Ac fan will not work on low or med only on
Ac fan in my 2000 dodge ram 2500 custom van will not work on low or med only on high why
  • 158 Answers
It may well be the fan switch is defective
Posted on Jul 27, 2009
My ac compressor doesnt turn on on my 2000 dodge ram 2500 5.9 diesel truck.
Make sure you are even getting power through your a.c. switch on the console. That sends power to the main relay and through the high pressure and Low pressure switch in series and then to your compressor clutch. Trace power through all of these and you will know which component is faulty.
Mar 07, 2015 | 2001 Dodge Ram 2500 Truck
Ac heat control switch
The item to check is the blower motor resistor.
I found a video from 2000 Neon youtube for reference.
Jan 16, 2014 | 2002 Dodge Neon
Oil pan gasket and front crank seal replacement on 2000 dodge 2500 van 5.2l
Drain coolant,pull radiator,fan shroud off.Need a fan tool to get that off.Need to pull ac,alt,ps and brackets off. to expose front of engine. Need crank pulley puller. Once that's done the timing cover can be removed. Hint,spring for a new timing set. loosen engine mounts and lift engine at bell-housing remove oil pan bolts.and reverse.Might as well replace oil pump if you intend to keep the van.
Oct 17, 2013 | 1998 Dodge Ram 1500 4WD
Low and medium speed fan for ac does not come on, while high speed fan works. 2000 1500 dodge van, had new condensor unit under dash replaced recently.
Blower motor resistor needs replacing. Follow wires from blower motor to connector, which should be the resistor. Usually in duct work, held in by 2 small screws.
Jul 25, 2011 | 2000 Dodge Ram 1500 Truck
91 chevy Siverado 2500 AC Blower problems
My guess would be the same as yours. Good job.
Jun 23, 2010 | 1991 Chevrolet Silverado 2500
Recharge ac run bypass
more like run a bypass on the low pressure switch
Mar 21, 2010 | 2005 Dodge Ram 2500 Truck
Ac blower fan problems
change the blower resister module,if this doesnt work replace the control head
Jul 05, 2009 | 2000 Dodge Ram 3500
I own a 2006 Dodge 2500 diesel and the air blows cold and when I turn it to high it sounds like its blowing high but the amount of air that should be coming out isnt. On low and med. its right, but only on...
The problem with your ac is the vent door has broken off and is blocking air from getting to the blower. To check and see if this is your problem you will need to remove the blower. The blower is located on the passenger side. You will need to remove three screws located on the blower using a 8mm socket. Once you have the blower removed reach inside and feel for the vent door. If it is broken you can remove it. However, you will need to get this fixed by a mechanic.
Jun 04, 2009 | 2006 Dodge Ram 2500
Heating & Cooling Logo
109 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
