My brake lights won't work so I am looking for a wiring diagram for my 1970 dodge islander recreational vehicle
SOURCE: brake light wiring diagram 1972 Gremlin
I have a 72 amx, the two wire conector at the brake light switch down on the brake pedal is light green and pink and the plastic connector is brown and plugs into the switch at the top of the brake pedal.
SOURCE: need help with the wiring diagram for my 92 Dakota, has not brake lights or blinkers
www.wiring-diagram.com
You can get any wiring diagram for any vehicle. It will cost about $12 and it's well worth it. It will give you the complete diagram bumper to bumper.
SOURCE: brake wiring diagram chevy lumina
why not just replace the turn signal switch must faster and safer . buy one from your local parts house then you can see its not that easy to install but you can do it with a little help
SOURCE: need a wiring diagram for a chevy s10. brake
your power starts at the brake light fuse,check with a test light,then proceed to stop light switch on brake pedal under dash,one wire will be hot when when you check it with your test light, the other won't be until you press down the brake pedal then the power flows through to the second wire,if no power to second wire replace switch,if you have power remove tail light bulbs and check for power in side socket.
SOURCE: Looking for a tail light
low beam kigth out on driver side replaced balb an still dont work this is om my 2004 dodge ram 1500
