Question about HP DeskJet 710c InkJet Printer
710c cable will not fit in new docking station
I have a new laptop. the new docking station does not have a port opening that the printer cable for my 710c plugs in. the cable connection is much too big to fit the new docking station.
  • 99 Answers
Need to buy a new USB to Parallel converter kit (is just a cable and a cd with the installation drivers) cost around $20
Posted on Aug 04, 2009
Will not print when docked
I would recommend that you undock the laptop, go into the Printers and Faxes console, and delete the printer. Then, dock the laptop, connect the USB cable to the dock and then re-install the printer through the dock. The USB ports on the laptop are assigned different hardware values than the PCI interface of the dock, and if the laptop is trying to print to a local USB port, it may not find the printer if it's connected through a PCI interface like the dock. That'd be my next move.
Mar 04, 2010 | Dell D/Dock Expansion Station Docking...
Can you help me install Dell A960 to my Dell laptop/docking station
Install the usb cable from your printer to the usb port on the docking station.
Install driver and software (the disc that came with your printer) while it is docked.
Jan 02, 2010 | Dell 1710 Laser Printer
The ethernet cable port on my docking station is broken.
It is hardly possible that anyone will even try to repair it. And believe it or not, it is cheaper to buy a new one then to repair the old one
Nov 17, 2009 | HP (EQ773AA ) Docking Station for nc2400...
Cant comp to work,it's plugged in and when you go
Remove Any Docking Stations or Port Replicators From the Computer Note: Docking stations and port replicators are optional equipment. If you are unsure if you have a docking solution attached to your computer, refer to Table 1 and Table 2 for examples. To remove the docking station or port replicator, perform the following steps: Shut down the computer. Remove the docking station: Universal Docking Stations: Disconnect the docking station's USB cable from the computer. D/Port or D/Dock: Remove any cable locks from the security slot on the right side of the docking station. Move the slide lock forward to the unlocked position. Press the Eject button and lift the computer from the docking station. C/Port II or C/Dock II: Remove any cable locks from the security slot on the left side of the docking station. Pull the locking lever forward until it stops to eject the computer, then slide the computer out of the docking station. Dell manufactures the following docking stations and port replicators (Table 1): D-series DocksC-series DocksSpecialty Docks D/PortLatitude? C/Port IIMedia Bases D/DockLatitude? C/Dock IIInspiron? Advanced Port Replicator Table 1: Dell Docking Stations (Click an image to enlarge it) Universal docking solutions are also available from third-party manufacturers including, but not limited to, the products below (Table 2): TargusKensingtonBelkin Table 2: Universal Docking Solutions (Click an image to enlarge it) Disconnect All Peripherals from the Computer Remove all external connections from the computer. This includes but is not limited to the following devices: docking station or advanced port replicator keyboard mouse speakers or microphone printers scanners USB or 1394 devices palm pilots zip drives secondary battery Plug the AC Power Adapter into the Laptop Computer Remove the battery from the computer. Connect the AC adapter directly to the computer Verify That the AC Power Adapter Has a Solid Green or Blue Light Verify the AC power adapter displays a solid green or blue light. Older Latitude? C Series laptop computer AC adapters may not have a light. The new E series power adapter indicator light is either a blue ring or a blue dot and is located at the tip, on the DC connector, not on the power brick itself (Figure 1). Figure 1: E Series Power Adapter Indicator Light Location Numbers reference image above: E Series Power Adapter Indicator - Blue Ring E Series Power Adapter Indicator - Blue Dot D series power adapters have a green lights located on the power brick (Figure2). Figure 2: D Series Powed Adapter Indicator Light Location Numbers reference image above: D Series Power Adapter Power Brick D Series Power Adapter Power Indicator Light Shut Down the System If the computer currently is turned ON, running on the battery, shut down the system: 1 Click Start. 2 Click Shutdown. 3 Choose Shutdown from the menu. 4 Click OK. 5 Allow the system to power off. Plug the AC Adapter into a Known-Good Wall Outlet Verify the wall outlet is known-good by testing it with another device, such as a lamp. Confirm there are no power strips, surge protectors, or uninterruptible power supplies (UPS devices) connected to the power cable. UPS devices provide temporary power for a computer when there is no electricity available from the wall socket, such as during a power outage. Plug the power cable into the known-good wall outlet. Power up the system. Replace the MiniPCI Door, Rubber Feet, and System Motherboard
Nov 07, 2009 | Dell Inspiron 1150 Latitude D600 14.1 LCD...
