Where are the stk ics located in a mitsubishi vs 6043
  • 29 Answers
Left side on left borad
Posted on Aug 19, 2009
No picture
Sound like you lost Vertical Deflection.  Youshould not have a line across the screen because this could destroy the threeCRT Red, Green, and Blue (Picture tubes) if left on to long. There is a protection circuit built in to protect your CRT’s.    Check on the PCB-SIGNALboard (Tuner located on this board) transistors Q-206 Collector should be around 1 Volt Base and Emitter 0V. If the voltage atthis point is greater then 5 Volts the Vertical output IC-401 (Mounted on heat sink 7 pin inline IC) is bad, Part # LA7845.  Pin Voltages should be PIN 1= 0V, 2= 34V, 3= 32V, 4= 3V, 5= 3V, 6= 33v, 7= -6V.  Data sheet located at http://pdf1.alldatasheet.com/datasheet-pdf/view/40357/SANYO/LA7845.html
Jun 22, 2008 | Mitsubishi VS-6043 60" Rear Projection...
I have no idea so if you can help thanks
The board on the left will have a series of small aluminum heatsinks with black ICs attached to them one of them will be the vertical output IC with about 7 pins on it. try resoldering those ICs and you should get the picture back as the vertical ICs will make the tubes cut off. The vertical IC should be marked on the board but solder all the ICs mounted to heat sinks on that board to be safe.
May 13, 2008 | Mitsubishi VS-6043 60" Rear Projection...
HOW TO RESET MY TV LOCK CODE
OPTION MENU "MENU 1370" SERVICE MENU "MENU 2357" CONVERGENCE MENU "MENU 2359"
Sep 20, 2007 | Mitsubishi VS-6043 60" Rear Projection...
Convergence IC
The convergence IC's are black in color with white lettering on them and will start with STK. These IC's will be standing up and be about 2" X3" in diameter. These IC's will also be mounted up against a large metal device called a heat sink. good Luck
Apr 08, 2007 | Mitsubishi VS-5043 50" Rear Projection...
Televison & Video Logo
27 people viewed this question
Top Televison & Video Experts
Electro Med Services...
