Question about Microsoft Office Professional 2007 Full Version for PC
I'm using jet reports with excel 2003, All I want to do is use two different tables- one with a customer ID and another that has the customer id and customer name. I want to link the two together so that it brings back the associated customer name with the id. I'm sure this is quite simple, i'm just very new to jet reporting and creating reports in excel.
  • 1 more comment
  • klane150 Jul 28, 2009
    There is a report wizard in which you can pull in a single table and create a report from just the one table. However, I need info. from another table. Both tablees have a common field (the customer ID). In the past I've used Access and I could easily link the two fields together and create my report using data from both tables. However with jet reports I have to use excel and I can't figure out how to create that link between the two common fields in each table. I hope that makes some sense.
  • Mohd. Tareq
    Mohd. Tareq May 11, 2010
    if you have any idea about excel formula like [=IF(ISERROR(VLOOKUP($F6,STOCK_POSITION!$A:$I,2,FALSE)),0,VLOOKUP($F6,STOCK_POSITION!$A:$I,2,FALSE))] or =if(----$A1$2=0,0,A5) etc. you can do it easily....If you want to build relation between two or more excel sheets...please let me know....I will try to help you...or make a module sheet... and clarify.
  • Mohd. Tareq
    Do you have any Idea about the Excel Formulla and the Pivot table.
Hi.. U can try vlookup formula for linking in excel.. if u dont know how to do it.. Replay on same i'll say u how to do it bye...
Posted on Jul 16, 2010
Memory is used up by excel
I don't think you can. It's a real resource hog especially if youre using 2010/13. See below.
Excel 2003 is officially limited to 1 Gigabyte (GB) of memory.
This limit appears to be a limit on the working set memory used by the Excel process, which is the memory reported by Windows Task Manager.
Although Excel 2003 has a substantially increased memory capacity, many of the individual specific memory limits listed below have not changed in Excel 2003.
Excel 2007 is limited to 2 Gigabytes of memory for the Excel process under Windows XP/Vista (Windows memory limit).
This 2 Gigabyte limit is a limit on the Virtual Memory address space. Virtual memory used by a process is larger than the working set memory reported by Windows Task Manager, so the amount of useable memory under Excel 2007 is considerably less than twice that of Excel 2003.
Because Excel 2007 (Excel12) also requires more memory to store the indexes to the increased number of rows and columns you may not be able to load larger workbooks under Excel 2007 than was possible under Excel 2003. Memory Fragmentation may also mean that it is difficult to make use of all of the available 2 GB of virtual memory.
Many of the individual memory limits listed below have been removed in Excel 2007.
Excel 2010 is available in 2 versions: 32-bit (2 Gigabytes of virtual memory) and 64-bit (8-Terabytes (which is 8000 Gigabytes of virtual memory)).
The 32-bit version has the same memory limits as Excel 2007, but the 64-bit version, when used with a 64-bit Windows operating system, will have extremely large memory limits.
Note that the different versions of Windows Vista 64-bit and Windows 7 64-bit support differing amounts of RAM.
Aug 17, 2014 | Microsoft Excel for PC
MS Project report customization
1.Click View > Resource Sheet.
Click View > Tables, Cost to apply the Cost table.
Review the cost columns.
Apr 10, 2017 | Microsoft Office Project Professional 2003...
Want to populate a form with data from a table, the Id number is keyed into the form and once it's matches with the Id in the table I want the other fields on the form to be populated with the data from...
Create a Form from the main table with a subform based on the other data you will want populated. You put the fields in the subform that you want populated from the main form. Go to the properties for the subform and select the data tab, In the data tab, select the Link Master Fields and choose the field you want linked. When you type the ID number in the main form, the other firlds you have in hte subform should populate from the data inthe table.
May 14, 2009 | Microsoft Access 2003 for PC
Invoice & Order Minimize Data Entry - Especially Name and Address
Do you have Microsoft Access? If so, you could use that to create a database and an invoice form. You could also use Access to "dump" the info into Excel to track and record.
Otherwise, try searching for "Import Data" in the Excel help. It would be very difficult to walk you through the whole process, but if you have specific questions about certain steps, that would be more manageable.
Jan 06, 2009 | Microsoft Excel for PC
Minimize Data Entry
I will suggest you to create small application in .net for ths which will add some value and process your data;If you want to use Excel only make a master sheet with details and use it in other excel sheets
Jan 02, 2009 | Microsoft Excel for PC
Import Database - No tables
Your table may be open in another application. Try closing the database or file, and then try to the import process again.