The C V H T and B keys on my other Dell laptop, an Inspiron 1545 have stopped working
Remove Any Docking Stations or Port Replicators From the Computer Note: Docking stations and port replicators are optional equipment. If you are unsure if you have a docking solution attached to your computer, refer to Table 1 and Table 2 for examples. To remove the docking station or port replicator, perform the following steps: Shut down the computer. Remove the docking station: Universal Docking Stations: Disconnect the docking station's USB cable from the computer. D/Port or D/Dock: Remove any cable locks from the security slot on the right side of the docking station. Move the slide lock forward to the unlocked position. Press the Eject button and lift the computer from the docking station. C/Port II or C/Dock II: Remove any cable locks from the security slot on the left side of the docking station. Pull the locking lever forward until it stops to eject the computer, then slide the computer out of the docking station. Dell manufactures the following docking stations and port replicators (Table 1): D-series DocksC-series DocksSpecialty Docks D/PortLatitude? C/Port IIMedia Bases D/DockLatitude? C/Dock IIInspiron? Advanced Port Replicator Table 1: Dell Docking Stations (Click an image to enlarge it) Universal docking solutions are also available from third-party manufacturers including, but not limited to, the products below (Table 2): TargusKensingtonBelkin Table 2: Universal Docking Solutions (Click an image to enlarge it) Reseat the Keyboard Connector to the Motherboard Caution: Before performing any of the procedures in this section, read and follow the safety instructions in Dell Knowledge Base Article: "Precautionary Measures for Personal Safety" Article ID: 339031. Reseat the keyboard connector to the motherboard. Be sure to handle only the connector and not the cable. For information about how to open the chassis and remove, reseat, and replace components, please refer to your Online User's Guide and browse to the Replacing and Removing Parts section. Remove All Power Sources and Reset the Computer Remove the battery and disconnect the AC power adapter from the computer. Note: For information about how to open the chassis and remove, reseat, and replace components, refer to the Online User's Guide. Click Systems, then the make and model of the computer. Download the Owner's Manual or User's Guide and refer to the Adding and Replacing Parts section. Press and hold the power button for 10 seconds. Reattach the AC power adapter to the computer. Power the computer on. Replace the Internal Keyboard
Nov 07, 2009 | Dell 0Y3740 Keyboard
My printer has a parallel plug and my new docking station...
You can buy a cable that goes on your old printer cable to convert to USB most computer shop will hav these or can get one
Jan 25, 2009 | IBM (250410U) Docking Station for ThinkPad
USB ports in docking station stopped working suddenly
I was having the same problem - the USB ports seemed to have stopped working so I could not use the mouse, keyboard, or printer, even though the monitors and power could still operate through the docking station. Finally, I just unplugged the docking station for 30 seconds, plugged it back in, and everything resumed working. I was surprised it was that simple, but it's working for the moment.
Aug 27, 2008 | IBM (250410U) Docking Station for ThinkPad
After docking laptop I have to add port prior to printing
I assume you're running Win Xp. Disconnect the USB cable from the docking station. Go to START/CONTROL PANEL/PRINTERS/VIEW PRINTERS. Double click on the Konica icon. In the print queue that opens, delete any pending print jobs. Go to START/CONTROL PANEL/ADD REMOVE PROGRAMS. Uninstall any Konica software. Go to START/CONTROL PANEL/PRINTERS/VIEW PRINTERS. On the MENU bar, click on PRINTER/SERVER PROPERTIES. Click on the DRIVERS tab. Remove anything that says Konica. Click on the PORTS tab. Remove ALL the Konica ports. Reboot Re-install the printer driver - DO NOT plug in the USB cable until it tells you to. That SHOULD do it. If it does not, please let me know and I'll research it further. Ed
Jul 13, 2007 | Konica Minolta PagePro 1350W Laser Printer
HP DeskJet 710c InkJet Printer Logo
107 people viewed this question
Seeker5211
Seeker5211
