Question about LG 60PS60 60 in. Plasma HDTV
Green vertical line on videocon 42inch plasma tv
We have a 7 star set top box, recently we see a vertical green line in the 42inch plasma videocon tv, we were wondering what could be the cause and how do we resolve this. Our plasma is around 2 years old so out of warranty. This vertical green line is in the left side of the plasma TV.Can someone guide whether we should use the TV or avoid using it till the problem gets resolved.
    Genius:
  • 1,112 Answers
Hello Depending how wide the line is their could be two possible causes.
I have two questions for you.
1. How wide is the line.
2. Does it run from top of screen to bottom of screen?
If the line is thin a single strait line then it is possible the PDP has gone Bad (Panel). (Screen). The screen will to be replaced.
If the line is at least 2 or more inches wide then its a buffer board which can be replaced. LG calls this board Hand insert Boards or display driver boards..
Posted on Sep 27, 2009
  • 17 Answers
SOURCE: Benq Plasma TV
Panel is bad; you need to replace it. Go to the nearest repair center.
Posted on Mar 04, 2008
Kindofcheap
  • 241 Answers
SOURCE: 42inch LG plasma TV
well if you could please give out the model nuumber thank you
Posted on Sep 10, 2008
  • 3 Answers
SOURCE: I have multi color vertical lines on my plasma
un plug 5 min
Posted on Dec 30, 2009
SOURCE: I have a videocon 42
What you need is known as a "Z buffer" or "address buffer".
It is a board located UNDER the display.
Can't tell you the board number because you do not mention the TV model, but if you are up to replacing it yourself you better get to there anyway and see the model printed on the board itself.
There are usually two boards underneat in the 42'' models, sometimes three, but usually two.
You need to find the one located where the vertical line shows and replace it.
Replacement is not hard, but requires a bit more unscrewing because those boards are usually covered by metal shielding / heatsink, which usually has quite a few metal screws.
Other than that, though, it is not hard.
Posted on Mar 23, 2010
  • 45 Answers
SOURCE: i have an lg 42inch plasma and now a vertical blac...
I had the same problem with a five year old 50" LG Plasma. I fixed the problem with a 11 dollar soldering iron from Radio Shack and about 2 hours of my night. You have to open the back of the tv and locate where the ribbon strips are attached to the screen. I beleive that on your 42" they will be on the bottom of the tv. Mine had 11 on top and 11 on bottom. Yours will probably have around 7 or 8 along the bottom. Mine was a little easier since I did not have to remove the control board. You unfortunately probably will have to remove it. It is not hard at all, just takes more time. Make sure to keep your screws seperated and remember where everything goes. On bigger jobs some tape and a marker are very useful. Put tape on the board and around the wires removed and leave a tail. This way tou will remember to hook them all back up. Once you find the ribbon strips you have to remove them one by one and look at what is behind the metal place. There will be 4 capacitors and 4 resistors. The tv manufacturers want you to buy new tv's every 5 to 10 years so they use a very cheap solder on their contacts. Use you soldering iron and re-heat the solder to liquify it again and thats it. Allow time to cool on each of the caps and resistors. It took me about 1 to 2 seconds on each side of these parts. I did use a dual wattage soldering iron from radio shack. Its is a 25 and 35 watt iron. I used the higher setting. I have pictures if you would like me to email them to you and show you what I did. Be careful removing the ribbon strips, I broke one of the clips that hold in the ribbon strip. That is costing me an extra 25 dollars off ebay but still for a free tv, its not bad.
Posted on Jun 05, 2010
LG vertical green line
LG plasma vertical line repair - YouTube
? 2:33
https://www.youtube.com/watch?v=24FkcQoeGPg
Feb 10, 2013 - Uploaded by Matt Mayer
I have an LG plasma, my vertical line is in the middle, as if one would have ... Panasonic Plasma TV TC-P50X5 Vertical GreenBar Line Fix ...
EASY HOW TO FIX LG plasma TV - color bars - YouTube
? 4:45
https://www.youtube.com/watch?v=QyaBiSkc1l8
Dec 16, 2010 - Uploaded by Tampatec
diy HDTV Plasma tv repair tv reparar the red green blue color stripe line vertical bars T- control t-con ..
Jan 16, 2016 | LG Televison & Video
42inch LG plasma TV
Sep 10, 2008 | LG RU-42PZ61 42 in. HD-Ready Plasma...
Vertical green line
? 4:45
diy HDTV Plasma tv repair tv reparar the red green blue color stripe line vertical bars T- control t-con ...
I Have An Lg Plasma It Has A Green Line Down The Center What ...
www.diyforums.net/i-have-an-lg-plasma-it-has-a-green-line-down-the-ce...
i have an lg plasma it has a green line down the center what. .... Essentially I just disconnected the flat cable around where the vertical line was, sprayed it with a ...
LG 50PK550 Plasma Single Thin Green Vertical Line - Fixya
www.fixya.com/.../t12061168-lg_50pk550_plasma_single_thin_green
Mar 10, 2008 - Posted on Mar 17, 2012.
I have evenly spaced, rows of two vertical green and red lines from top to bottom of my vizio plasma P50HDTV10A
Somehow when switching between the tv and the dvd my wife encountered the pink and green, thin, parallel, vertical lines on the screen. The picture was visible with the lines. I turned the tv off and on but the problem persisted. Unplugged tv for about two minutes and after plugging it back in and turning it on the vertical lines very gone and the picture was back to normal.
Jan 12, 2012 | Vizio P50HDTV10A 50 in. Plasma HDTV
Sampo plasma TV 42inch
I have a PME-42S6 on Ebay that has a turning on problem it is a complete unit and work good if you can get it to turn on
Ebay # 120362175465
bid on it and pick it up and swap parts
Bob
678-333-6746
Oct 16, 2008 | Sampo PME-42S6 42 in. HD-Ready Plasma...
Half Screen has colored lines, Half screen is working ok
there is a defected capacitor in the vertical circuit trouble shoot and replace. or if the vertical circuit is separate then replace the whole board.good luck
Jul 11, 2008 | LG 42PX5D 42 in. Plasma HDTV
Getting a HD Picture on MY LG Plasma
Have you made sure the box is set to send a HDTV signal to your LG? Example 720p, 1080i, or 1080p? You usually have to set the resolution in the v+.
Feb 29, 2008 | LG 42PX4DV 42 in. EDTV-Ready Plasma...
Vertical green lines on screen
IF THE LINES ARE ON LEFT SIDE ITS THE LEFT BUFFER BOARD AND VICE VERSA THEY ARE ON THE BOTTOM OF YOUR TV HOPE THIS HELPS YOU OUT
Feb 21, 2008 | Daewoo DP42SM 42 in. HD-Ready Plasma...
Plasma tv vertical lines
I am getting a vertical green line on my lg 50 incs is the screen or have you a solution
Sep 03, 2006 | Sony WEGA KZ-42TS1 42 in. Plasma...
LG 60PS60 60 in. Plasma HDTV Logo
1,738 people viewed this question
Computer Repairing
Computer Repairing
