Ducted A/C has an internal fancoil unit installed in the roof space of the home. From this central location, a series of ducts run from it and into as many rooms in the house as the owner desires. From these ducts, this allows you to cool or heat each room individually – called zoning
Split systems stand out for their relatively low initial purchase price. Another perk is that the installation is not so invasive – it can often be done in a day or less from a licensed technician. Though, being that the unit is fairly small, it is best suited to cooling or heating one room – this is either a positive or negative depending on how you look at it. On one hand, it’s an efficient option if you only need to cool or heat one room, but on the other hand they are less effective in larger spaces. Rarely could a split system air conditioner cool or heat an entire home. Split system air cons are great options for small areas, but lack the power to affect larger spaces – this is reflected in their relatively cheap purchase price, from around $1,000-$2,000.
SOURCE: The air conditioner only produces hot air.
possibly a dirty filter, dirty coil, or your outdoor unit is not working properly
SOURCE: I have a domestic carrier air-conditioner in
I believe this code is for the outdoor coil sensor not reading or out of range. Check the sensor in the outside unit to see if on of the wires broke or came off it should be located in the outside unit on one of the copper lines near the bottom. If you look through the grill on the outside unit you should see it.
SOURCE: what is the difference between ducted roof air
Non-ducted units blow the cooled air out louvers on the unit. Ducted units discharge into a duct system like your home furnace. (Or RV Furnace (heater)).
Testimonial: "Thanks for the help, I own a 1406 jayco pop up and just want to get the right roof air unit for it. HOSS"
