Question about Xerox Phaser 8500/DN Printer
Paper jams at front feed. noisy when starting. grinding noise
Could have spilled ink on a move as it only cooled for 10 minutes.
    Scholar:
  • 141 Answers
Run remove ink smears. Clean pick an feed rollers with packing tape.
Posted on Aug 04, 2009
Hp photojet 7520 automatic document feed works but is very noisy since I removed a paper jam.
one of the gears must have come out of place a little. Will still work but will be noisy
Feb 28, 2015 | HP PhotoSmart Office Equipment & Supplies
P3005 jams
Post the exact error message indicated on the printer LCD. 13.01, 02 paper feed issues, worn rollers or jammed paper inside of paper feed assembly.13.05, 06 fusing assembly issues, broken sensor flag in fuser or worn busing on fusing rollers (fusing assembly will be noisy or making grinding sound.) If this the issue being noisy, the fusing assembly has to be replaced along with one of the drive gears, about a 30 min. of work.
Sep 30, 2011 | HP LaserJet P3005 Printer
It's says there is a paper jam and there isn't, then the ink cartriages keep popping up and makes loud noise...
1. Turn the printer off and open the access cover.
2. Look for any obstructions in the paper path and remove them if necessary. (It is possible to move the carrier assembly with the power off.)
3. Turn the printer on, load some paper, and press the Form Feed button.
4. Watch the paper as it feeds through and try to determine where the jam is occurring.
5. Check to see if all the rollers are turning.
If all the rollers are turning, there may be something in the feed path that you can't see. Go to step 6.
If not, there is probably a feed motor or a gear problem and the printer may require service.
6. If the paper is jamming under the carrier assembly, you may be able to fix it using the manual feed slot.
7. Turn the printer off.
8. Take a #10 envelope and feed it through the left side of the manual feed slot until it comes right through the printer to the back of the exit rollers.
9. Move it up and down first, and then slowly move it over to the right side. If something is stuck
Dec 10, 2009 | Dell 948 All-In-One InkJet Printer
I have an HP C4180 and there is a grinding noise when the print head moves back and forth and the paper will partially feed and then jam. Just started doing this.
Contact HP and let them know what a inconvenience this is to you they are very good about keep their customers happy. I've replaced three HPs that where in warranty.
Nov 20, 2009 | HP Photosmart C4180 All-In-One InkJet...
Printer heads won't move into view....just makes a grinding noise. All lights are flashing. Thanks!!!!
with it making a "grinding" noise, I first wonder if you have children. if so, then open the lid and/ or look in the paper feed area for plastic tools, band aids, etc. (worked in tech support and once had a gerbil stuck in a printer by it's tail! OUCH!)
if not, then try this procedure that I found else-where on Fix-Ya.
"Turn the printer on while holding down both the ink and paper buttons. When the paper light flashes release both buttons, then hold down the ink button for approx. half a minute until the printer lights flash again then release it. That resets the printer.”
Feb 24, 2009 | Epson Stylus 880 InkJet Color Printer
Grey sponge came out when I pulled a jammed paper out of printer
its the ink blotter it collects any excess ink when you load in new ink cartridges you can still use it but watch out for any spills ...
hope this helps... jedi-inc...
Feb 09, 2009 | Canon Pixma iP6600D InkJet Photo Printer
Canon mp830 errors 5110 and 6A00
Hi
Error 6A00
The 6A00 is a Canon generic code for paper path jam.
Solution 1:
Move the printhead carriage back and forth a few times.
Solution 2:
Check the purge unit: Moving the print head assembly will not clear a purge unit if its jammed with paper, paper clips, push pins, screws, cookie crisp, flower bud pods or the like.
Solution 3:
Press the ink pads down in the purge unit.
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Jan 24, 2009 | Canon PIXMA MP830 All-In-One InkJet...
Phaser 860 Printer posting a paper jam at start up.
Sounds like printhead needs replacement.
Moving these printers without cool down is known to destroy printheads and of course wax goes everywhere and then everything else fails.Think about replacement
Jul 02, 2008 | Xerox Phaser 8400 Laser Printer
Paper Jam...grinding noise
The print head lock is probably not retracting. Look for the white plastic block that pokes through from the paper feed side just in front of the head. Push it in with your finger and move the head to the middle by hand. Now turn the machine on. Then turn it off using the correct method. Then turn it on once more. If it starts grinding again, you screwed the feed mechanism when tugged out the jammed paper (probably pulled it backward through the feed instead of making it go forward and out the correct exit). If this is the case, you may as well bin it. If it in warranty, you can try to get a claim for repair.
Jun 15, 2008 | Epson Stylus CX3200 All-In-One InkJet...
Lexmark Z11 Printer will not work
i am having the same problem and after looking it over, something is not feeding it thru the beginning of the paper starting in. if i pust 1 sheet down far enough to grab the paper it will print one page at a time. I have been unable to determine what is not feeding at the beginning yet.
Oct 03, 2006 | Lexmark JetPrinter Z11 InkJet Color...
Xerox Phaser  8500/DN Printer Logo
245 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
