Question about Watches
How do i attach a hook end c ring watchband - Watches
Need the replacement strap for Timex watch M805
Timex Watchband - watchbands.com
www.watchbands.com/Departments/Timex-Watchbands.aspx
Original Timex® Replacement watchbands and straps designed to fit Casio, Seiko ... Currently the Timex bands we have are below. Leather Timex Watch Bands.
Jan 01, 2016 | Timex Watches
Need replacement part for end of watch band Michael kors mk5362
Forget it! Unless you have a specialized jeweler nearby who stocks watchband parts you would be better off getting a new watchband!
Jan 07, 2013 | Watches
The clasp on my steel watchband pulls away from the band creating a large gap. it looks bad and catches on things. what do i do?
You need to make sure that if you had the watch band adjusted they did not adjust it at the clasp. When you adjust the watchband links should be removed if you adjust it at the clasp the band keeps pulling open. When you open the clasp fully make sure the pins are on the end holes. If the pins are in the end holes then, the clasp is probably sprung somehow and you will need a new one or have a jeweler or watch repairman fix it! You may also be able to order a new clasp from manufacturer! Hope this helps!!
Sep 21, 2011 | Watches
How do I add a link to the wristband?
Thank you for contacting FixYa.
  • Turn your watch on its side so the links are vertical. On the inside of the links closest to the clasp you can see arrows, which point in the direction that the pins must be pushed out. Only about four links on either side of the clasp have arrows, because these are the only links with removable pins. On the edge of the links on the opposite end from where the arrow is pointing you will see a small circle where the pin is inserted.
  • 2
    Place the tip of your pointed tool on the small circle mentioned in Step 1. Push downward on the pin in the direction the arrow is pointing. Once the pin starts to come out of the link, use your fingertips or a pair of tweezers to completely remove the pin from the link. You may need to use force, but be careful not to scratch your watchband. Use a pointed tool from a jeweler's or hobby kit or watch pin removal tool.
  • 3
    Slide the links apart where you removed the pin so there is a gap in the watchband. Slide your new link into the gap and fit the neighboring links into the new link so it matches the rest of the watchband.
  • 4
    Insert the new pin into the watchband. You will need to insert two pins, the pin you moved in Step 2 and your new pin, into the two empty pin holes. You need to insert the pin small end first so the larger pin head does not pass through the link. Insert the pin against the direction of the arrow rather than in the direction the arrow is pointing like you did in Step 2. Use your pointed tool and your fingertips to push the pins completely in the links until the pin head is flush with the edge of the link.
  • Best regards. Jewel
    Sep 16, 2010 | Nixon District Watch
    How do i install additional links to this model watch? the company mailed me 2 additional links but no installation instructions Fossil model ES1967
  • Place the tip of your pointed tool on the small circle mentioned in Step 1. Push downward on the pin in the direction the arrow is pointing. Once the pin starts to come out of the link, use your fingertips or a pair of tweezers to completely remove the pin from the link. You may need to use force, but be careful not to scratch your watchband. Use a pointed tool from a jeweler's or hobby kit or watch pin removal tool.
  • Slide the links apart where you removed the pin so there is a gap in the watchband. Slide your new link into the gap and fit the neighboring links into the new link so it matches the rest of the watchband.
  • Insert the new pin into the watchband. You will need to insert two pins, the pin you removed in Step 2 and your new pin, into the two empty pin holes. You need to insert the pin small end first so the larger pin head does not pass through the link. Insert the pin against the direction of the arrow rather than in the direction the arrow is pointing like you did in Step 2. Use your pointed tool and your fingertips to push the pins completely in the links until the pin head is flush with the edge of the link.
  • Aug 18, 2010 | Watches
    Unclear as to how you adjust the rubber band strap
    1. Remove the deployant clasp from the watchband. The clasp is attached using spring bars on each end of the clasp. The method of spring bar removal varies but is usually performed by pushing a small pointed tool (one end of a spring bar tool) into a hole at the end of the clasp. While depressing the spring rod, pull the buckle away from the bracelet to detach. Repeat this for both sides of the buckle.
    2. Step 2 Measure the watchband to determine proper sizing. Use the scissors to cut along the inner grooves to remove needed sections (each section of the rubber will contain a new set of holes for the bracelet spring bars). Cut carefully and conservatively, as this step cannot be undone.
    3. Step 3 Reattach the buckle to the band after resizing. Reverse Step 1, pushing the spring bar in while sliding the buckle back into place.
    jQuery('.article ol .image').each(function(i,e){ var $this = jQuery(this); $this.find('img').error(function(){ jQuery(this).remove(); $this.remove(); }); });
    Aug 16, 2010 | Tissot T Race Case Stainlesssteel carbon...
    How do i change watchband for casio bg169wh
    Take the watch with the broken watchband and place it on the table. With a ruler, measure the width of the broken band at the point where it is attached to the watch. Now, measure the total length of the watchband when it is in one piece and fits around your wrist. There will be a crease on the band where it is normally buckled.
  • Step 2 Go to the local store and select a band that you like. You should make sure that the width of the band at the point of attachment to the watch is the same as the old band. Also make sure that the new band will be long enough and not too long to fit your wrist. Purchase the band and return home to change the band.
  • Step 3 Clear a spot to work and make sure that there is a small towel covering the table top so that you can see anything that may drop or pop out during the process of changing the band.
  • Step 4 Use a magnifying glass to look at the point where one side of the band is attached to the watch. You will see a small pin connecting the band to the watch on either side of the band. Carefully use the jeweler's screwdriver to depress the spring loaded pin from the watch to the band and release it from the watch. When the tension on the spring pin is released it may pop out of the band and you will want to take care not to lose it. Repeat this process with the other half of the band.
  • Step 5 Take the new band and slip the spring pins into the small holes on the end of the band where it will attach to the watch. Working with one end at a time, slip one side into the pin hole in the watch body.
  • Step 6 Use the jeweler's screwdriver to depress the other side of the spring pin and guide it into the pin hole in the other side of the watch body. Repeat this process with the other half of the watchband and other spring pin. You now have a new band for your broken one.
  • Jun 20, 2009 | Casio BabyG BG169WH3V (Size: ) Watch for...
    Changing a Rolex metal watchband to a leather watchband
    Put the watch face down and examine the point where the band is connected to the watch case. you will find two holes and through them you will see sprinbar ends insertyed into watch case lugs. Take the tiny screwdriver and push the springbar end inwards,then do the same at the other lug reaching them through those holes.
    Then repeat the same at the other end of the band.
    Measure the distance between watch case lugs- this will be exact size for your new leather band.
    Rate me, plesae.
    Mar 23, 2009 | Rolex Daytona 116528 Wrist Watch
    Take link ot of watchband
    take it to a jeweler because if you do it your self your warranty is no longer valid
    Jan 06, 2009 | Citizen Aqualand Duplex JP104009E Wrist...
    Watches Logo
    202 people viewed this question
    Top Watches Experts
    Ansel Alberto
    Ansel Alberto
    Are you a Watch Expert? Answer questions, earn points and help others
