that laptop can detect.
9. The default wireless network name that the Linksys router broadcasts is "linksys". Connect to it which is an unsecured wireless network.
10. Once you are successfully connected, check Internet.
Hope this helps!
Nov 16, 2008 | Linksys Wireless-G Broadband Router
Cd won't load on computer
You may configure your router without using the cd.
Using an ethernet cable, connect the router and the laptop so that you can configure it for internet connection.
1. check physical connection. modem to internet port of router. laptop to numbered port of the router.
2. check lights.
3. on your laptop go to the command prompt. (type cmd on the run window)
4. type ipconfig/all on the black screen
5. look for ip address. IP address should be in this range 192.168.0.*
6. open your internet explorer browser then type http://192.168.0.1
7. type admin on the username then password or 1234 on the password box.
8. configure the router for dsl or cable connection. don't forget to save
9. check if you have internet connection. if not, power cycle the modem and router.
10. once you're online, go to wireless tab. set your ssid (any name you want). set your encryption (either wep or wpa) don't forget to save
11. unplug the ethernet cable from the laptop and the router.
12. if the wireless card of the laptop is configured, you may click the wireless connection icon at the system tray (near the clock). enter your ssid and encryption.
13. you should have internet connection.
Nov 02, 2008 | NetGear WGR614 Wireless Router
Multiple laptops... router only connects with one?
type into IE your routers web address 192.168.0.1, or 192.168.1.1, i forget which yours is; then you will be prompted for a username and password, the username is usually blank and the password is admin, unless you have changed it.
When in the settings look for DHCP and make sure it is enabled to automatically assign ip addreses to all pc and check that all the pc's are set to obtain an ip address automatically
Aug 18, 2008 | Linksys Wireless-G WRTP54G Router
Router won't log into it's IP address online
It appears to me that you have everything plugged into the desktop PC. This is not the way that it should be done. Plug the cable modem into the wireless router via the Internet/WAN port. Plug your desktop PC into one of the ports numbered 1-4. Now connect to the router via the wireless connection for the router and you should be able to now connect to the internet with your laptop.
If it still does not work, power down everything in this order: Laptop, Desktop, Router, Cable Modem. Bring everthing up in the reverse order (Cable Modem, Router, Desktop, Laptop) waiting for each device to stablize before moving to the next.
Once you get everything working, turn on your wireless security (WPA not WEP) asap to keep your computers and surfing safe, and to keep intruders off your network.
Jul 20, 2008 | NetGear RangeMax WPN824 Router
My wireless router wont work
Run a cat5 cable from the laptop to a cat5 port on the router, open internet explorer in the address window type http://192.168.1.1 or what ever the IP address of the router once you have accessed the router create your PPPOE internet connection, enter your Internet Service Provider's username and password. Once you have done this, disconnect the cat5 cable and connect wirelessly to the router from the laptop. If all this fails press and hold the reset button on the back of the router for 10-15 seconds this will reset the router to factory defaults. connect to the wireless router and create the PPPOE connection. BPCS
Dec 29, 2007 | D-Link DI-634M Wireless Router (DI634M)
NetGear WGR614 54 Mbps Wireless Router - Wireless router - EN, Fast EN, 802.11b, 802.11g Logo
94 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
