The fan stops running
On model#acq249xr2 the fan stops in mid run we let it sit 15 mins it works again then it stops..... my husband manually turns the fan and it starts running again and in a few mins the fan stops again
  • 378 Answers
Check whether the power saver mode is on. put it off. or some timer must be on. stop the times. it wll be rectified
Posted on Jul 27, 2009
My car Renault laguna 1999 model hatchback, stop after 5-10 min run.and start working after 10 to 15 min wait.i also note that the car exhausted more fuel then before
try this ?= renew the throttle fly by wire control inside the the car ,they go just like the way you describe ,car runs then just stops ,leave and it goes again ,trust me been their got the teashirt on this one ,some customer paid out over 2000 euros to a renault garage for the same fault and it was still the same till a little bird told me what to change ,with one from the scrappers it been ok ever since
Nov 19, 2013 | 2000 Renault Laguna Estate
2002 Chevy Impala wont start after letting sit after it warms up
Almost sound's like vapor lock , the fuel boils in the fuel injector rail , turns to vapor ! That was a common problem with carburetors , letting the vehicle hot soak after shutting down the vehicle an letting it sit for 10- 15 mins. The fuel would boil away ! Are the cooling fans working ? After turning off a hot engine the cooling fans can run on without the key being on , do you hear fans run ? What engine does your impala have ? 3.4 or 3.8 L . Has the check engine light come on ? The fuel pressure regulator could be leaking fuel . Pull the vacuum hose off the regulator after shut off the vehicle , is there fuel coming out of the regulator ? Dribbling out the end of the hose ? This could be bleeding the fuel from the fuel rail ! Good luck , hope i've given you something's to check that you haven't already .
Mar 29, 2017 | Cars & Trucks
My 1997 grand am runs rough, theres oil around the 1 spark plug, if it sits and runs for a 10-15 min it will start to get hot. also the gas gauge will say 1/2 tank then after a mile or 2 it will say 1/4 ...
Those are troubled cars and older ones are even more troubled with problems I would sell it and get anything but a pontiac and a dodge stay away warning! warning! You got high miles on that ? Its a money drain.
Mar 13, 2011 | 1997 Pontiac Grand Am
I have a samsung air conditioner - model AQV24NS and after 10- 15 mins it shuts down both red & green lights start flashing. The only wayi can get it to work again is to shut off the main power suply...
Please check outdoor unit. Compressor or fan motor getting high amps due to overheat. Clean condenser coil. If still problem, replace running capacitor. If out door fan less rpm replace fan capacitor. In some unit 2 in 1 capacitor is there. So replace one capacitor will rectify fan and compressor problem. Thanks. Helpful?
Jan 09, 2011 | Samsung Heating & Cooling
Stops cooling after a few mins
Check the condenser fan motor It probley has bad bearings and over heats and shuts down
after 15 or 20 min of run time
Jul 25, 2009 | Heating & Cooling
Amana Cooling Condensing Unit fan stops spinning after 15 mins
Capacitor, dirty condencer coil causing the motor amps to run too high. But most likely worn bearing on blade side of motor causing it to pull to one side causing it to over heat and shut down. Sleve bearings should have no side play.
Jun 28, 2009 | Amana PTH123B25AJ Heat Pump Air...
Heating & Cooling Logo
181 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
