Question about Maytag Neptune MAH5500B Front Load Washer
The belt keeps coming off my maytag washer mo. mah55flbww. tub bearing seem good motor seems ok
    President:
  • 1,776 Answers
That is a tough one, especially since you indicate that the bearings are okay. The belt not wanting to stay on a Maytag Neptune washer usually does not bode well. It is usually an indication that the drum bearings are shot. Look for brown splatter on the back of the drum and the inside bottom of the washer. The presence of any brown discoloration is a pretty good indicator that the bearings are going. Anyway, hope this helped, sorry for your problem, and best wishes.
Posted on Jul 27, 2009
Maytag washer pav5157aww
Your pump is probably stiff. Bearing is going out.If the pump is ok I would look at possibly replacing the thrust bearing. Their could be something between tubs.
May 15, 2013 | Maytag Neptune Washer
Won't spin at end of cycle. Maytag top load washing machine
RITS REAL COMMON WITH THAT MODEL FOR THE BEARING TO LOCK UP. TURN THE TUB BY HAND A LITTLE THEN TRY SPIN, IF IT THEN RUNS YOU NEED A BEARING/SEAL KIT.GOOD LUCK
Jan 16, 2010 | Maytag SAV5710 Top Load Washer
Maytag Neptune MAH3000AWA seems to be rubbing
I suspect that you have a leveling bracket come loose. Many of the Maytag washers also use a large concrete block fastened underneath to help balance things. Look to see if yours is this type. If so then the steel rod holding thinge that holds it in place may have come loose...should be easy to put back correctly but will require some muscle. Most of the Sears Kenmore units have springs that can come loos from their connections and require re hooking but I do not think you have this type of unit for a Maytag. Hope this helped.
Aug 21, 2009 | Maytag Washing Machines
Constanat noise from motor, seems to run ok
Well, I'm glad the pump suggestion helped then. If you need anything else, just drop us a note. :)
Jul 11, 2008 | Maytag Atlantis MAV6451 Top Load Washer
Groaning noise in Maytag 4000 washer
yea probly passed warr from manu , if its rear bearing issue gonna run alot ot fix BIG JOB!
Feb 23, 2008 | Maytag MAH6700AWW Neptune Front-Load...
Maytag washer repair
I had the repair guys out 3 months ago maytag paid for labor I paid $150 for seal and bearings, tub froze and belt broke. the tub now is making the loud screams that others complain about I contacted maytag and reapir servce and talked with the tech. this machine is a piece of S$%^ the seal fails on a regular basis and bearings get water in them. I just missed my 3 month waranty and will not pay for that repair again. people at home depot agree that this machine is trouble. the machine must be taken completely down from the top to replace the bearings and or the belt. the tub must be removed. If you call maytag they will pay for the labor but not the parts.
Jan 06, 2008 | Maytag Legacy Series Top Load Washer
Washing machine problem
Sounds like the upper bearing located in the outer tub seal is bad. It takes very little play at this bearing to cause what you are describing.
b739f41.gifThe area of this picture you are interested in is the top left. This is the tub seal assy.
Dec 28, 2007 | Maytag Atlantis MAV6451 Top Load Washer
Belt installation
repacing the belt on a neptune is simple. unplug the unit and move it away from the wall.. now remove the 4 screws holding the access panel in place. loop the belt over the end of the motor shaft so that the grooved side of the belt catches the grooves on the shaft. now simply feed it around the tub pulley. if you find the belt keeps coming off you might have a bearing problem tht has caused the tub to shift. look for fine plastic powder, almost dust like, that would be the pulley eating into the back of the tub
Sep 04, 2007 | Maytag SAV5710 Top Load Washer
Maytag Neptune MAH5500B Front Load Washer Logo
412 people viewed this question
Top Maytag Washing Machines Experts
Bill Long
Ronny Bennett Sr.
Ronny Bennett Sr.
John Tripp
John Tripp
Are you a Maytag Washing Machine Expert? Answer questions, earn points and help others