Oct 29, 2008 | Synercard Asure ID Enterprise (932011001)...
How to compare a value in a subform with parent form's value in Dcount
Assuming that Process id is an integer, this should do the trick:
DCount("[stageid]", "Process Stages", "[Process id] = " & Me.Parent! [Process id])
Regards -- Joe (Access VBA samples)
May 01, 2008 | Microsoft Office Access 2003 (077-02871)...
Forget excel 2003 password so how break it pl help
You can recover your lost excel password with the use of excel password recovery software likehttp://www.stellarinfo.com/password-recovery/excel-password-recovery.php
First use trail version if you are satisfied with result then go with full version?
Feb 16, 2008 | Excel (SS8SATAS5128400R)
Export data in excel sheet and in specific column
I did not write this but look towards the end of the code and it will give you an idea on how to do it
Sub ExportToExcel(strOutputFile As String, Optional boolSuppressMessages As Boolean = False)
Dim strTemplateFile As String
Dim fso As Scripting.FileSystemObject
Dim cnn As ADODB.Connection
Dim rstTarget As ADODB.Recordset
Dim rstCustomers As ADODB.Recordset
Dim rstServiceReps As ADODB.Recordset
On Error GoTo ErrorHandler: On Error GoTo 0
Set fso = New Scripting.FileSystemObject
' Get template file path
strTemplateFile = CurrentProject.path & "\CompaniesEmployeesList.xlt"
' Copy template to the target
fso.CopyFile strTemplateFile, strOutputFile, False
' Open a connection to the workbook
Set cnn = New ADODB.Connection
cnn.Provider = "Microsoft.Jet.OLEDB.4.0"
cnn.ConnectionString = "Data Source=" & strOutputFile & ";" & _
"Extended Properties=""Excel 8.0"""
cnn.Mode = adModeReadWrite
cnn.Open
' Open the target recordset (the Excel sheet)
Set rstTarget = New ADODB.Recordset
rstTarget.Open "SELECT [ID], [Name], [City] " & _
"FROM [Sheet1$]", cnn, adOpenDynamic, adLockOptimistic
' Open Customer data recodset
Set rstCustomers = New ADODB.Recordset
rstCustomers.Open "SELECT CompanyID, CompanyName, City " & _
"FROM Customers " & _
"WHERE City = 'Madrid' " & _
"ORDER BY CompanyName", CurrentProject.Connection
' Open Service Rep data recodset
Set rstServiceReps = New ADODB.Recordset
rstServiceReps.Open "SELECT EmployeeID, [LastName] & "", "" & [FirstName] AS Name, City " & _
"FROM Employees " & _
"ORDER BY [LastName]", CurrentProject.Connection
' Loop through Customers result set and copy to target
Do While Not rstCustomers.EOF
rstTarget.AddNew
rstTarget![ID] = rstCustomers!CompanyID
rstTarget![Name] = rstCustomers!CompanyName
rstTarget![City] = rstCustomers!City
rstCustomers.MoveNext
Loop
' Insert blank line between result sets.
rstTarget.AddNew
rstTarget![ID] = ""
rstTarget![Name] = ""
rstTarget![City] = ""
rstTarget.Update
' Loop through Service Reps result set and copy to target
Do While Not rstServiceReps.EOF
rstTarget.AddNew
rstTarget![ID] = rstServiceReps!EmployeeID
rstTarget![Name] = rstServiceReps!Name
rstTarget![City] = rstServiceReps!City
rstTarget.Update
rstServiceReps.MoveNext
Loop
rstTarget.Close
rstCustomers.Close
rstServiceReps.Close
cnn.Close
If Not boolSuppressMessages Then
MsgBox "Workbook Created", vbInformation + vbOKOnly, "ExcelExport"
End If
ExitHere:
On Error Resume Next
Set rstTarget = Nothing
Set cnn = Nothing
Set rstCustomers = Nothing
Set rstServiceReps = Nothing
Exit Sub
ErrorHandler:
Eval "MsgBox(""Error " & Err.Number & "@" & Err.Description & "@"")"
If Not cnn Is Nothing Then
cnn.Close
End If
Resume ExitHere
End Sub
Jan 03, 2008 | Computers & Internet
Microsoft Office Professional 2007 Full Version for PC Logo
267 people viewed this question
Top Microsoft Computers & Internet Experts
micky dee
Alun Cox
Are you a Microsoft Computer and Internet Expert? Answer questions, earn points and help others
