Question about Maytag MGD6300T Gas Dryer
I have a Maytag PYG3200AWW and it won't start.
I have a Maytag PYG3200AWW Gas Dryer and it won't start. There is power on the outlet. Before having this issue, it was taking a long time to dry out the cothes, sometimes 2 or even 3 cycles was necessary. So I cleaned out the duct and it was working great since then. It worked well for about 4 weeks and then stopped.
Any hit?
Machine is about 8 years old.
  • 4 Answers
Sounds like a problem with a limit control switch. Some are manual reset and some are automatic . Not sure about yours. They are located of course, in-line within the wiring harness limiting the amount of heat build-up within the machine. If yours had been running with a stopped up, or patially stopped up vent, (and your limit swithch IS AUTO reset,) then the switch could have been cycling the heat numerous times, over that period, preventing overtemperature conditions. This would weaken the switch because it is a safety device and not actually a cycling device. Also, in the vent exhaust, @ the back of the machine there may be a limit switch. And of course, it could always be the start button..........
Posted on Jul 27, 2009
No power to maytag neptune drying center mcg8000aww
Sounds like the thermal fuse is open, which generally means the vent is clogged
Aug 31, 2014 | Maytag Neptune MCG8000AW Gas Dryer
My Maytag gas dryer won't heat
Hello Todd,
Their are several things that could cause the dryer to not heat, i have posted a tip i wrote what to check whena gas dryer doesn't heat
http://www.fixya.com/support/r10293028-gas_dryer_not_heating
GENE
Nov 12, 2011 | Maytag Dryers
When we push the button to start dryer it buzzes, it won't go and won't dry clothes. maytag admiral dryer ADG7005AWW
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
May 19, 2011 | Maytag ADG7005AWW Gas Dryer
Dryer wont start
If the problem you are having is that your Maytag gas dryer is not starting, these are the parts you will need to check until you find and correct the problem.
You need to make sure that the wall outlet has 120 volts presents in it, in order for the dryer to be able to start. Connect a good working hair dryer in the wall outlet, if the hair dryer works, then you know that the wall outlet is not the problem.
Most gas dryers have one thermal fuse and some have two thermal fuses wired in series with the motor. If any of the thermal fuses are blown that could be one of the reasons of your dryer not starting.
The timer is the distribution center in the dryer, the timer will send the right voltage to each of the individual parts in the dryer. Most common problem with the timer, is burnt contacts.
The motor is in charge of turning the tumbler, turning the blower to circulate hot air inside of the dryer and making sure that the heating element won't come on when the dryer motor is not running. A bad or weak motor could be the reason for your Maytag gas dryer not starting.
The door switch is a safety device use to prevent the dryer motor from starting or running when the door in the dryer is open. Burnt contacts or a broken actuator on the switch could be the reason that the dryer is not starting.
The push to start switch is single pole single throw switch that is use to start the motor. Once the motor starts running the switch is no longer in the motor circuit. A bad push to start switch could be the cause of your dryer not starting.
Burnt terminals or wires on the cord could be the reason for your dryer not starting.
As you can see, if any one of these parts fails the dryer will not start.
please comment on these post by staying how helpful.
Dec 21, 2010 | Maytag MDG308DAWW Gas Dryer
No start
If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer Troubleshooting2_bing.gif Electric2_bing.gif Dryer won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
May 03, 2010 | Maytag EPICz Electric Dryer
Dryer noise and no motor action
heatman101
May 03, 2010 | Maytag PYE2300AY Electric Dryer
Model # PYG3200AWW my dryer was having a hard time starting and now won't start.
to check for bad motor,open dryer door,hold in door switch and someone push in on start switch,at the sam time reach inside the dryer and turn drum clock wise,if it start's than you have a bad motor.
Nov 15, 2009 | Maytag Performa PAV3200
Changing a 3 prong plug into a regular outlet plug.
Your plug is for 220v and a regular wall outlet is 110volts. It simply will not work. You will burn out your dryer, and place yourself at risk of electrocution.
Nov 03, 2009 | Maytag Neptune MDE6800A Electric Dryer
Dryer has power but will not start.
You might have a wiring issue in the dryer or a bad control board.
Feb 20, 2009 | Maytag Neptune MDG5500AW Gas Dryer
Maytag MGD6300T Gas Dryer Logo
139 people viewed this question
Top Maytag Dryers Experts
Dan Webster
Dan Webster
Tim Whalen
Are you a Maytag Dryer Expert? Answer questions, earn points and help others
