Question about HP DeskJet 950c InkJet Printer
Photo paper stops feeding through about 1 inch from end
I have just started this problem on my HP 960c, which has never had this issue before. (using Kodak Premium Photo paper, which I have used many times in the past) Normal paper goes through fine.
  • 724 Answers
Regular paper feeds?
Then use a single sheet of photo paper at a time with nothing else in the tray
Use a ord processor to see if there is t software glitch
Posted on Jul 27, 2009
My 4x6 prints are not centered on paper
That printer can't print borderless on 4x6 photo paper, you should use A4 size paper, print and cut the pictures.
Nov 04, 2009 | HP DeskJet 940c InkJet Printer
How can I stop my hp deskjet 960c from printing unwanted pages once it has started printing?
Turn the printer off and unplug the printer cable from both ends (printer and computer ) and cancel the documents from the printer list.
Sep 25, 2009 | HP DeskJet 960c InkJet Printer
The paper will not feed in all the way. it starts
The paper feed roller needs to be cleaned, you will have to take the printer in for a service.
Aug 04, 2009 | Canon PIXMA MP210 Photo All-In-One Printer
I have a HP 950C Printer And Am Trying To Print on photo paper
It sounds like the printers rollers are slipping on the heavier paper, possibly because this paper is smoother then your regular paper.
Try cleaning the exit rollers on the printer with something like methylated spirits - if the rollers have gone shiny, then you can usually revive them by using some emery paper to roughen them up.
Jul 08, 2009 | HP DeskJet 950c InkJet Printer
Wont grip paper on feed, keeps 'saying' paperjam
I have had this problem after printing a large batch of sheets on a heavy matte photo paper. The roller picks up a 'polish' from the surface coating and then fails to grip. I have tried cleaning the roller, with some sucess, but the best solution I have found is to feed through several blank sheets (just page throws in a Word document) of a ordinary 80 gram paper. Doing this between smaller batches of the photo printing seems to keep things flowing.
Jun 24, 2009 | HP Photosmart 2575 All-In-One InkJet...
My HP Photosmart D7260 is not printing pictures
Ok! You didn't tell me how old is the printer, what type of paper and what size you tried to print so I'll do my best to help.
Please note:
  • The photo paper cassette cannot be installed when printing on paper loaded in the in tray.
  • The 7260 printer support 5x7 media only when printing from a computer with the printer software installed.
Loading 5 x 7 inch paper in the HP Photosmart 7260 printer
  1. Lift the main cover of the printer, and slide the paper width guide as far to the left as it will go.
  2. Lift the Out-tray and place a stack of paper in the In-tray.
    • Load the paper with the side to be printed facing down.
    • Load paper in the portrait orientation with the shortest edge feeding into the printer.
    • Do not use too much or too little paper. It may be difficult for the printer to pick up a sheet of paper when there are only one or two sheets in the in tray.
    • Use one type and size of paper at a time. Do not mix paper types or sizes in the In-tray.
  3. Push the paper into the printer as far as it will go without bending.
  4. Lower the Out-tray.
  5. Adjust the paper width guide to fit snugly against the edge of the paper without bending the paper. The paper width guide holds the paper straight as it feeds into the printer.
  6. Close the main cover.
Load 4 x 6 inch (10 x 15 cm) photo paper in an HP Photosmart
Use the photo cassette to load 4 x 6 inch (10 x 15 cm) paper. To print borderless photos, use 4 x 6 inch photo paper with a 0.5 inch tab (10 x 15 cm with 1.25 cm tab). This allows the photo to print without borders on three sides and with a small border on the bottom edge that can be torn off.
HP does not recommend printing borderless photos on plain paper. Also, remove any paper from the In tray before inserting the photo cassette into the printer.
1. Lift the top cover of the printer and remove the photo cassette from the sheath.
2. Place up to 15 sheets of photo paper in the photo cassette with the side to be printed facing down. For tabbed paper, insert the paper so the tabbed end goes into the cassette first.
3. Lift the main cover.
4. Slide the paper width guide all the way to the left.
5. Lift the Out tray and remove any paper that is in the In tray.
6. Line the photo cassette up with the far right edge of the In tray.
7. Gently slide the photo cassette into the printer until it snaps into place.
8. Lower the Out tray.
9. Slide the paper width guide to the right until it cradles the photo cassette, then close the main cover.
If the Out of Paper message appears on the computer and the product stops picking up or feeding paper.
