Question about Husqvarna Chain Saw 20" Bar
I have a Jonsered 2065 chainsaw. It will crank fine, when you give it gas it runs rough, it wont pick up speed, it spits and goes dead. We put a new spark plug on it, checked the carb., flywheel. It seems to be getting gas. Thanks KG
  • 245 Answers
If the previous suggestion doesn't fix it, and it's running fine at idle, you should let it warm up well before giving it gas. If it is warmed up and still dies, your high-speed needle may be set too lean or the fuel passage may be partially clogged. Dying when the throttle is applied usually means the fuel setting is too lean or a jet is clogged.
Posted on Jul 30, 2009
    Scholar:
  • 173 Answers
If you have checked the plug and air filter, and all is well, then it must be a timing problem.
There are two solutions to sort out the timing.
The first, is to adjust the gap on the plug,
and the second is to adjust the gap on the magneto.
That'll sort it out.
Don't forget to rate:)
Posted on Jul 28, 2009
  • Lemming Leejn
    Lemming Leejn Jul 28, 2009
1999 kia sephia hesitate to pick up speed then surges all of a sudden why thank-you
if it starts and runs wont be
timing marks or crank angle sensor
or coils
any engine check light on ?
could be the air idle sensor
egr
fuel pump pressure to the rail
Apr 11, 2017 | Kia Cars & Trucks
Oil ratio for my Swedish made jonsered chain saw model 625=2
Using only a high quality 2 cycle oil mix 2.6 ounces of oil to a gallon of fresh gas.
Sep 30, 2014 | Oregon Jonsered 13" Chain Saw Repl. Chain...
I have a 757C chain saw. When I start it, it idles rough for a couple of minutes and then once it warms up runs fine. I put a new carb on this saw and have adjusted the high and low speed needles. The
did you replace the crank seals ? The seal goes out on the crank next to the clutch,it's called a grease seal, it loses the suction needed to pull fuel in to the engine, can be a tricky one to replace, but will spark a new saw back to life. You may want to replace both crankshaft seals
Nov 08, 2013 | Shindaiwa 757
Need initial carbueter settings for jonsered 2041 chainsaw
Basic setting H 1 turn out L 1 1/4 turns out, you will have to fine tune from there, maximum free no load speed 12500rpm idle speed 3000 rpm
Apr 19, 2013 | Ryobi Factory Reconditioned 18" 40cc...
No spark from spark plug
my jonsered 2041 was like that and I replaced the coil with a new one worked fine after that
Mar 27, 2013 | Ryobi Factory Reconditioned 18" 40cc...
I want to know which way the piston and ring goes on a 2065 johnsonred chainsaw
The piston crown will have an arrow on it if you clean the carbon off, the arrow always goes towards the exhaust port which puts the ring peg at the inlet.
Jan 23, 2013 | Husqvarna , No.455 Rancher, 20" Gas -...
My ps 9010 dolmar goes dead after about 10 minutes of running
Tim:
The problem with your saw could be a few things. First, check the filter at the end of the fuel line in the tank. Sometimes the filter hangs up in a part of the tank where it is not totally submerged in the fuel. This can happen especially if you are doing side-cuts or tilting the saw. you may possibly need to adjust the fuel/air adjustment screws on the carburetor.
Jan 18, 2013 | Dolmar New Chainsaw PS-9010
My chainsaw wont run at full speed
Dump the gas and start over, pour some chem-tool in the tank slosh it around for a wile and dump it out, then refill your saw with NEW PREMIUM GAS and NEW OIL mixed at the correct ratio, it will take a few minutes to get the old fuel out of the line but then it will run like new, Gas and oil goes bad faster these days as oil company's no longer put in as much if any stableizer's
Feb 20, 2009 | Husqvarna Garden
Husqvarna Chain Saw 20" Bar Logo
861 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
