Question about Bosch Exxcel WFO 2264 Front Load Washer
DRUM NOT SPINNING
The washing was working fine and during a wash my daughter came along and pressed the buttons on the front of the machine whilst it was operating.
Now the machine has stopped working. The drum will not spin no matter what programme is selected.
The water etc is fine and it does drain. The problem is the drum will not spin.
  • 3 more comments
  • MrPoo Nov 24, 2007
    Very much the same issue. Water flows in at the beginning of the programme, there is a click and the drum fails to spin. Can also drain the water out successfully...
  • fusion007 Nov 24, 2007
    Not sure if this helps to pinpoint the fault.
    When I put it on spin, the timer starts at 11 minutes then when it goes down to 10 minutes, it goes straight to 1 minute and the machine stops.
  • fusion007 Nov 28, 2007
    These buttons are not on this model.
  • dbsteeples Dec 04, 2007
    I have a WFA206Q front loader. the number doesn't appear on many US web pages, since we got it in Mexico. It's still there, and one repairman had it for a few months and didn't fix it. Washer fills, motor hums, and never spins. the belt is still in. Any thoughts... looks like it might be the motor.
    Thanks!
  • bigyellowt Mar 04, 2008
    We have exactly the same problem. Have been advised to clean the impeller - but it doesn't appear to come out.
    Pump or brushes are possible other causes.
    President:
  • 1,294 Answers
Disconnect your washer's plug for 5 minutes or more from the wall socket. Plug in. Press "end of cycle" button for over 5 seconds, the child lock comes off.
Press it again and the child lock comes on................ If this does not work, try the pre-wash button likewise.
Posted on Nov 25, 2007
Washing machine knocking.
Does the drum wobble quite a bit or does it look normal? If it's wobbling it could be the drum casing knocking the internal structure. Might need a new drum spring if this is the case
Oct 20, 2014 | Washing Machines
My fridgedaire front loader washing machine has been making weird noises when it spins or washes, making sounds like there is loose metal inside somewhere rubbing and clanking around. As of last night...
When my washer did that, I found that the shocks that hold the tub were bad...
Check out this tip I wrote about the noise and vibration that front loadwashers can make..
Washer Problems Washer noise when spinning
heatman101
Aug 13, 2011 | Frigidaire Washing Machines
Kenmore supercapacity 3.5 , model 417.44052400 drum does't spin during the rinse and spin cycle
Problems with a washing machine not spinning or not draining are often inter related..
If you are having a problem with your top load washer then check out this tip...
Washing Machine does not Pump or Spin
If you are having problems with your front load washing machine then checkout this tip...
Front Load Washing machine not draining and or not spinning
heatman101
Mar 05, 2011 | Kenmore Washing Machines
The drum won't spin during the spin cycle
heatman101
Oct 04, 2010 | Maytag LAT3600A Top Load Washer
What will cause the drum not to spin during cycle? It spins freely by hand. Belt is in tact and motor shaft turns freely manually?
Problems with a washing machine not spinning or not draining are often interrelated..
If you are having a problem with your top load washer then check out thistip...
If you are having problems with your front load washing machine then checkoutthis tip...
heatman101
Sep 15, 2010 | Frigidaire FCCW3000F Front Load Washer
The washer no longer seems to spin... during the spin portion of the cycle it lights up saying it is spinning, but you can see inside that it is not physically spinning. The clothes are left dripping wet...
Normal 0 MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman";} Hi,
heatman101
Sep 02, 2010 | GE WSXH208A Front Load Washer
Severe drum? shaking and display lights flicker during spin cycle
Loose mounting points or broken pins. If not that then possibly drum shaft could be cracked.
Nov 10, 2008 | Indesit W 123 Front Load Washer
DRUM HAS STOPPED SPINNING
Does it sound like the motor is spinning?
I'm thinking it could just be a coincidence and the drive belt may have snapped or fallen off.
Comment again and one of us will help you some more regarding this.
Nov 22, 2007 | Bosch Exxcel WFO 2264 Front Load Washer
Bosch Exxcel WFO 2264 Front Load Washer Logo
422 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