Step one: Reset the product
1. Without turning the product off, remove the power cord from the back of the product.
2. Wait 30 seconds and then plug the power cord into the back of the product.
3. If the product is not already on, use the On button to turn it on.
Step two: Check the condition of the paper and reload it
1. Replace any paper that is ripped, dusty, curled, wrinkled, or bent.
NOTE: Use only plain, white, unused paper in the product until the issue is resolved.
2. Make sure that all the paper is the same size and type. Because only one type of paper can be used in the product at a time, paper types should never be mixed.
3. Tap the stack of paper on a flat surface to align the edges.
4. Make sure that the stack of paper to be loaded in the product contains no fewer than 10 and no more than 25 sheets of paper.
NOTE: Do not load too much paper in the product.
5. Insert the stack of paper into the product and gently push the paper guides snugly against the paper. Make sure that the paper is completely inserted into the product and can be picked up by the paper rollers.
6. Try printing again. If the issue is not resolved, try loading different brands of paper and different types of paper, one type at a time, into the product and then try printing again.
If the issue persists, continue with the next step.
Step three: Adjust the paper settings in the print driver
The paper settings in the print driver must match the paper settings for at least one of the installed paper trays.
1. Open a document in the program being used to print.
2. Click File , click Print , and then click Properties . The product Properties dialog box appears.
3. Click the Paper/Quality tab.
4. Choose the appropriate paper size from the Size is drop-down menu.
5. Choose the appropriate paper type from the Type is drop-down menu.
6. Click OK and then click OK again to print the document..
7. If the issue is not resolved, continue with the next step.
NOTE: If the issue is resolved and it is necessary to print on another type of paper, load the new paper type into the product and then repeat steps 2 through 7 for the new paper.These changes do not change the default print settings. The print settings return to the default the next time the program is opened.
Step four: Clean the rollers
1. Turn off the product and unplug the power cord.
2. Open the access door to gain access to the rollers. Depending on the model, this is usually the rear access door. See the product user guide for information about locating the rollers.
3. Clean the rubber rollers with a lint-free cloth, lightly moistened with water.
NOTE: Distilled, filtered, or bottled water is recommended for cleaning the rollers. Tap water might contain contaminants that can damage the rollers.
4. Make sure that any paper rollers that rest on the input tray, which are located behind the back rollers, are cleaned. A clean cotton swab, lightly moistened with water, might be necessary to reach these rollers.
5. Close the access door and plug in the power cord.
6. Try printing again. If the issue is not resolved, continue to the next step.
Step five: Service the product
If you have completed all the steps listed above and are still experiencing a problem, service the product.
If your product is less than a year old, don't worry, HP can trace the product when you provide the model and the serial number and will help you if it is in warranty. No prove of purchase required.
Jan 09, 2009 | HP PhotoSmart 7260 InkJet Printer
Mis-feeds paper and thinks it has paper jam
the gears of the printer r worn out and they have hanve lost their allignment settings so this problem.either replace the gears.or the other solution.do not insert the paper in the tray ,keep it little bit outside and hold the end of the paper in hand when you will give a printout the printer will make a noise of picking the paper at that time just push the paper inside and then it will print properly.
Dec 10, 2008 | HP Deskjet 2330 InkJet Photo Printer
please verify that the main roller that is moving the paper out while its being printed upon is moving....if its not or it moves a bit verify that the gear teething are all intact at the gear assembly end....
check to see that you don't have worn out rollers.
Nov 02, 2008 | HP PSC 750 All-In-One InkJet Printer
Paper won't feed due to piece coming loose
If it is the piece I am thinking of, try replacing the spring with a modified spring from a click-top pen. Otherwise, please add a photo of the issue for better understanding
May 07, 2008 | Canon MP610 Photo All-In-One Printer
Won't feed paper
Hiya .. Your roller guides.. just need a general clean... and the sensors located just on the inside of the printer at the bottom where the paper sits ..
Regards Faggly
Mar 25, 2008 | Epson Stylus Photo R300 InkJet Printer
HP DeskJet 950c InkJet Printer Logo
123 people viewed this question
mukhtar21 shaikh
mukhtar21 shaikh
