SOURCE: i have no ignition on my zongshen 250cc, how do i install one?
It could be the ignition switch or the starter it self. I would be better to have a certified mechanic perform the work.
Quadboss
SOURCE: will a 750 motor from a 93 nighthawk fit in a 99 nighthawk 250cc cbx frame
if you get both engines side by side then measure the length , hight and width of them and the frame you will see if it will fit in the hole ! Then measure the areas where the engine mounts fit you will see if same or different and what you have to alter ! Anything is possible !!
If it fits in the hole then align temp' and see where the exhaust ports come out near the down tubes of your frame and see if it needs altering ! If frame needs stretching up , down , left or right then when adding tubes use tube inserts to strengthen !! Hope this helps to give you an idear bud ! P...
