Question about liftmaster Chamberlain Garage Door Opener Transmitter 300MC
Lift-Master garage door opener stopped working
I have a Lift-Master 1/2 hp garage door opener that was installed when the house was built, circa 1997. It's worked fine for 12 years. Now when I push the wall button to open the garage door, the opener box clicks once and then a green light blinks 5 times in succession, then there
s a wait, and then 5 again.The opener doesn't make any other sound but the single click when you push in the button, followed by the 5 blinks of the green light.
I tried everything on mine which had the same problem. I cleaned the the circuit board with a toothbrush to remove some of the excess grease which had flung off the cogs then tried unplugging and plugging back in again and it worked. Mind you I did try unplugging it before several times which didn't work until I cleaned the circuit board. Hope this helps.
Posted on Apr 25, 2013
This might be VERY basic, but this happened to me.
Do you have attic space just above the garage? Could there be a heavy box on top of some wires? Those wires seem to be very sensitive & as soon as I moved the boxes off of some wires that looked like phone wires it WORKED like normal.
Posted on Aug 14, 2009
    Scholar:
  • 173 Answers
The motor will probably need rewinding.
Professional job. Don't forget to take the condensor with the motor.
Or alternatively, if money isn't a problem,, get somebody out to look at it.
There ya go:)
Posted on Jul 27, 2009
I have a garage door opener (Chamberlain Lift Master Professional 1/2 HP) all the sudden it stops durring clossing & opening The garage door. no paticular spot. just on a random spot at ramdom times,...
Somewhere on the power head( motor ) is 2 knobs. The are to adjust up and down force. As the opener gets a little old you will need to turn these up occasionally! Turn to the right a 1/4 of a turn and try. I that doesn't work turn it up a little bit more. This should get you fixed up!
Jul 21, 2011 | Kitchen Ranges
Lift master cablesi removed the cables and doors sectional doors to fix .how do i set the tension. and the roller brackets is there a diagram to tell how to install,there a two holes and i can't...
Please do not attempt to set the tension your self. Call a garage door service Co. Broken arms and fingers result. It is not worth the attempt. Those tension spring do all the lifting of the door and have to much torque to mess with.
Jul 21, 2011 | liftmaster Garage Door 1/2 Hp
Purchased a house in short sale with a lift master 1/2 hp model #1155-4 date 11/92. We got a new car remote, it works fine, but don't know how to program the wireless keypad. It is not hard wired and has...
Sorry that keypad is no used to u.If u don't know the secret codes.Just push in the codes it will work.No enter button,mean u just don't push enter after u push in the codes.
Nov 27, 2010 | Sears Craftsman LiftMaster Chamberlain...
Chamberlain Lift Master Pro Formula 1 only makes click sound
Is the door stuck in the open position? If so the trolley is probably jammed against the bolt just in front of the motor unit. Loosen the chain enough to free the trolley and then run the opener until the door is closed. While the door is closed locate the 'up limit' on the side of the motor unit and turn this control 2 complete turns in the opposite direction of the arrow printed on the cover. Tighten the chain.
Apr 03, 2010 | Sears Craftsman LiftMaster Chamberlain...
Chamberlain PowerDrive 1/2 HP (circa 2000) - part
You can buy any part for a Chamberlain opener from most every door opener company in the yellow pages. They love to sell parts.
Nov 14, 2009 | Sears Craftsman LiftMaster Chamberlain...
Access Master Garage Door Opener opens by itself
The most common cause of this is a bad wall control or the wiring going to it. The wall control goes bad from use and the wiring sometimes has intermittent short caused by the staples the installer used.
Jul 31, 2009 | Sears Craftsman LiftMaster Chamberlain...
liftmaster Chamberlain Garage Door Opener Transmitter 300MC Logo
1,441 people viewed this question
Top liftmaster Electrical Supplies Experts
Vince Heuser
tamska1102
Level 1 Expert
ray gallant
Are you a liftmaster Electrical Supply Expert? Answer questions, earn points and help others
