Question about Whirlpool Washing Machines
I need to change the lid switch on my KSQ9544KQO washer. How do I access it?
  • 29 Answers
If it's top load take a screwdriver in the gap between the front panel and top of washer and pry it up it will come rather easy. the top will tilt back and you have access.
Posted on Jul 28, 2009
Lid safety switch how to get out to change how to
Remove screws from rear of timer console, pull console forward and hinge it up to expose brass colored clips. Remove these clips and unplug lid switch connector. The cabinet will now hinge forward and you can remove it to access the lid switch.
Sep 11, 2010 | Whirlpool Ultimate Care II LSQ9564J Top...
LS error
The machine control detected that the lid switch is not functioning properly. Raise the top part of the washer to gain access to the lid switch.
Disconnect the machine from the power source. Gently pry the emblem from the front of the machine and remove the T20 torx screw hidden behind it. Slide the top of the washer forward and raise its front. Prop it up high enough to allow easy access to the lid switch.
The lid switch is activated by an actuator (part number 19119) mounted on a hinge. It will not work properly if the actuator is damaged.
Check the operation of the lid switch using a multimeter. Disconnect the lid switch wiring harness and connect the test leads of the multimeter (set to X1 or ohm) to the terminals of the lid switch and activate it. The multimeter should read zero ohms while the lid switch is activated and open when deactivated.
Replace the lid switch if it is broken or if it fails the test above. Remove the lid switch mounting screw and install the new lid switch. Reconnect the wiring harness and slide the top of the washer back into position. Reinstall the T20 torx screw and the emblem.
Feb 11, 2010 | Whirlpool Calypso GVW9959K Top Load Washer
Washer wont go into spin mode or discharge the water
Check the lid switch or lid striker that operates the switch. lift the top lid and insert a pen or similar into the hole on the right hand side to operate the switch when in spin mode.
If not try shorting the switch temporary, the top part of the washer needs to be hinged back to gain access, to do this insert a flat blade 4" from each side at the seam with the front panel to release the clips, lid will now hinge back to give access to the internals, Isolate the supply and locate the lid switch on the underside of the top panel and remove the 2 wires and short out/ link together. test the spin cycle now should now work and also drain the machine (Draining only works when washer is spinning) If all ok obtain and install a new switch do not leave the switch shorted.
Note this switch only affects the spin and draining parts of the cycle.
Good luck
Jan 02, 2010 | Admiral AW22 Top Load Washer
How do I acces the lid switch on my kenmore washer
The following link explains step-by-step how to access and/or replace the lid switch on a Kenmore top loader:
http://www.fixya.com/support/r385198-replacing_lid_switch
Most lid switches are located under the right hand side of the top panel. Some, are located adjacent to either lid hinge. In any case, you still need to remove the washer exterior case to access it. The switch is held in place with a couple of mounting screws with a ground wire attached. This is a very simple repair, but if you experience any difficutlies please let me know. I hop this helps you.
Nov 27, 2009 | Kenmore 24032\24036 Top Load Washer
My washer turns off when i shut the lid...turns on with weightlid
Check your lid switch. The lid switch is toggled by the action of the washer lid closing and it will not complete a cycle if it does not engage. It sounds like the switch may be loose and needs to either be adjusted, or tightened. If you need instructions, please post back with a brand name and model number so that I can explain how to access the switch. I hope you find this helpful.
Oct 04, 2009 | Washing Machines
Need to replace Lid Switch for Maytag Atlantis 2002 Washer
Hello, I can help you.
Let me explain to you how the Maytag washer lid switch works.
The lid switch is located on the controls panel, and is activated by opening and closing the washer door. The purpose of the lid switch is to prevent the washer from working with the door open.
It is a safety device to prevent the user from sticking their hands inside of the washer while the washer is agitating or spinning.
When the washer lid switch stops working, the result could be that the washer won't wash, drain, spin and in some cases the washer will not work at all.
You will need a multimeter to check the internal contacts on the washer lid switch.
You will also need to use the wiring schematic to see what contact should be close when the lid switch supposed to be on.
You will need to remember that the Maytag washer lid switch is one of the first parts that you will need to check, when the washer don't want to start filling, agitating, draining or spinning.
Jun 13, 2009 | Maytag Atlantis MAV6000 Top Load Washer
Kenmore series 800 lid switch
you can see the video as how to acces the lid switch(at least removethe cabinet) on you tube,
http://www.youtube.com/watch?v=vogysB7XOc8
Dec 15, 2008 | Kenmore 24032\24036 Top Load Washer
Whirlpool Thin Twin Lid Switch and Return Pump access
where the washer and dryer attach just above washer lid there should be screws to rmove cover between units yours may have clips instead of screws that need to be removed to remove lid and top on rear edge of top there is a plug that hooks lid switch just watch when reinstalling top to be sure it reconnects..sorry for mix up those units had 2 different layouts over the years and without an image hard to tell which one you had
Jun 12, 2008 | Washing Machines
How to open washer to check and fix lid switch
the lid switch can be changed without removing from closet for sure,you can remove the angular access panel between the2 units youll see 2 brass clips holding the cabinet to the top, slide the entire top toward you to remove. its located under there. there may be 2 screws across the rear of main top holding down as well but yea pulling out will get you kn more access to any component
Mar 14, 2008 | Whirlpool LTE5243D Top Load Stacked...
Washing Machines Logo
18 people viewed this question
Dan Webster
Dan Webster
Sal DeAngelo
